04-19-2015, 05:51 PM | #1 |
What the €¥#%
so mocking up my 292, i had to remove the passenger side frame mount cuz this beast came with a 250. no problem there, my issues is now that its moved only the drivers side fits perfect. the passenger side seems like the mount in too far out about 2". i have a plan to make it fit by cutting the back of the mount 2" and while keeping enough material to make the wings that mount to to frame. any ideas that have worked is NEEDED!!!
04-19-2015, 05:56 PM | #2 |
Re: What the €¥#%
driver side all bolted up...
04-19-2015, 05:57 PM | #3 |
Re: What the €¥#%
sitting purrty, just need the other side to bolt up!!!
04-19-2015, 06:00 PM | #4 |
Re: What the €¥#%
this is with the engine sitting how it should, no tension on the hoist chain!!!
04-19-2015, 06:47 PM | #5 |
1961 crewcab
Re: What the €¥#%
this might help?
http://67-72chevytrucks.com/vboard/s...d.php?t=552399 and areotruk has some as well.... http://67-72chevytrucks.com/vboard/s...d.php?t=397681
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
04-19-2015, 07:21 PM | #6 | |
Re: What the €¥#%
04-19-2015, 07:24 PM | #7 |
Re: What the €¥#%
Doesn't the 292 use a special mount/bracket the 250 doesn't use? I believe it does.
04-19-2015, 07:31 PM | #8 |
Re: What the €¥#%
here's a rough idea, ima make the exact piece outta cardboard to make sure!!!
04-19-2015, 07:38 PM | #9 |
Re: What the €¥#%
04-19-2015, 10:17 PM | #10 |
Re: What the €¥#%
The frame bracket that you removed , did you just move it to the new location ? Or did you find a 4x4 292 frame bracket for the pass side ?
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
04-19-2015, 10:25 PM | #11 |
Re: What the €¥#%
04-19-2015, 10:27 PM | #12 |
Re: What the €¥#%
pic 4 shows the passenger side, its like its too for out and won't allow the block to move down any further. thats why i want to modify the frame side bracket to pull it back 2"...
04-19-2015, 10:36 PM | #13 |
Re: What the €¥#%
That's what I'm getting at . The one riveted to the frame on the passenger side is 4x4 292 only and in a different location as you already know.
04-19-2015, 10:50 PM | #14 |
Re: What the €¥#%
04-19-2015, 10:54 PM | #15 |
Re: What the €¥#%
If you need a picture or measurement my 4x4 panel is easy to get at
04-19-2015, 10:54 PM | #16 |
Re: What the €¥#%
heres a pic looking down, you can see the frame side mount lines up. its just too close to the engine!!!
04-19-2015, 10:56 PM | #17 |
Re: What the €¥#%
04-19-2015, 10:57 PM | #18 |
Re: What the €¥#%
04-19-2015, 11:02 PM | #19 |
Re: What the €¥#%
04-19-2015, 11:02 PM | #20 |
Re: What the €¥#%
04-19-2015, 11:06 PM | #21 |
Re: What the €¥#%
3 different mounts!!!!!!!!!!!!!!, i feeling like calling GM from 1966 and give em an ear full....
04-20-2015, 10:53 AM | #22 | |
Re: What the €¥#%
3 9/16 to bottom lip. If the engine were out I could get better measurements . Might contact padreseg , he had one for Aerotruk .
04-20-2015, 11:05 AM | #23 |
Re: What the €¥#%
thats makes all the sense in the world, so i asked the right person!!! my bracket was meant for a 250 and wont fit a 292 unless it came with it!!! thks i will modify mine...
04-20-2015, 11:07 AM | #24 |
Re: What the €¥#%
the notch is at about 3-1/4" and your mark is about 5-1/4" so my estimate was right to take out 2"...
04-20-2015, 01:00 PM | #25 |
Re: What the €¥#%
Run a level across the frame rails , then level the engine off the carb flange to get your location right before welding , just a thought
