11-23-2014, 08:27 PM | #26 |
Re: Leg room
I was told you can get more room by moving the gas tank. Using a bench seat that the top sits below the cab line, the brackets can be moved back, giving a couple of inches? Also, told the steering column can be moved towards the dash- with minor changes to the shaft?
Local guy with a '67 told me this |
11-28-2014, 08:55 PM | #27 |
Re: Leg room
6' 6" 210 lbs. I'm with you. Still looking for a solution to the crammed in seating position. The stock bench seat in my '70 CST is too nice to replace so I'm looking at shortening the mounting assembly.
I find I have even less room in my '69 GMC but that might be due to needing my left leg positioned for the clutch. Good luck and keep us informed.
'69 GMC I6 4sp; '70 Chev C10 CST Hugger Orange/white |
11-29-2014, 05:27 PM | #28 |
Re: Leg room
First time in my life where being short and wide isn't a bad thing!
Neil............... 1972 C10 SWB - Shop Truck in the Works 5.3 LS / Full Air Ride / Rear Notch 20" American Racing Daytonas IG - neilioustx - pictures of build/progress Born and Raised in the Promised Land.... TEXAS Y'ALL!! |
11-30-2014, 04:09 AM | #29 |
Old member
Re: Leg room
You dont want these then either!
I'm 5'-9" and have plenty of room.
