Old 02-20-2015, 10:39 AM   #26
Hart_Rod
Hart_Rod's Avatar
Re: Roadster Shop 69 REVO Patina build
Originally Posted by Roadster Shop View Post
Correct. There are eccentrics on the lower control arm that will move the suspension through the full range of alignment. This eliminates the need to take off and thread/un-thread rod ends to do an alignment. With this set up, you can get +1.45 to -2.78 degrees of camber and +3 to +6 degrees of caster.
Here is a clip to illustrate the range of motion.
[/IMG]
Sweet!
Hart_Rod is offline   Reply With Quote
Old 02-20-2015, 01:19 PM   #27
flashed
So this complete set up is bolt in with the exception of the rear C notch ?
flashed is offline   Reply With Quote
Old 02-20-2015, 02:10 PM   #28
Roadster Shop
Roadster Shop's Avatar
Yes, it will be a complete bolt on kit.
Roadster Shop is offline   Reply With Quote
Old 02-20-2015, 02:12 PM   #29
Roadster Shop
The rear suspension installed for initial test fitting and mock up
Old 02-20-2015, 02:17 PM   #30
Roadster Shop
And the front installed
Getting the steering linkage to the rack has always been an issue on these trucks due to the frame rail width and positioning of the steering column coming through the firewall. We have designed a package to take the guesswork out of routing the steering. We fabbed up a chassis brace that bolts into the frame rail. A small notch is required to be cut in the frame to get a better steering shaft angle. The new frame mount includes a tab for a heim joint to support the steering shaft. We have also designed a lower column mount (through firewall) and an upper column mount (to the dash) to secure the column adn position it where it needs to be. This is designed to work with an Ididit replacement column
Old 02-20-2015, 02:46 PM   #31
Number98
Prestige Worldwide
Number98's Avatar
Very Cool...
Number98 is offline   Reply With Quote
Old 02-20-2015, 02:55 PM   #32
ol_skool_chevy
ol_skool_chevy's Avatar
I'm diggin on the shock mounting outside the frame rails..
I love the designs....but Cost?.............a lot of guys along with myself have more of a concern with cost...
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 02-20-2015, 04:16 PM   #33
flashed
That was going to be my next question ,so whats the whole set up going to cost ?
Old 02-20-2015, 04:37 PM   #34
bterry97gt
I'm not going to ruin the thread but if you want to see the finished product they posted a pic on instagram...
bterry97gt is offline   Reply With Quote
Old 02-20-2015, 04:48 PM   #35
TexasLS1
TexasLS1's Avatar
Watchin'...
TexasLS1 is offline   Reply With Quote
Old 02-20-2015, 05:20 PM   #36
Roadster Shop
Here is the pricing:
1967-72 C10 REVO IFS Crossmember $4,495
Standard Features:
  • Modular 1 piece crossmember assembly
  • 1.25" upper and 1.625" lower TIG welded control arms
  • Eccentric style lower control arm mounts for fast, simple alignment adjustments
  • Front mounted power rack and pinion steering
  • Wilwood forged Pro Spindle and steering arm
  • Afco Single-adjustable coilovers with springs
  • Positive and negative bump stops to protect the suspension components
  • Grade 8 hardware through out
  • All components mounted in double shear for strength and durability
4-Bar Bolt-In Rear Suspension with Ford 9" Housing & Axles $3,975
Standard Features:
  • Large diameter parallel 4-bar rear suspension with panhard bar
  • Bolt-on C10 frame brackets with C-notch in frame
  • Afco Single adjustable coilovers with springs
  • Strange Engineering Ford 9" housing with 31 spline axles
  • All brackets welded to rear axle housing
Old 02-20-2015, 05:36 PM   #37
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Pretty slick, guys!
77' Chevy SB
Dropmembered Front and Rear
5.3/4l60e combo
JNJchev77 is offline   Reply With Quote
Old 02-20-2015, 06:01 PM   #38
slowcpe
slowcpe's Avatar
Saw the pic on Instagram and was hoping to see a better pic in this thread. Looks good!
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 02-20-2015, 06:21 PM   #39
Roadster Shop
We jumped the gun a bit with the Instagram posts! I'll start catching this one up and show some of the completed pics.
Old 02-20-2015, 06:34 PM   #40
Roadster Shop
For the wheels, we decided that the American Racing Salt Flats were the perfect fit for this truck. It has always been a wheel design that I've liked and the grey center was the right look against the matte green paint. Something that I wasn't aware of until putting this order through is that they will custom color match most wheels. (These would look pretty slick in a bronze/gold finish on a blue truck.)
The ever important wheel/tire sizes on this truck:
American Racing Salt Flats: Grey center, polished hoop
Michelin Pilot Super Sports
Front:
• 20x9.5” w/4.25” BS
• 265/35R20
Rear:
• 20x10 w/4” BS
• 285/35R20
These fit in the 100% stock wheel houses front adn rear. No modifications to the inner fenders or rear wheel tubs.
Old 02-20-2015, 06:37 PM   #41
Roadster Shop
A few teaser shots for the weekend!
Old 02-20-2015, 07:13 PM   #42
mistertrose
In!
mistertrose is offline   Reply With Quote
Old 02-20-2015, 11:05 PM   #43
Advanced Design
Advanced Design's Avatar
This looks to be a very well thought out package. One example is the integration of the front sway bar. Looking through the RS website on this product package ,I don't remember seeing a rear sway bar. Is there one?
Nice work on engineering out the intermediate shaft too.
Advanced Design is offline   Reply With Quote
Old 02-21-2015, 12:22 AM   #44
flashed
If I ever build another truck I would like to try this if the money tree ever produces leaves .
Old 02-21-2015, 12:49 PM   #45
crawdadfox
crawdadfox's Avatar
Location: New Orleans Louisiana.....a great place to visit but you wouldn't want to live here!!!
I tried to buy this truck...twice! Looks like it ended in the best possible hands!
Down......with the sickness!!
crawdadfox is offline   Reply With Quote
Old 02-21-2015, 02:59 PM   #46
mooseknuckles
mooseknuckles's Avatar
Holy crap!....how long was I gone?..lol. you're knockin this out pretty quick...looks awesome, great work!
mooseknuckles is offline   Reply With Quote
Old 02-24-2015, 11:57 AM   #47
Roadster Shop
A few completed beauty shots...
Cold weather testing!
Old 02-24-2015, 12:06 PM   #48
mooseknuckles
Very nice!
Old 02-24-2015, 09:01 PM   #49
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Very nice!
ChuckDriver is offline   Reply With Quote
Old 02-25-2015, 12:39 AM   #50
70 supersport
Sweet will all that fit a 2wd blazer?
70 supersport is offline   Reply With Quote
