#26 | |
Re: What to do about a bent frame???
On a related note, if I go with a SWB and I'm using a T5 w/ s10 tail, can I use a 1 piece driveshaft? I will be lowering about 4 to 5 inches out back as well. |
#27 |
A bill of sale might be sufficient, but I would check with your local DMV regarding the issue of having different VINs on the frame and body. It may not be an issue in AZ, but it is better to find out for sure beforehand rather than after the fact and have an issue.
I did a build on a 74 k20 and it had the frame bent to the left by 3 feet. I just purchased a new frame and took bindi to the old vin and took my small grinder and put the truck vin on it. |
#28 |
i dont know about other states but in calif if the VIN is altered in any way the vehicle is to be considered STOLEN... so if you do a frame change here you go to the highway patrol and the will do vin check and issue a new vin for the whole vehicle
#29 |
SWB it is! Straight, no rust cancer, hasn't been hacked up. Only part missing is the bell housing crossmember. I should probably just install a trans crossmember. I think I paid a little too much (800), but I did get a legit notarized bill of sale so that I can do the swap without the fear of the G man confiscating my ride.
#30 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Yeah that is a little steep, but a nice short bed frame is getting hard to find. Plus one with some paperwork to make it legal.
#31 | |
I had found 1 SWB roller. That one was 500. It had been sand blasted and showed signs of deep rust. Also had missing brackets and no paperwork. I also looked at 2 LWB frames. One had been hacked and cut in a failed attempt to notch the rear and replace crossmembers. 250 and no paperwork. The other was just the frame with no paperwork for 300. I wish I could have found a GMC frame as they don't have vin stamps, but now I can start wrenching again. Interesting bit. The stamp on the frame looks like it had a mistake corrected on the factory line. the last number was changed from a 7 to an 8. The vin on the cab was the same numbers with the last number being an 8. |
#32 |
Get you some 2x3 and built a custom frame! Although that would cost as much if not more then getting that frame for 1k.
1965 C10 Project |
#33 |
I would drive a bent truck.
Supercharged Scottsman Scottish by birth, American by law, Texan by the grace of God. “To avoid criticism say nothing, do nothing, be nothing.” ― Aristotle |
#34 |
#35 |
well you know, I'm a little bent myself.
![]() Maybe it could offset the bent frame? ![]() |
#36 |
Good job finding the SWB frame. May be a little expensive up front but piece of mind is priceless.
Cutting down a box isn't all that hard. I did mine first thing. Measure, measure, measure and measure 10 more times. I used an 1/8th" cutting disk and it went real smooth. |
