05-17-2014, 10:31 PM | #26 |
Re: My first 1965 c10 bag build----------fast and cheap build
yes I will have to move it up
05-18-2014, 12:46 AM | #27 |
60-66 Nut
No, it has been beat on at some time to make room for a nonstock engine.
05-19-2014, 12:40 AM | #28 |
Upper a arm brace
05-19-2014, 12:44 AM | #29 |
Rear cut off, a arms done, starting new rear frame rails.
05-19-2014, 12:47 AM | #30 |
Both lower arms
05-19-2014, 01:02 AM | #31 |
60-66 Nut
Nice work
Are you using 4 x 2 for the rear frame?
05-19-2014, 09:43 AM | #32 |
Yes 4x2x1.20 wall
05-19-2014, 10:11 AM | #33 |
Major Surgery!!! Great Work!!!
Nice Sled by the way!
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
05-19-2014, 10:26 AM | #34 |
I'm just glad to be here!
Great work on the front!
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
05-20-2014, 10:02 AM | #35 |
Rear frame rails
05-26-2014, 02:35 AM | #36 |
nice!
~TJ project: "Cream Puff" 1966 Chevy C20 2wd |
05-26-2014, 10:46 AM | #37 |
Your progress is moving right along.
Nice looking welds. |
05-26-2014, 04:54 PM | #38 |
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
05-27-2014, 06:54 PM | #39 |
Those lcas are nice man good looking work
05-27-2014, 06:57 PM | #40 |
Did you change the angle on lower ballpoint? I'm doing something similar right now but I cut the lower arm mounts and moved them up so I can drag the crossmember rather replace plate on x member than grind my frame down and I'm not a fan of blocks
05-27-2014, 07:29 PM | #41 |
Very nice work on the frame rails. What did you do to keep them straight while putting all that weld heat in them?
05-28-2014, 01:05 AM | #42 |
clamped the hell out of them and went back and forth with the welding
05-28-2014, 06:46 AM | #43 |
Cool, thanks. Where are you going to mount the rear bags?
05-28-2014, 10:02 AM | #44 |
right in front of the axle
05-28-2014, 10:09 AM | #45 |
Jamming Right Along!!!
05-28-2014, 12:07 PM | #46 |
looking good!
06-08-2014, 10:29 PM | #47 |
On the ground
06-09-2014, 02:06 PM | #48 |
On the ground
06-09-2014, 02:47 PM | #49 |
Damn you work fast. It looks good! I'm guessing you only have a few hundred bucks in it at most huh?
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
06-10-2014, 10:32 PM | #50 |
Awesome work and fast
