Old 03-31-2015, 09:55 PM   #26
NTIMID8R
NTIMID8R's Avatar
Re: Is this motor a goner?
Glad you got it fixed. As Enaberif said, may want to put fresh oil in and run it a few days and change it again to be safe.
Yesterday is history, tomorrow is a mystery, today is a gift, that's why it's called "the present".
1971 Sierra Grande LWB, 350/TH350, Factory Air Lots, of future mods planned!!
NTIMID8R is offline   Reply With Quote
Old 04-01-2015, 12:40 AM   #27
swamp rat
swamp rat's Avatar
Now the real question is what caused it to stick in the first place? using unleaded alchohol ladin gas with the stock guides? did the cylinder get hot? carbon buildup in the valve stem in the port?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 04-01-2015, 06:54 AM   #28
NTIMID8R
NTIMID8R's Avatar
Quaker State oil
Jus sayin --- Look at the crud on # 1 rocker arm and spring.
Old 04-01-2015, 08:33 AM   #29
enaberif
Crappy oil and crappy gas and letting it go without proper maintenance.
enaberif is offline   Reply With Quote
Old 04-01-2015, 08:54 AM   #30
67 chevelle
67 chevelle's Avatar
Fill her up with some req 90 , or better yet 100 low lead , and some seafoam with it , should take some of that carbon out of the engine , synthetic oil may help also "they" say sythetic is better for all engines
You have some serious grundge in that engine
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 04-01-2015, 09:59 AM   #31
67 cst swb
67 cst swb's Avatar
If it were me. For the cost of a few gaskets, I would pull that head off and do serious cleaning.
If you are apposed to that, then at least buy some SeaFoam and follow the instructions on the can for pouring into the carb. You will be surprised how well that works.
Also... WD40 is not the best thing to use. Just as the name implies; Water Displacment 40th try. All it does is displaces water, it might soak into something, but not really doing what your thinking it does.
Go with a penetrating oil.
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 04-01-2015, 10:06 AM   #32
enaberif
On a old engine I wouldn't use synthetic.. I would run a good 10w40 or 15w40 oil though.
Old 04-01-2015, 10:33 AM   #33
Coley
Coley's Avatar
.....I'll go 'ditto' on the Seafoam treatment.
Just be sure that you have a nice open space when you fire it back up cause there will be a lot of 'burn-off' for 15-20 minutes. After that you'll notice how much it runs.
All good
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 04-01-2015, 12:05 PM   #34
WIDESIDE72
WIDESIDE72's Avatar
Originally Posted by Norgermish View Post
Excellent point about the gas. Also to allay bent valve thoughts I don't think there is ever any interference between valve heads and pistons on these engines. Pretty sure the open valve does not extend past the combustion chamber. Now when the intake was off and a not or bolt may have squirrled into the port, that could be a problem. Bad gas makes a lacquer and it creeps up the valve stem and will definitely hang a valve
x2
WIDESIDE72 is offline   Reply With Quote
Old 04-01-2015, 09:14 PM   #35
GRX
GRX's Avatar
Cool deal. Glad you got it running. The reason behind the stuck valve was obvious. Seen it many many times. Be sure all the old fuel is flushed out and you should be good to go.
Originally Posted by 65standard View Post
junkyard rescue truck
Yes, it has about 45 minutes run time with orange rusty looking gas. I have since pulled the tank and cleaned it along with the lines and carb.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 04-04-2015, 08:44 PM   #36
snipescastle2
snipescastle2's Avatar
Talking Re: Is this motor a goner?
anytime I ever had a lifter start ticking on me, I added half a quart of atf to the oil. the detergent in the atf helps break up carbon and varnish and stopped the ticking noise, then I just did another oil/filter change. I have never used seafoam, can't vouch for it. but atf sure worked for me. I would get your fuel tank boiled out to remove any varnish/deposits that may still be in there. One note, when you see a Gasloline tanker filling up the tanks at your favorite gas station, keep driving until you get to a station where there isn't a tanker filling the tanks, reason being, once they start filling the tanks, it stirs up all the crap and debris on the bottom of their tanks, the pumps have a fuel filter on them, but I wouldn't trust that.....just my opinion.
HTH,
Ben Smith
snipescastle2 is offline   Reply With Quote
Old 04-05-2015, 09:12 AM   #37
65standard
65standard's Avatar
Okay, I got the motor back together with new gas, oil, and spark plugs. It fires right up and idles pretty good now. Only issue I have now is a small pop through the exhaust about every 30 to 40 seconds. The carb works great with no stumbles or hesitations.
I'm guessing the points or wires are causing this pop through the tailpipe.
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
