Old 06-02-2015, 04:02 PM   #26
racer357
Re: Danforth Cross Member Install
Used ones run from 225 -600.00. I am Indiana, so they are plentiful.
Latemodels and Modifieds are everywhere here
racer357 is offline   Reply With Quote
Old 06-04-2015, 01:34 PM   #27
mikec4193
mikec4193's Avatar
Hey Coach
I am following along on this build for sure....I love my daily driver S10 truck...not sure if I am gonna be able to handle the antique feel of leaf springs and a straight front axle on my current "Howard Knapp" farm truck I am rebuilding...I love the looks of the stock stuff but darn...I have driven straight axle stuff before and boy oh boy...they don't ride or turn anything alike...I think you are gonna love these changes for sure...
You seem to have a handle on all this stuff...good luck and may the money fairy's dropped tons of cash in your wallet so you can finish these upgrades in a timely manor...
MikeC
mikec4193 is offline   Reply With Quote
Old 06-04-2015, 02:31 PM   #28
dwcsr
Hollister Road Co.
dwcsr's Avatar
Originally Posted by Coach529 View Post
That is good info to know. Do you have a resource that tells you the specs of the rack and pinion?
I am pulling parts from a 1995 Thunderbird (same as 1995 Mark Series) and have access to that rack.
According to Cardone the Tbird 22-203A travel is 5.3" and
Mark VIII #22-215 is 5.95" so it should get me lock to lock, I'm just about !/2" short of lock to lock now.
This is what I just ordered
1994 LINCOLN MARK VIII 4.6L V8 #22-215 48" oal 5.95" travel
FORD THUNDERBIRD (1989 - 1997)
LINCOLN MARK VIII (1994 - 1996)
MERCURY COUGAR (1989 - 1997)
This is what I currently have on it now.
FORD LTD (1984 - 1986) #22-203A 48" oal 5.3" travel
FORD MUSTANG (1985 - 1993)
FORD THUNDERBIRD (1984 - 1988)
LINCOLN CONTINENTAL (1985 - 1987)
LINCOLN MARK VII (1984 - 1992)
MERCURY CAPRI (1985 - 1986)
MERCURY COUGAR (1985 - 1988)
MERCURY MARQUIS (1985 - 1986)
I believe these all mount the same
this may also be helpful when connecting the hoses
http://my.cardone.com/techdocs/PT%2022-0007.pdf
dwcsr is offline   Reply With Quote
Old 06-04-2015, 10:43 PM   #29
Coach529
Coach529's Avatar
Awesome......thanks for the info!!
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 06-04-2015, 11:34 PM   #30
Coach529
Coach529's Avatar
Originally Posted by mikec4193 View Post
Hey Coach
MikeC
Thank you very much!!
1949 Chevy 3600
Old 06-05-2015, 04:11 PM   #31
dwcsr
Hollister Road Co.
dwcsr's Avatar
It is exactly a 6" throw which gives me the 3/8 on each side that its short of hitting the stops. It is long so I think I need to either trim off some tie rod or change them to a shorter one or possibly use the ones off the Tbird if they fit.
I'll take some pictures tomorrow when it on and we test it out
Old 06-06-2015, 06:45 PM   #32
dwcsr
Hollister Road Co.
dwcsr's Avatar
We have it in and its a whole lot better steering than it was. It is about an 1/8" from the stops. We did have to use Tbrid inner tie rods EV117 and cut them about 3/4' on each end. The rod end were 7" long from a 93 corvette re-tapped to fit the tie rods. On a very tight turn it does scrub a bit but its only when its up against the stop. we do need to raise it 1.5".
Old 06-06-2015, 06:56 PM   #33
dwcsr
Hollister Road Co.
dwcsr's Avatar
One side note about the rack fittings. I had to turn the ends that go into the rack down a bit so they didn't bottom out and let the oring seat. I used a Borgeson gm pump to ford rack hose kit. It didn't take much only about .125 off. You could do the same with a little thicker washer than they gave me.
Old 06-08-2015, 10:03 AM   #34
Coach529
Coach529's Avatar
Thanks a ton for the info. I plan on pulling the rack and pinion from the Thunderbird when I pull the IRS rear end.
