05-08-2014, 12:18 PM | #26 |
Re: Think I found a dandy
Thanks everyone Correction it is a 62 on the title. I thought the hood should be different, I know GMC stuff can be different though. That firing order diagram would be great. It is home tucked in the shop, let the fun digging in begin.
05-08-2014, 12:21 PM | #27 | |
05-08-2014, 12:26 PM | #28 |
05-08-2014, 12:57 PM | #29 |
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread |
05-08-2014, 01:09 PM | #30 |
here is your firing order http://www.autozone.com/autozone/rep...96b43f80cb0c73
05-08-2014, 01:21 PM | #31 | |
05-08-2014, 01:32 PM | #32 |
it appears that it is
05-08-2014, 04:46 PM | #33 |
"What do I need to do first to it to get it back on the road?"
I can't believe no one said that the only way to get it back on the road was to call them to come get it Great find & good luck.
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
05-09-2014, 12:06 AM | #34 |
60-66 Nut
Just check the function of the clutch, which on the '60-'62 is hydraulically operated. The master cylinder on the firewall is 1/2 for the clutch and the other 1/2 is for the brakes. For the steering, check the steering box for excessive slop and check the tierods and idler arm for looseness, If they all check good, I would grease all the tierods, balljoints and control arm bushings. And since you have the grease gun out, may as well grease the U-joints too.
05-09-2014, 03:51 AM | #35 |
All the above...
I'd add grease all the zerks til new grease comes out, replace all the hoses, including brake flex hoses, and at least flush the brakes. And plan on new tires if the freeway is in the future. Personally, I'd lightly wash it, and maybe use some CLR on the rustier bits, then drive it. The goodness of stuff that comes from OK is crazy. It's an hour away but something's different |
05-09-2014, 11:47 AM | #36 |
Nice find! I would do a good cleaning and paint restoration on it. Some things might have to be repainted but the majority looks good. I wish mine look like that when I found it!
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
05-10-2014, 02:11 PM | #37 |
Thanks gentlemen for all the responses I've started gathering parts and reading lots of stuff on here can't wait to drive it around the block.
05-10-2014, 02:36 PM | #38 |
Somewhere along the years they charged the '60 hood off of her. She has the 62-66 hood, no biggie though.
http://s1299.photobucket.com/user/jb...23904108567829 |
05-10-2014, 05:11 PM | #39 |
I corrected that at the top of this page it is a 1962. The master cylinder was all gunked up and clutch stays on the floor. I think the clutch may be stuck to the flywheel can't seem to get it unstuck or it's not out of gear. Making it hard to turn the engine over with a socket. I poured marvel mystery oil down the spark plug holes may just need to let it set a few days. Sure seems tight right now hope it frees up.
