Old 05-19-2015, 07:58 PM   #26
richards72chevy
richards72chevy's Avatar
Re: Building an electrolytic tank to derust.
Good info to know.
richards72chevy is offline   Reply With Quote
Old 05-19-2015, 08:36 PM   #27
In The Ten Ring
Well maybe I should have tried Fritz's idea after all!
After 2.5 hours of running, I removed a lot of rust but there is still plenty to go. I did get rid of most of the paint. *It may have flash rusted after clean up though.
I'll go again tomorrow and see what happens, I'll go for 12 hours.
In The Ten Ring is offline   Reply With Quote
Old 05-20-2015, 10:48 AM   #28
Davidf
I recommend that any acid, other than phosphoric, NOT be used. Read up on the subject and you may learn that acids are problematic in the long run. Media blasting is by far the most efficient method in removing rust.
Davidf is offline   Reply With Quote
Old 05-20-2015, 11:12 AM   #29
In The Ten Ring
I am running the process again today, this time for 10 hours, on just one bracket.
Davidf, I do have an aversion to using HCl for anything, other than eating. A media blaster is something I'll need to buy/build if I am going to keep up in this hobby.
Old 05-20-2015, 12:54 PM   #30
In The Ten Ring
I just checked and wow, it looks like it's really doing well this time! I guess because I am only doing one bracket instead of two.
Now, if I use this method on my rockers and fender, what should I do for priming? I am going to have these panels painted at a body shop. I imagine they'll flash rush immediately, so what do I do?
Old 05-20-2015, 03:54 PM   #31
swamp rat
swamp rat's Avatar
I you can share specific links i'm all ears, thanks
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 05-20-2015, 07:01 PM   #32
Fitz
Don't worry. He can't because there are none. Here's before, during and after 20 minutes in a 3 parts water, one part HCl bath.
Balanced valence equation is: FeO + 2 HCLO4 = Fe(CLO4)2 + H2O
No fumes, no poisons and no rust problem! The Fe(CLO4)2 precipitates out as an inert solid leaving behind a mildly more diluted solution of HCl and....Water!
Fitz is offline   Reply With Quote
Old 05-20-2015, 07:15 PM   #33
In The Ten Ring
Wow Fitz, that's great man. Thanks for the pics and the equation, along with detailing the results. You may have won me over. :-)
Here is what I have after 8 hours of running. Top bracket got the treatment, bottom did not.
Old 05-20-2015, 07:32 PM   #34
Fitz
Still some rust on the top one. Wash any oil off with acetone and you might have gotten better results. None of these methods will work through even an extremely thin coating of oil. Antifreeze has a wierd chemical that fights off surfactants as well so it could also slow the process.
Old 05-20-2015, 07:36 PM   #35
In The Ten Ring
Acetone first eh? I'll give that a go if I do this again.
Thanks.
Old 05-21-2015, 08:53 PM   #36
In The Ten Ring
I ran electrolysis again today and even the 40 degree temps, it was effective. I have found, that when I combine it with an evaporust soak, it really cleans the metal. Check out the pic.
This bracket was run in the tank for about 10 hours and then soaked in Evaporust. I did not use any other derusting treatment (like a wire brush). Within minutes of the Evaporust soak, it looked like it does now.
