#26 |
![]() Join Date: May 2007
Re: it's a boy
well had another me day, my lovely bride had plans to go watch her 4yr old great niece.
took the grill back out and straighten it out for the trim ring to fit, swap out the front bumper and made a tag bracket to center it, the parking light are on the to do list the clutch linkage was missing a return spring and had some wrong linkage, sorted through my spare parts to get it working a lot better but still need to work out some more kinks with it. got some help from my buddy John ( olbue60 ) had another great day
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
#27 |
Re: it's a boy
wouldn't have and extra z-bar would you? one in my truck is wrong and rubs the frame... need one hat the arms are more like 140 degrees or so from one another mine are at about 90..
cheers,
'66 C10 SWB '64 C2 roadster '38 Indian Scout Flattracker '70 Triumph T120R '81 Laverda Jota |
#28 |
Re: it's a boy
none of those would work on the 66, I'm thinking about converting it to a hydraulic
#29 |
Re: it's a boy
#30 |
Re: it's a boy
First shake down run
#31 |
Re: it's a boy
Nice looking rig! 5 speed swap is on my short list of winter projects. Will be following your swap for sure.
-j-rod '06 3500 LWB CC 4wd, 8.1 Allison |
#32 |
Re: it's a boy
![]() ![]() ![]() ![]() ![]() James, I'm lovin' what I'm seeing!!!!! ![]()
C/10 Rene 1966 Short Fleet "The Hag" 1967 CST Short Fleet "Dark Poly" 1971 Short Fleet 1970 Jimmy Custom 2 WD "Golden Ticket" 1972 Blazer 2 WD "Retro Blaze" |
#33 |
Re: it's a boy
got some boxes with a bunch of pipe
poof it turn into a instant garage nice and toasty in it's new home
#34 |
Re: it's a boy
GMC front parking light replacement 101
the assembly is held in by clips on the back side I used a flat screw driver on both of the bottom side and pushed it out then do the same on the top
#35 |
Re: it's a boy
you have to drill out the rivets to get it apart
as you can see the repro rivets look like .... well you know the hole for the rivets are counter sunk so I used button head allen # 40 with nuts, they give the same look as the correct rivets you have to clearance the hood for the nuts remember to change the 1157 bulb to amber
#36 |
Re: it's a boy
his and her swb bbw in the garage, I changed out the high beams to fog lights
time to do something with the bed went a different route on this one, I used diesel fuel cut with marine 2 stroke oil to dirty it all need now is for the sun to bleach it this is the fourth bed that I have done and this one was the hardest, every nut and bolt was frozen and most of the metal strips were bent and twisted
#37 |
Re: it's a boy
Your garage is sooo cool.
The bed looks great too along with the new lenses. Where did you get your instant garage? |
#38 | |
Re: it's a boy
The first one live through both hurricane Irene and Isabel. I would recommend to upgrade to the heavy ply cover.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! Last edited by duallyjams; 10-19-2014 at 11:20 PM. |
#39 |
Re: it's a boy
Lookin good. Havent been a fan of the euro look amber lamps but the light blue looks good!
GOD BLESS AMERICA! |
#40 |
Re: it's a boy
I wasn't sure if I would like so just thought I would try and see. I have seen the old style fog lights back in the grill on a GMC that looked good.
#41 |
Re: it's a boy
changed the hood V6 emblems, didn't just want take them off and leave the holes in the hood picked some up on ebay, cleaned them up and repainted them just another pic of the bed wood just a fall pic
#42 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: it's a boy
Such a cool truck!
#43 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: it's a boy
Nice collection..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#44 |
Re: it's a boy
Getting better and better
#45 |
Re: it's a boy
Thanks it's a slow process
Think I'm good for awhile on trucks ![]() half of the buddy bucket is at the upholstery shop once I get it back I'll swap out the driver side, lots of thoughts running around in my head of what I would like to do.
#46 |
Re: it's a boy
All I got done this weekend was added a hood bird, rocket, airplane ah you get the idea. I tried to get a good pic of it but well guess its one of those thing you have to see in person.
#47 |
Re: it's a boy
Nice work ,thats a collection to be very proud of!
#48 |
Re: it's a boy
Nice truck James!!
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
#49 |
Re: it's a boy
Thanks, I'm definitely spoiled
I got tired of waiting for you to turn yours loose ![]() I need all new glass for this one also I will be giving the shop a call soon.
#50 |
Re: it's a boy
Looking good. Makes me want to keep mine.
