#26 |
Re: I6 intake, carb, header upgrades? Worth it?
Just watched the video from the link. So cool! That's more hp than the 350s had.
#27 |
Old Duffer
![]() Join Date: Mar 2003
Granted, the 250 and 292 are different engines, but the principles are the same in both I6's. Another way to look at it is the cam won't give you that much advantage unless you allow it to work, and it can't do that well without the external components.
'68 Short C20 Flatbed Dually w/ 292 4bbl, Langdon cast headers, and WC T5 trans. '81 G10 Shorty Van "Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers "Under promise, then over achieve." |
#28 | |
Decisions decisions.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
#29 |
Yep. Hence post #11. Power band from idle to 3,500 rpm.
#30 | |
#31 |
This maybe the best choice for my setup as I don't plan to run the drag track. Just a nice Cruiser is all I'm looking to for......... along with standing out in the vast sea of V8's everywhere.
#32 | |
#33 |
Six in a row makes it go...
![]() Join Date: Mar 2009
I built one performance 250. It made good power. It was expensive.
Ultimately, I think you bump into two big considerations when hopping up the six: 1) the head really needs the bolt bosses milled out and 2) Fuel distribution with a single carb is less than optimal. Overcoming those requires a more serious investment. I keep my sixes stock now and hot rod V-8s if I want power.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
#34 | |
Old Duffer
I have the water heated intake manifold on my engine, but bypassed it after I didn't notice any real gains with it. I don't jump in my truck and go, I usually let it get a little temperature before I take off. I have a 195 deg thermostat and the cast headers seem to warm the aluminum intake pretty quickly. I've never had a carb icing problem with this set up like I did with a crate 350. From what I've heard and have no reason to doubt it is, the single quickest gain in power and reliability is the HEI. My truck isn't quick, it's heavy and was designed as a work truck, I just wanted something a half-step out of the mainstream, but what it has got going for it is reliability, smooth operating, and easy to work on. It'll exceed the posted speed limit.......(I guess my age is showing now.... ![]() Probably a good investment for the money spent is a copy of "Chevrolet Inline Six-Cylinder" by Leo Santucci. This is an excellent resource on I6 speed/power modifications.
#35 |
Does anyone know if the Langdon headers or clifford headers have any issues if you have a clutch and the Z bar?
That sure is a good looking 292 engine there. I'm buy that book and read up some before I dive straight in. I'm looking for reliability more than anything. The stock set up is very reliable as it is. Just want a few of the cool wow factor items to be different. If I can gain more power, that's a bonus too.
#36 |
Originally Posted by Custom/Ten Eventually someone with some experience might speak up,...................... I meant in response to the last question he asked. The one that no one had answered yet. The one about loosing the heat riser when you add headers. Ya know , the question you just answered. wasn't saying the previous posts weren't useful. When I said person with experience I meant someone other than myself as what I was posting was based on research, NOT experience. Wouldn't want to upset anyone lol. Hope that clears that up for ya. ![]() Last edited by Custom/Ten; 05-22-2015 at 11:54 AM. |
#37 | |
Old Duffer
If you look closely at the photo you can see where Langdon designed the headers to run either side of the Z bar. Custom/Ten, No worries, I misread what you meant.
#38 |
Installing tube headers and loosing the heat valve on a six is little different than tube headers on a V8. The setup on the six may continue to provide some heat after warm up, but like slomotion, it has never been an issue on my engine.
In the winter, I can push the manual choke off, after a couple of blocks. In the summer, I'll pull the choke out just enough to set the idle up till I get out of the driveway. It never gets cold enough in SoCal to require much choke on any engine. I ran water to a block bolted under the intake like slomotion mentioned and had the same results. No change with or without water. The newer Clifford manifolds have a built in water passage that runs the length of the manifold. I don't know if heating the manifold helps them or not.
'67 GMC 2500, 292, 4spd, AC |
#39 |
I had the Clifford shorty two-piece headers. I made my own Y-pipe to bring it to a single exhaust. The Z-bar fit.
I also had the Clifford 4-barrel intake with the coolant plate below. I was driving it in the winter so I never tried it without it. I never had a problem when using it.
#40 |
Really great info. Thanks everyone.
Where does everyone get these nice side plate and valve covers from. They are nice looking with the fins.
#41 | |
Tom's website http://www.12bolt.com
68 GMC 2500 stepside LWB 250CI |
#42 |
![]() Join Date: Feb 2002
I have Clifford long tube headers. The Z-Bar fits and works fine.
#43 | |
I really appreciate all the insight and help everyone.
#44 | |
#45 |
Yea. I'm looking at adding some headers basis the advice given and the minimal issues. Thanks guys.
#46 | |
Might it be Tom Lowe?
#47 |
Old Duffer
For what it's worth.....
Since back in the old days when we were building/driving flathead engines up to our current vintage engines, we had a procedure for putting headers on. Whether it was a help or not I don't know, but I have never had a gasket burn through as long as the flanges were true and flat. Make sure everything is clean - head, studs/bolts, header flange, and gasket. Get a can of good quality aluminum based hi-temp rattle-can paint. When everything is ready, paint both sides of the gasket and let it dry. Then paint it a second time and install everything when the second coat is tacky, taking the nuts/bolts up to torque specs. After the engine has been run up to operating temps and cooled down again, re-torque. I don't know if it's helpful, but I do know it doesn't hurt, and best of all, if you have to open the engine up again, the gasket won't rip in two needing a bunch of scraping to remove all of it.
#48 | |
#49 | |