The plan is coming together........
1949 Chevy 3600
Old 07-22-2015, 03:30 PM   #35
Coach529
Coach529's Avatar
OK, so I found a S-10 donor at a local scrap yard. Hope to head out there in the near future.
Any special tools required to remove the A arms and associated stuff?
1949 Chevy 3600
Old 07-22-2015, 04:02 PM   #36
dwcsr
Hollister Road Co.
dwcsr's Avatar
save the a frame bolts, There were hard to find new in the right size.
Old 09-25-2015, 03:39 PM   #37
Coach529
Coach529's Avatar
Finally got around to spending some time in the junkyard and pulling parts from a donor.
2 hours and $30 later I have all the front suspension parts I need.
1949 Chevy 3600
Old 09-25-2015, 06:20 PM   #38
Coach529
Coach529's Avatar
Beyond excited about my score today. Bearings, Brake Pads, Ball Joints......Bushings all look great.
1949 Chevy 3600
Old 09-25-2015, 09:37 PM   #39
dwcsr
Hollister Road Co.
dwcsr's Avatar
did you get all the bolts for the A frames?
Old 09-25-2015, 10:03 PM   #40
Coach529
Coach529's Avatar
Yes for the lowers. I had to sacrifice the upper mount bolts.
1949 Chevy 3600
Old 10-01-2015, 11:58 PM   #41
azcornman
DWSR, I have installed a Tbird/Cougar rack on my 52 Burb with danforth member. Used large grade 8 bolts welded into the crossmember, can use flat washers to adjust in/out up/down. Notched the frame to have nice clearance for imput shaft. NOW I LEARN THERE IS A BETTER RACK!?! I haven't shortened the rods yet, going with Impala ends to mate to S10 2" drop spindles. Is the Lincoln going to slide right on with the same angle of input shaft? I can still exchange with the jy, they're good guys to work with that way.
Appreciate the info!
AZCORNMAN
azcornman is offline   Reply With Quote
Old 10-20-2015, 12:49 PM   #42
Coach529
Coach529's Avatar
A couple other install pictures I found online.
1949 Chevy 3600
Old 10-20-2015, 12:50 PM   #43
Coach529
Coach529's Avatar
AZCORNMAN
Do you have any pictures of your install?
1949 Chevy 3600
Old 12-09-2015, 10:06 AM   #44
Coach529
Coach529's Avatar
Truck is being stripped down and going to FINALLY start this project.
Got all my air components ordered last night from Thor Bros.
Slam Specialties SS-7 bags
Dual Viair 444 compressors
1949 Chevy 3600
Old 12-09-2015, 02:55 PM   #45
Donnie Lee
Hey Coach, previous page post #4, do you recall where the photo with the tubular a arms came from, would like to get info on the brand.
Donnie Lee is offline   Reply With Quote
Old 12-09-2015, 04:43 PM   #46
Coach529
Coach529's Avatar
Sorry, I do not remember where I found that one......
1949 Chevy 3600
Old 12-12-2015, 10:45 PM   #47
Coach529
Coach529's Avatar
Had a pretty good afternoon. Motor is out and I got a start on stripping the frame of unnecessary stuff in prep for the install.
1949 Chevy 3600
Old 12-14-2015, 06:55 PM   #48
Fountain
Dave, In your build thread you stated that the v6 spring was too stiff, what spring did you end up using?
Fountain is offline   Reply With Quote
Old 12-14-2015, 07:05 PM   #49
dwcsr
Hollister Road Co.
dwcsr's Avatar
MOOG 5658 We cut a half coil or a full coil out on the final set. but we wanted a particular look so a half would for most rides. and they will start to settle rather quickly
Old 12-16-2015, 01:09 PM   #50
Luther Grimace
Luther Grimace's Avatar
Subscribed
1955.2 Chevy 3100, 6bt, Getrag G360 5-speed, NP205, Dana 60/70 - http://67-72chevytrucks.com/vboard/s...d.php?t=536540
1992 Chevy K1500 Silverado ECSB
1965 "Crewcab" Chevelle 300 Deluxe - soon to be LBZ Duramax/4L85E powered
Luther Grimace is offline   Reply With Quote
