#26 |
![]() Join Date: Mar 2014
Re: FS:72 SWB Parts Long Beach, CA.
#27 |
![]() Join Date: Oct 2001
Jeff I want the power brake booster bracket and rod that runs to brake pedal, I don't need the booster. that one frame that has 1 L shaped center bumper bracket on the right frame horn I need that also.
S.C 29720 thanks Donnie
Things happen for a reason! |
#28 | |
sorry, I miss-understood. The L shaped bracket I need as this frame is the one that I'm going to use. Looks like I'll be on the hunt for one as well. the "Brake booster $65.00" is for the whole set up, the master cylinder, booster, mounts to the firewall and the linkages up to the brake pedal. I'll ad to my ad description to be more clear. I'd rather not piece it out so right now it's $65 bucks plus shipping for the set up and if you want me only to ship part of it for shipping savings I will. I could probably fit all of it less the booster part in a large flat rate for 17.00 or less the booster and master cylinder in a med flat rate for 13.00. jeff |
#29 |
Minus the booster and master cylinder, I,ll pay $78.00 shipped to me, correct?
I just need the bracket,rod and support bracket that mount back to firewall, Let me know if we are on the same page, better yet post a pic of what yr sending me,lol thanks Donnie
#30 | |
![]() jeff |
#31 |
ttt
#32 | |
thanks Donnie
#33 |
Front Cross member set up has sold so I updated the listed to reflect what is still available. As a refresher, Items still for sell:
Brake booster set up. this includes the master cylinder, booster, mounts to the firewall and the linkages up to the brake pedal. $65.00. Front driver side fender. Left Fender has rust in the lower front otherwise it's perfectly straight. $50.00 for the left one. Automatic column. $75.00 1972 a/c cab. The cab will be a bare cab(no glass or interior parts, just the metal cab) Bad: No SPID on the glove box. minor rust in the floor and cowl area, worse rust in the drip rail/roof area. the good: just renewed the tags last month($170 value). cab comes with clean title and plates that are good thru june 2015. It also appears that it may have originally been a big block truck originally as it has the high hump and heat shield on the firewall. it may have originally had a 400 tranny cause the gas pedal has the kickdown switch on it. This cab will come with the doors however they won't come with any handles or the wing windows, or hinges or interior panels as I need them for my truck. they will come with glass and the regulators...the outer skins aren't great though. selling this for $325.00 with the title, plates, and new tags. Tailgate. $75.00 Lastly, I will also be selling the frame for $200.00 It's a long bed frame that has been cut down to a short bed length. The front of the frame was tweaked but a fellow member offered front frame pieces so that it could be fixed. I drove the truck around with this frame and it tracked great. jeff in long beach, CA. |
#34 |
#35 |
Hoping you still have the cab. Sent a pm. My B pillar got munched beyond repair.
