Old 04-20-2015, 03:26 PM   #26
pimpston65
pimpston65's Avatar
Originally Posted by 60-66 View Post
Run a level across the frame rails , then level the engine off the carb flange to get your location right before welding , just a thought
no welding needed, just need to cut down my mount 2"
pimpston65 is offline   Reply With Quote
Old 04-20-2015, 03:33 PM   #27
pimpston65
pimpston65's Avatar
Re: What the €¥#%
plus the engine is sitting level with just the one mount
Old 04-26-2015, 12:28 PM   #28
pimpston65
pimpston65's Avatar
Re: What the €¥#%
now my build can move forward!!! i cut the frame side mount down 2" and bent the ends in to make new flanges that mount to the frame. bolted it to the rubber mount, marked hole placement, drilled the holes on the frame. bolted up and BAM, its all centered and lever; perfect... BIG shout out to Jon(60-66) for the pics...
Old 04-26-2015, 12:29 PM   #29
pimpston65
pimpston65's Avatar
Re: What the €¥#%
all lined up...
Old 04-26-2015, 12:30 PM   #30
pimpston65
pimpston65's Avatar
Re: What the €¥#%
centered in the frame rails...
