#26 | |
Re: Frame shortening
#27 | |
Makes me wonder if there is a rectangular box steel out there somewhere that would simply slide over the two frame sections as an external box. Square up the frame, clamp or bolt it, and weld. |
#28 | |
#29 | |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Thanks for the video link. I like his reasoning for rounding the corners to prevent cracks from starting.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
#30 |
I have cut 2 frames. One I did behind the cab because I didnt want to remove the cab, and the other was under the cab like Stacey did. Both worked out great it just depends on how far you want to take the truck down. Youll do great if you just follow the advice (and measurements) of all the guys that have successfully done the shortening. GOOD LUCK!!
#31 |
I know you said you have a short bed already and maybe you've seen this, but amazing work here...
--------------------------------------------------------- I'm not crazy, I'm chosen, there's a difference. ---------------------------- '72 K10 SWB, 350, sm465/np205 ---- ---- |
#32 |
So, has anyone used these?
https://www.summitracing.com/parts/c...2rfs/overview/
#33 |
Just cut mine under the cab, removed a foot. I was going to do the Stacy David cut, but the frame on the pass side has a lip in it. Mu cut would have ended up in the middle of it. I did a straight cut and boxed it, couldn't find any channel to sleeve it, unless I bought a full stick. Glad I checked this post, saw that CPP sells some precut. I'll get it and go back in and put them in for added protection. Good luck with your truck.
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE Last edited by rjs53; 03-25-2018 at 12:47 AM. |
#34 |
Just noticed this is a old post, oh well found something new
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
#35 |
Yep, old threads doesn't mean out of date information.
I was hoping to hear if anyone has used those stiffeners and how nice did they fit?
#36 |
They look like the ones Brothers uses in their shortening kit
1970 C-10 "Old Yeller" |
#37 |
Hate to throw money away, but I'm getting ready to order some stuff from Summit and for less than $40 I think I'll take a chance.
#38 |
Click on my build thread. I used the ECE stiffeners and there is detailed instructions on the process. Best money I spent.
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71 |
#39 |
I shortened my frame under the cab. I unbolted all the cab mounts, loosened the core support mounts and lifted/tilted the cab up to give me some working room.
A few pics... My build - http://67-72chevytrucks.com/vboard/s...d.php?t=379889 |
#40 |
And finished -
#41 |
![]() Join Date: Oct 2011
...I'm kind of glad I'm not into this trend, lol.
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
#42 |
Moderator
![]() Join Date: May 2007
That sure is a lot of work! Looks like you did a great job.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#43 |
How snug do they fit before you weld them in?
#44 |
I got my ccp stiffeners from summit today.
Very tight fit. So tight, I was at first concerned. But they fit so tight, I had to tap them in with a hammer. They are pretty heavy duty too. Now to cut a perfectly good longbed frame in half. ![]()
#45 |
Same here, got the frame inserts and they do fit snug. I think they'll work great.
#46 |
![]() Join Date: Nov 2006
gonna do my 72 c10 asap
I BELIEVE IN JOHN 3:16 |
