01-24-2015, 03:20 AM | #26 |
Moderator
Re: 4/6 or 5/7 drop
One more.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
01-24-2015, 03:23 AM | #27 |
Moderator
Re: 4/6 or 5/7 drop
Last one, rallyes again.
01-24-2015, 03:09 PM | #28 |
Re: 4/6 or 5/7 drop
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list. 1972 GMC 4X4 K1500 Survivor - Sold No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy |
01-24-2015, 03:15 PM | #29 |
Re: 4/6 or 5/7 drop
Beauty right there!
01-24-2015, 05:41 PM | #30 |
Re: 4/6 or 5/7 drop
4.5/5.75...1"- 1.5" clearance to snumber above rear axle.
1970 C10 Short Stepper with 71/72 front clip. |
01-25-2015, 09:35 AM | #31 |
Re: 4/6 or 5/7 drop
5/6 drop, 2.5" spindles with 2.5" coils front and 4" drop springs in rear with 2" blocks
01-25-2015, 10:05 PM | #32 |
Re: 4/6 or 5/7 drop
Front 4.5", Back 5"
US ARMY RET, SUPPORT THE TROOPS 1972 Custom/10 Short Fleet 4.5/ 5 Drop Dogg Pound Customs |
01-25-2015, 11:56 PM | #33 |
A day late and $1 short...
Re: 4/6 or 5/7 drop
Yes, it had a CPP notch in the rear.
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
01-26-2015, 12:32 AM | #34 |
70+ ( Old Skool Club )
Re: 4/6 or 5/7 drop
I love the look of your truck, for my taste its lowered just right, not too low. Could you post a sideways shot and tell us what your drop specs and tires size.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
01-26-2015, 08:15 AM | #35 |
Re: 4/6 or 5/7 drop
01-26-2015, 05:56 PM | #36 |
Re: 4/6 or 5/7 drop
Here's mine with a ECE 4/6 kit and 1" lowering blocks. Tires are 255/55/17 with no rubbing issues. I had a c-notch installed as well.
01-26-2015, 07:00 PM | #37 | |
RAT1968 '68 Cab/'71 Parts
Re: 4/6 or 5/7 drop
I like your wheels better.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
01-26-2015, 07:26 PM | #38 |
Re: 4/6 or 5/7 drop
Those of you on 15's, what is the clearance like? I love the look but I'm worried about it scraping on everything because it's going to be driven often.
01-26-2015, 08:22 PM | #39 |
Re: 4/6 or 5/7 drop
I switched to 70 series tires from 50 series to gain extra ground clearance in the front. With the 50s there was about 1-1.5" clearance below the LCA. I picked up an additional ~2" with the 70s.
01-26-2015, 08:23 PM | #40 |
Re: 4/6 or 5/7 drop
Here's a *little* more accurate P-Shop of the side-by-side"
01-26-2015, 11:48 PM | #41 |
Re: 4/6 or 5/7 drop
4.5 and seven rear with c notch.
HSRACER Slammed 53 5 window Blown/Bagged 54 Pickup Patinaed 67 LS stepside Supercharged 67 Nova Bagged 69 Suburban Turbo'ed 5.3 LS |
06-24-2018, 11:42 AM | #42 |
Re: 4/6 or 5/7 drop
06-24-2018, 11:45 AM | #43 |
Re: 4/6 or 5/7 drop
5/7 does not rub The inner fenders becuase I have 6” wide rally wheels in the front . Iv used this setup on two different 67-72.
06-24-2018, 11:53 AM | #44 |
Moderator
Re: 4/6 or 5/7 drop
Mine does not rub either. I have 7” rallies in front with a 215 70 tire. All other wheels/tire combos I’ve tried DO rub (including the American racing ones I posted above a few years back)
06-24-2018, 08:30 PM | #45 |
Re: 4/6 or 5/7 drop
5/7 with BBC. 73-87 Front K-member swap and the early axle housing
Front wheels are 20x8.5 with 5 3/8 Backspace. The rears are 20x10 with 5" Backspace. 255/45/20 and 295/45/20. It is C-Notched.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
11-20-2018, 10:02 PM | #46 | |
Posted via Mobile Device |
11-20-2018, 10:46 PM | #47 |
Re: 4/6 or 5/7 drop
Stock width early 67-68 housing. Porterbuilt Stage 2 mild notch and rear suspension.
02-07-2020, 02:37 AM | #48 |
Re: 4/6 or 5/7 drop
Old thread but I love this stance with the rallye’s. Do you happen to remember what width, back spacing and tire size you ran here? Looks like you said 7” up front with a 215 70 tire.
Thanks!
Kenney 68 Chevy C10 454 |
11-17-2022, 10:23 PM | #49 |
Re: 4/6 or 5/7 drop
Hello what size tires are you running on the rallys with that 5/7 drop? I have 3" springs 2" spindles getting installed up front and I'm wondering if my 275/60/15 are going to fit. Thanks! Nice Truck!
11-18-2022, 09:46 AM | #50 |
Re: 4/6 or 5/7 drop
I'm betting a 275mm wide 28" tall front tire will be an issue.
