Old 09-23-2015, 11:01 AM   #26
ETraugott
Re: Eric's 52' 1ton 4x4
Got a little done last night. I swapped the dually rear end in to place. Started labeling engine harness and removing parts from cab. Looks like a little more rust than i thought but still not too bad. I will have to repair or replace the upper cowl vent area, the lower lip of dash where key goes, ( rusted from cowl vent leaking) and the pass side floor pan. Im going to try and get the cab in place and mounted soon.
ETraugott is offline   Reply With Quote
Old 10-06-2015, 12:12 AM   #27
ETraugott
Got some templates made for the cab mounts. Maybe i can get the cab on and front clip mocked up by the end of the week.
52 Chevy 6400, 1 ton dually 4x4 350 vortec NV4500 315/75-16 tires
http://67-72chevytrucks.com/vboard/s...d.php?t=661795
94 Chevy K1500 4.3 4l60e (The Wifes)
Old 10-06-2015, 01:39 AM   #28
Purcell69
Keep up the good work! I reused parts of my late model cab mounts in my build. If all goes well later today, I will be adding in the gussets to the rear mounts.
-Joe
My '57 "Ram-rolet" not a NAPCO build: http://67-72chevytrucks.com/vboard/s...d.php?t=589917
Purcell69 is offline   Reply With Quote
Old 10-06-2015, 09:15 AM   #29
ETraugott
Yes im reusing the new model cab mounts. Im making all my mounts the same height because im planning a square tubing sub floor when i change floor pan.
Old 10-06-2015, 12:09 PM   #30
big_moss
big_moss's Avatar
that's dope man
big_moss is offline   Reply With Quote
Old 10-16-2015, 03:46 PM   #31
ETraugott
Got some mounts fabed up finally. Trying to get a few hour in here and there to stay interested.
Old 10-16-2015, 03:49 PM   #32
ETraugott
Tacking together
Old 10-16-2015, 03:52 PM   #33
ETraugott
Still need welded up. Looks like they will work. They are built out of 1/4 in plate. A little thicker than needed bu material was free.
Old 10-16-2015, 04:25 PM   #34
Purcell69
Looks good! And, you can't go wrong with the thicker material. Solid is definitely a good thing when it comes to mounting the body.
-Joe
Old 10-16-2015, 04:45 PM   #35
ETraugott
Thanks. I tend to have a problem with overkill.....
My goal is to try and have the cab mounted and front clip mocked up this weekend. We shall see. Seems like somthing always comes up.
Old 10-19-2015, 10:51 AM   #36
ETraugott
Body on and front clip mocked up. Have to get creative with radiator or move engine back 5-6 in.
Old 10-19-2015, 10:53 AM   #37
ETraugott
Clearence issues.
Old 10-19-2015, 11:00 AM   #38
burger
Originally Posted by ETraugott View Post
Clearence issues.
Have you thought about using an early Mustang radiator with an electric fan? Here's a link to a combo on eBay.
41 chevy
70 skylark
85 c4
dumb house that always needs work
4 stall detached car hole
burger is offline   Reply With Quote
Old 10-19-2015, 11:01 AM   #39
ETraugott
Looking like somthing
Old 10-19-2015, 11:04 AM   #40
ETraugott
Thanks will take some measurements tonight.
Old 10-19-2015, 11:09 AM   #41
burger
I used that radiator in a 54 truck with only minor metal work being required.
41 chevy
70 skylark
85 c4
Old 10-30-2015, 11:57 PM   #42
Trekster
Trekster's Avatar
Nice truck. Keep up the good work.
Trekster is offline   Reply With Quote
Old 10-31-2015, 05:10 PM   #43
Purcell69
Eric, how much room is there at the back of the motor? Is it possible to move it back a little, maybe an inch or two, without having to tear into the firewall? If you switch over to all electric fans, you can lose the clutch fan on the front of your engine and gain 3". This would leave you room for the radiator and a pusher fan or two on the front. You could get a two stage electric like Ford used on the Crown Vic's, Taurus, etc. Those things move a LOT of air in the "high" speed mode, somewhere around 4000 CFM if I remember correctly. They are very popular with the Jeep crawler guys. Low speed is for general cooling and high comes in to play via a thermostat switch, usually when the AC is on.
-Joe
Old 11-01-2015, 08:39 AM   #44
Chance48
Eric, love the 4wd approach. I've got something in my mind like that for the future. Gotta get my first build off the ground first though, haha.
Good luck, keep us posted and pics coming.
Chance48 is offline   Reply With Quote
Old 11-01-2015, 01:44 PM   #45
ETraugott
With the body sitting up high i can prob move the motor back 5-6 inches without cutting firewall. Ive decided i will slide the motor back. Its going to help with the inner fender clearence also.
Old 11-01-2015, 05:35 PM   #46
Purcell69
Eric, I ended up doing the same thing. It wasn't a big deal to move the motor mounts now and get everything situated where it needs to be. It was a lot less trouble than having to go to electric fans for everything. Don't get me wrong, an electric fan has its place, but if that is your only cooling and it goes out, you could be looking at a motor if it doesn't get caught in time.
Be sure to leave yourself about 2" of gap between the fan clutch hub and your radiator, that way the fan will move air through the radiator and out the shroud.
-Joe
Old 11-21-2015, 12:53 AM   #47
ETraugott
Havent got anything done but i did get a new to me grille.
Old 06-30-2016, 04:16 PM   #48
ETraugott
Havent worked on on the truck latkey but i have been working on a place to work on it. Still not finished but its a 60x44.
Old 06-30-2016, 05:46 PM   #49
Purcell69
Mmmmmm! Garage envy.
-Joe
