Is this motor a goner?
I have been struggling trying to get the 250 engine in my junkyard rescue truck running right. Idle is the biggest issue. I replaced the plugs, intake gasket, and rebuilt the carb. It still won't low idle.
I did a vacuum test and it only has 11 inches of vacuum. Sounds like a vacuum leak, but I can't find one. Then I do a compression test. Cylinder 1-6 are 155, 155, 0, 160, 165, and 155. Then I pulled the valve cover and found the intake valve stuck on the #3 cylinder. This looks fatal to me.
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
Re: Is this motor a goner?
Squirt some penetrant around the stem and wack the valve tip with a hammer. Put a block of wood on the tip.
Agreed but somewhat gently on the hammer and graduate from there.
I'd use a soft dead blow hammer on the top of the valve of you have it, definantly use a block of wood with a steel hammer, try and get the valve to move free. There is a good posibility the piston may have struck the valve and ether bent or broke it. This is when a goos micro camara can tell a lot going in thru the soark plug hole.
I'd alsoull the lifter inspection cover, pull the pushrood and see if its bent, see if the lifter is frose up on the lifter bore or if it moves, if it is you need to try and remove it, once out see if it and the bore are galled up, try and clean them up.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
I'll try to spray it with oil and break it loose. But when I see a valve stuck open, I'm thinking it is bent because the motor ate a bolt or something down the carb.
I'd be concerned using a block of wood to hit against. if its soft wood like pine you're liable to sink the valve stem into the wood and then when the wood makes contact with the retainer you're likely to pop the keepers out and the spring will pop out. Be carful you don't hit on the retainer, thats all. Worst case is you'll have to pull the head and get it cleaned up with valve job. Unusual for the intake to get gummed up.
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
![]() Join Date: Mar 2003
Is it stuck or is the spring broken
"""I'm thinking it is bent because the motor ate a bolt or something down the carb.""" do you think thats what might have happened?
Well that is my first thought since I don't know the history of this truck. But it may be just stuck because it sat in the junkyard for 18 months before I rescued it.
Was the engine run with bad gas? Very bad gas? Smells like Turpentine. I have seen *many* intake valves stuck in the guide because of sticky varnish from bad gas. Like geezer said try spraying some solvent around the guide. Denatured alcohol works well for that. Then strike it with a plastic hammer.
1969 c-10 Step Side Long Bed. I-6 250cid = ![]() |
Yes, it has about 45 minutes run time with orange rusty looking gas. I have since pulled the tank and cleaned it along with the lines and carb.
Hmmm ... I'd lay money down that is what caused it. Especially since it is one of the center cylinders. Hopefully the piston did not smack the valve.
One time a guy dropped off an old Dodge 225 slant 6 engine to be rebuilt. Long story short ... after bringing the head back three times with stuck intake valves, and complaining we made the guides too tight, he finally flushed out the fuel system. Problem solved. The smell & varnish on the valve stems told me instantly what happened but he was too stubborn to listen.
#13 |
Thanks for the tips. I will try to unstick the valve. I'm hoping to save it since I just put a new exhaust on it. And I finally got the exhaust to stop smoking so bad. The thing is the motor runs good now above 1500. Below that it sneezes through the carb.
#14 |
Instead of tapping it down what about a gentle pry upward after spraying some carb cleaner on that valve to see if you can "degunk" it? That would be after the inspection cover is removed to make sure the lifter isn't stuck in the bore or you have a bent pushrod. I would spray carb cleaner on that one valve then pry up a little then push down a little about the same amount you get it to move up. If you do that a couple times it will move a little more each time you make it move. Jim
#15 | |
#16 |
![]() Join Date: Feb 2015
Remove the spark plug for that cylinder and use an air blower with a rubber tip and see if it will move back up with a little air pressure. Better than prying up on it and risk bending it if it's not bent yet. Like others said, may just be gunked up. Also works if you need to change a valve spring.
Tim Yesterday is history, tomorrow is a mystery, today is a gift, that's why it's called "the present". 1971 ![]() Last edited by NTIMID8R; 03-30-2015 at 11:39 PM. |
#17 |
How about rebuilding it so it's correct and will run good.
1957 CHEVY 1/2 TON SHORT BED 1940 FORD 1/2 TON SHORT BED |
#18 |
![]() Join Date: Oct 2011
I also agree with the possible broken valve spring theory. I recently went through this issue on a cylinder that went to '0' psi compression.
Look very closely at the spring and run your fingers around all the coils to either identify that possibility....or eliminate it. Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
#19 |
I'll mess with it tonight. Yesterday's fun factor was at zero too. I feel better today with new hope to save it. I just want to thank everyone with all of their advise.
#20 |
![]() Join Date: Dec 2012
Yikes !!!
That doesn't look good
1971 GMC Sierra 1959 GMC 100 |
#21 | |
You only need a few psi for this to actually function. |
#22 |
Okay, good news. I got the valve to pop up after 15 minutes by using compressed in the cylinder, carb cleaner, and gentle taps. Then I sprayed some WD40 around the stem and put the pushrod ans rocker back on. Did another compression test on that cylinder and it is 150psi.
This tells me the valve and piston are not damaged. Now, what is the correct procedure to do to prevent the others from sticking. I'm also worried that I might have flushed out the rings on that cylinder from the carb cleaner. Thanks again for all of the great advise everyone, much appreciated.
#23 | |
To make sure no others stick I would do the air in the cylinders for the rest just to make sure nothing is stuck. Then clean up what you can top side with a good stiff brush and some cleaner then some fresh gas and oil and just run it. The biggest thing you want to be careful of is any large chunks of carbon or debris. |
#24 | |
just like that old Johnny Cash song. "One piece at a time and I am go na make an old C10 mine a look at all your faces when I drive through your town" |
#25 |
Nah just run fresh gas through the engine and let it burn all the crap off itself. You may have to do a oil change or two right away so be prepared for that.
