05-15-2014, 10:54 AM | #1 |
My first 1965 c10 bag build----------fast and cheap build
My first 1965 c10 bag build------------------------
My plan is to bag the front and rear. I want it to lay the frame. 383 tpi stroker. I have built many tube chassis rock crawl rigs but I want to be driving the truck soon so I'm going the cheap and not so right way. Raise the crossmember up 2.50" forward 1" Last edited by ronniehotdog; 05-15-2014 at 11:05 AM. |
05-15-2014, 10:58 AM | #2 |
Re: My first 1965 c10 bag build----------fast and cheap build
I'm in for the ride...
aboard!!! We like lots of pics, Hint, Hint...
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
05-15-2014, 10:59 AM | #3 |
Cutting the front out starting in.
1983 front parts found. |
05-15-2014, 11:56 AM | #4 |
Getting ready to cut the dish in for the front 2600's
05-15-2014, 12:00 PM | #5 |
Got the frame cut up 2.5 and forward 1.
Crossmember fits good. |
05-15-2014, 12:16 PM | #6 |
Need to clean the back shop out.
05-15-2014, 12:26 PM | #7 |
Welcome to the forum!
Keep us posted on the build.
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182 700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236 |
05-15-2014, 01:02 PM | #8 |
Welcome and nice start on the project!!
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
05-15-2014, 04:04 PM | #9 |
I'll ride.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
05-15-2014, 06:37 PM | #10 |
Watchin.
05-15-2014, 08:28 PM | #11 |
Rock buggies eh? In thanks for the chance.... Lol
-j-rod '06 3500 LWB CC 4wd, 8.1 Allison |
05-15-2014, 09:36 PM | #12 |
I’m curious does that front "c notch" of the forward crossmember work??? i have seen the sandwich technique and of course the famous drop member but i have not seen this technique used. What else needs to be modified besides the cutting of the frame??
overspecialize and you breed in weakness... |
05-15-2014, 10:33 PM | #13 |
Well I follow along all the time, so I'm here
05-16-2014, 01:04 AM | #14 |
60-66 Nut
You're not wasting any time.
Looks like someone massaged that firewall a little. It must have had a big block in it at some time.
05-16-2014, 01:54 AM | #15 |
I think the firewall is stock. It had a straight six when I got it.
05-16-2014, 02:31 PM | #16 | |
I'm just glad to be here!
Great start Ronnie. Welcome to the board!
This is much easier then doing the pancake or sectioning of the crossmember itself. If you do not do the rack & pinion conversion, then the steer components will need to be relocated the same dimensions as well.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
05-16-2014, 09:15 PM | #17 |
I'm in
-Chapa 65 SWB step-side / 383 stroker / TH350 / 4:10 gears / static drop 4 1/2" front 5" rear. |
05-17-2014, 12:16 AM | #18 |
To go sledding tomorrow or work on the truck?
05-17-2014, 12:17 AM | #19 |
Got the arms started
05-17-2014, 12:19 AM | #20 |
Rear is cut and ready for a new frame
05-17-2014, 09:25 AM | #21 |
LAIDOUT
Fast start! What rack and pinion do you intend to use?
05-17-2014, 11:28 AM | #22 |
stock steering just raised up and moved forward. I am new to the whole 2 wheel drive thing so I will do what I know will work.
05-17-2014, 01:16 PM | #23 |
Registered Loser
Nice! I like the low buck, home builds. Lots of good ideas and fab work.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
05-17-2014, 08:36 PM | #24 |
Got the a arms done
05-17-2014, 08:49 PM | #25 |
