Old 02-18-2015, 05:22 PM   #1
Roadster Shop
Roadster Shop's Avatar
Roadster Shop 69 REVO Patina build
Here is a 69 SWB build that we have been working on to debut a new bolt on REVO suspension line as well as be the R&D vehicle and general shop truck. We started with an incredibly nice truck, originally out of Georgia. Great patina and insanely solid! The only issue that we have found is a small dime sized rust spot in the back of the cab that is covered by the bed.
The plan is to keep the exterior and interior basically as is. We will upgrade the suspension with our new bolt-in REVO IFS crossmember and 4-bar rear. It will get a pretty healthy, injected SBC and 4L60 trans. Nothing too fancy, just a reliable, comfortable truck with a great stance that can be driven anywhere.
Roadster Shop is offline   Reply With Quote
Old 02-18-2015, 05:29 PM   #2
rustylew
Re: Roadster Shop 69 REVO Patina build
I'm in...
rustylew is offline   Reply With Quote
Old 02-18-2015, 05:30 PM   #3
rustylew
I'm in...
Old 02-18-2015, 05:52 PM   #4
c10Dream'n
c10Dream'n's Avatar
i'm coming along for the ride
c10Dream'n is offline   Reply With Quote
Old 02-18-2015, 07:22 PM   #5
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
I'm in!!
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 02-18-2015, 08:01 PM   #6
preacher anthony
Got 2 watch this one.
preacher anthony is offline   Reply With Quote
Old 02-18-2015, 08:13 PM   #7
mooseknuckles
mooseknuckles's Avatar
nice!...I'm in.
mooseknuckles is offline   Reply With Quote
Old 02-18-2015, 08:47 PM   #8
Rod Run
Rod Run's Avatar
Sweet
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 02-18-2015, 08:53 PM   #9
aod92
aod92's Avatar
I was in your shop once and what a nice place....These guys build some top notch stuff!
aod92 is offline   Reply With Quote
Old 02-18-2015, 08:57 PM   #10
flashed
Im in .
flashed is offline   Reply With Quote
Old 02-19-2015, 09:26 AM   #11
1stchevy
1stchevy's Avatar
Ready to see what you guys do to this one!
1stchevy is offline   Reply With Quote
Old 02-19-2015, 09:56 AM   #12
zicc1835
zicc1835's Avatar
got my interest
zicc1835 is offline   Reply With Quote
Old 02-19-2015, 10:40 AM   #13
Roadster Shop
Thanks for all of the support!
After a little design work, we were able to come up with the finished product...
Once the stock front crossmember is removed the new REVO crossmember will bolt directly in using existing frame rail holes. A few additional mounting holes are required to be drilled in the frame rails. If you are not familiar with the Roadster Shop REVO IFS, check out this link and read up on the "Overview" and "Standard Features" sections on this page. http://roadstershop.com/suspension/1967-72-c-10-revo/
(the green sections represent the stock frame rails)
On the rear, we designed all of the brackets to again bolt to the frame using existing holes. A few additional holes are required to be drilled in the rear rails as well. In order to get the rear of the truck sitting low, a C-notch needs to be cut into the rear rails above the axle. We provide a template to trace and cut out. The new rear bracket extends forward and back of the c-notch for added support. It also has a boxed in section the fits into the c-notch to again add strength. The coilovers are mounted outboard of the rails and set vertical to optimize the motion ratio. You can run a 10" wide wheel in the stock wheel tubs with this set up. If you want to slightly mini-tub the bed, an 11" wheel will fit with a 305 tire.
We have a few other pieces in the works for a center crossmember, exhaust ports, steering mounts, etc...
Old 02-19-2015, 11:07 AM   #14
Number98
Prestige Worldwide
Number98's Avatar
I will be following along on this one!
Number98 is offline   Reply With Quote
Old 02-19-2015, 01:24 PM   #15
Advanced Design
Advanced Design's Avatar
Me too. Looking forward to the install plus features and benefits information.
Advanced Design is offline   Reply With Quote
Old 02-19-2015, 01:35 PM   #16
Low Elco
In!
Low Elco is offline   Reply With Quote
Old 02-19-2015, 03:14 PM   #17
Roadster Shop
The completed front suspension
Old 02-19-2015, 03:33 PM   #18
Hart_Rod
Hart_Rod's Avatar
Nice setup.
Hart_Rod is online now   Reply With Quote
Old 02-19-2015, 03:56 PM   #19
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Watching. I would have gladly provided the truck. I have one very similar.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 02-19-2015, 04:10 PM   #20
Roadster Shop
The completed rear suspension (with a few pieces of 1"x1" to prop it up for the pictures)
Old 02-19-2015, 07:09 PM   #21
SCOTI
SCOTI's Avatar
How is the alignment adjusted in this configuration?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-19-2015, 10:32 PM   #22
Advanced Design
The lower control arms have eccentrics to adjust camber and caster at the bushing end.
The link has a good diagram of the eccentric action.
Old 02-19-2015, 11:18 PM   #23
bterry97gt
cant wait to see this one
bterry97gt is offline   Reply With Quote
Old 02-19-2015, 11:37 PM   #24
Graham57a
Graham57a's Avatar
Subscribed
Graham57a is offline   Reply With Quote
Old 02-20-2015, 10:33 AM   #25
Roadster Shop
Correct. There are eccentrics on the lower control arm that will move the suspension through the full range of alignment. This eliminates the need to take off and thread/un-thread rod ends to do an alignment. With this set up, you can get +1.45 to -2.78 degrees of camber and +3 to +6 degrees of caster.
Here is a clip to illustrate the range of motion.
