01-04-2015, 07:16 PM | #26 |
Re: Pink's 68/72 - Dropmember Equipped Build
looks good!
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
01-08-2015, 12:05 AM | #27 |
Thanks guys. I appreciate it.
I decided to modify the frame stiffener mounting. I removed the PBFab boxing plates and replaced them with CPP boxing plates. They fit the frame extremely tight and are longer than the PBFab ones. They will be welded in and all the bolt holes filled. I still haven't decided if I am going to bolt the stiffener or weld it in place. What do you guys think? Would there be any reason that I need to remove it in the future? I also started installing the front body drop mounts but I don't have any pictures of that. Hopefully I can make some good progress this weekend and post a few updates. |
01-08-2015, 12:18 AM | #28 |
Looks good. I'd weld it in...I hope my frame doesn't have all those holes...
01-12-2015, 02:37 PM | #29 |
I got the front body drop mounts and crossmember installed. I still have a few more bolts to install but it's pretty much complete.
01-12-2015, 08:09 PM | #30 |
I call for welding it in. The only thing I don't like about all the bolt in aftermarket members is that it looks like a hardware store puked on your frame.
01-12-2015, 08:36 PM | #31 |
Nice progress,I'm gonna jump onboard and follow along. You've got all the PB parts that I plan to order so hopefully I can pick up a few tips and tricks along the way.
01-14-2015, 11:16 PM | #32 | ||
Only a minor update for today. I worked on filling more of the holes in the frame. I haven't ground them down smooth yet but they are slowly getting filled. |
01-15-2015, 09:42 AM | #33 |
Count me in as well. Nice work so far.
01-15-2015, 10:05 AM | #34 |
01-19-2015, 10:40 AM | #35 |
The swiss cheese look wasn't working for me. I think this looks a lot better.
01-19-2015, 08:37 PM | #36 |
A320 Pilot/USAF Retired
Much better!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
01-19-2015, 10:50 PM | #37 |
Nice work! I'm in
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
01-23-2015, 11:32 PM | #38 |
Thanks guys.
01-23-2015, 11:41 PM | #39 |
More welding and grinding. The top of the front boxing plates are welded in and smoothed out. Got the new rear frame boxing plates tacked in place. I also decided to weld in the stiffener. It's just tacked in place for now but will soon be fully welded in.
01-23-2015, 11:55 PM | #40 |
Very nice! Can I ask where you got the boxing plates?
01-24-2015, 07:02 PM | #41 |
They are from Classic Performance Products, 17" long and fit snug in the frame rails.
01-24-2015, 07:11 PM | #42 |
They fit good? I've seen then and considering doing that to my frame.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
01-24-2015, 07:23 PM | #43 |
They are an extremely tight fit. I had to hammer them in to place but I would rather they fit tight than loose. It probably took me about 10 min to get each one in to place. Nothing a rubber mallet and some patience can't take care of.
01-25-2015, 02:01 AM | #44 |
Hi, my name is Chris and I have a problem. I can't stop welding in BOLT ON parts.
Since I'm spending all this time filling all the holes in the frame, I decided to weld in the rear notches. All the bolt holes will be filled and the welds smoothed out. |
01-30-2015, 10:45 PM | #45 |
Tons of welding and grinding lately. Not much of an update but I'm really happy with the way the notches look welded in and smoothed out.
01-30-2015, 10:54 PM | #46 |
I like it....
01-30-2015, 10:55 PM | #47 |
That's looking great.
02-01-2015, 09:14 AM | #48 |
Looking good. My rear got welded on as well.
02-01-2015, 03:27 PM | #49 |
Thanks guys! Sac, do you have a build thread I could check out?
02-05-2015, 05:47 AM | #50 | |
Looks great so far! I'm just in Carson, we should hook up sometime so I can check out your project in person.
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together |
