Building an electrolytic tank to derust.
I've been getting by with a wire wheel, Evaporust, and Krud Kutter (phosphoric acid) but parts that need derusting are getting bigger and yet more awkward to hit with my wire brush drill attachment. It's time to awaken my inner Tesla.
I'll keep you guys posted on how this goes. I'll put it together tomorrow and get pics. |
Re: Building an electrolytic tank to derust.
It worked well for me about 8 yrs ago while cleaning tractor parts. takes a while to clean so have patience, and be carful whth sparks after its been cooking for a while, gasses form so do it in a ventalated area. I removed one of the leeds from the anode and it sparked and made a loud pop like a 22 short going off. scared me, LOL..
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
you need one of the those big poly tanks/totes they keep oil in, or one of those tanks Farmers use to haul water, etc.....
Ben ![]() |
Thanks guys. I was going to do it in my kitchen and smoke afterwards. LOL
I'll do it outside, on the back porch. Yes, I plan to unplug the battery charger before touching the leads. What about a kiddie pool for rockers and fenders? |
#5 | |
A kiddie pool will work. Just remember this is mostly a "line of sight" process therefore multiple Anodes may be required for large & irregular shaped parts.
From what I remember something like a fender would take 24 hours, depending on amount of rust. As stated multiple Anodes will be required for large & irregular shaped parts.
Where would I get steel wire to suspend the parts from into the water?
I have plenty of copper wire but none of the instructions I have come across suggest using that. |
I use coat hanger wire.
#10 | |
I'm just glad to be here!
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
Tractor supply?
I called TS and they have galvanized wire, is that OK? Thanks guys. I figured that coat hanger wire would work but wasn't sure about the coating. |
#12 | |
![]() Join Date: Sep 2010
One good source for instructions on electrolysis bath is The Garage Journal. Search their forums for "electrolysis" and you'll find lots of info. http://www.garagejournal.com/forum/
1971 GMC K1500 Longbed Fleet 1989 Chevy K1500 Shortbed Sport Side |
#13 |
I sand the coating off the coat hanger. Good call on the galvanized wire. Was about to mention that. Not advisable to contaminate your solution with Zinc. Stainless and copper are not recommended either.
#14 |
Thanks for the warning guys! You got to me just in time.
I'll pick up some rebar tie wire tomorrow at Lowe's. As for the rest of the tank, I can put it together tonight. |
#15 |
post pics of your progress if you can
1967custom |
#16 |
The wire used for tieing Re-Bar is what you want, comes in a small 4-5" roll about 1" thick it should be avalable anyplace that sells the same, it also makes great shop wire and can be used in gas welding too.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#17 | |
#18 |
X2
#19 |
Oh I probably should use hydrochloric acid but I have wanted to do electrolysis for a long time. I just wired up my first "tank" (a bucket) but I left my camera out in the car. I'll get pics when I run the process tomorrow.
#20 |
Here's the one I built:
Half a 55 gal drum: ![]() I made a cage out of rebar. I thought I heard to use copper wire, so I did: ![]() Add a little bit of magic elixir: ![]() (the instructions I was following said something about so many Tspoons per gallon, yada yada yada. Since I didn't really know how many gallons I had, I just used half a box) My work is hanging from a shovel handle. One copper wire from the rebar, the other to the work: ![]() Before: ![]() And after about 2 or 3 hours: ![]() Yeah, it works!
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
#21 |
Wow, that's neat. I'll get pics for you guys tomorrow.
I think for the rockers I'll use this big storage tote I found (yes, literally "found") and a kiddie pool for the front fender. |
#22 |
Muratic acid has such nasty fumes i had to resort to buying a 3M resperator good for acid vapors, but it kicks butt on rust removal
#23 |
Re: Building an electrolytic tank to derust. PICS!
Here are the pics:
I won't earn a Journeyman's rating with this wire job but it works. ![]() Brackets before: ![]() Whole set up: ![]() Set for 12 Volts at trickle charge; the process began immediately. ![]() Last edited by In The Ten Ring; 05-19-2015 at 04:31 PM. |
#24 |
Then it's an 'experiment' and not the solution to a rust removal problem!
#25 |
