05-18-2015, 09:34 PM | #1 |
I6 intake, carb, header upgrades? Worth it?
I have an all original 1968 250 CI engine with an HEI upgrade.
Thinking about adding an intake, carb and headers to it. What kind of power increase can I expect? I know the original set up rated it at 155hp/235tq. Any recommendations. Would like a little more power without a V8 upgrade.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
05-18-2015, 10:12 PM | #2 |
Re: I6 intake, carb, header upgrades? Worth it?
I don't know about the 250 but a buddy of mine had a 258 jeep inline he milled the head, put a cam, intake and Holley 4 barrel and 3" exhaust. It was a beast, you would swear it was a v8 if you didn't know. I'd love to try it someday on a 250.
05-18-2015, 11:21 PM | #3 |
You can get good horsepower out of a straight 6 but they tend to work best in lighter vehicles like an old CJ. On the other hand try and tell the Turbo Buick guys you need a v8 to do well in the quarter mile.
1971 Cheyenne Big Block Longhorn |
05-18-2015, 11:57 PM | #4 |
Moderator
Did it all the time to my Jeep CJ inline sixes. Difference is night and day, worth every penny IMO
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
05-19-2015, 12:58 AM | #5 |
I've been running a 4 barrel carb, Offy intake and Clifford headers on the L6 292 in my '68 C/10 Stepside since 1978. The intake and headers are on their second engine. After 250,000 miles on the last engine and a 500 mile break-in with a newly rebuilt 292, the 390 Holley gave up the ghost. But it was old and I decided it was more cost-effective to put on a new 500 CFM Edelbrock 1404 [AFB-clone], than to get a new throttle plate for a 25 year-old carb. I have since upgraded to a Pertronix II ignition. The new build in 2005 included larger [1.84"] intake valves and a Crane 260H cam.
05-19-2015, 01:28 AM | #6 |
"Worth it" is relative. You will probably see slight gains. Potential from bolt on externals mentioned is best utilized by upgrading the camshaft.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. |
05-19-2015, 07:46 AM | #7 |
with the bigger carb. and aftermarket exhaust, your just making it breathe better
dont want to hear excuses, i want to hear solution(s) |
05-19-2015, 10:55 AM | #8 |
05-19-2015, 12:30 PM | #9 |
So there isnt too much to gain without camshaft swap then ? Any recommendations on camshafts?
05-19-2015, 01:10 PM | #10 | |
Langdons stovebolt, and summit sell them but as to what you should use, that's over my head. If your ready to buy you could call Langdon guy but his selection is pretty limited. An old timer I respect always said just call edelbrock and they'll tell you what you need! Langdons also sells some sweet lookin cast iron headers, and they're shortys too. I bought some cheap headers from summit and hated them, thin flange and way too long, looked like crap, touched the intake, I wouldn't get the long tubes. |
05-19-2015, 02:55 PM | #11 |
The stock 250 cam is not performance oriented by any means. Around 390 lift intake & exhaust if memory serves. A common upgrade I often did for customers was install a Mercruiser marine cam which can be used with the stock springs. A step up is the Crowler #03240 cam which is what I am running in my '69 250. Similar to the "towing cam" of old. My '69 c10 is running stock intake & Monojet carb, with split headers. Nice improvement in low end with very smooth idle. Highly recommended you go with the #84008 lifter/spring/retainer kit along with it.
Cam: http://www.crower.com/camshafts/chev...ulic-cam.html# |
05-19-2015, 03:07 PM | #12 |
I think he's talkin bout this guy up top, correct me if I'm wrong
05-19-2015, 04:48 PM | #13 |
I had this very same question about a year ago and when I weighed the costs of a complete upgrade and engine overhaul, I fiqured out it cost more to do then getting a brand new gm 350 from Jegs.. But with a little ebaying, amazoning and patience i was able to get a Clifford intake, a never used but second hand holley 390. Hedman headers, a full dual exhaust,tom langdon valve and side covers for around 700 bucks.. No cams or engine work.. The exhaust sounds nice, other than that the upgrades provided very little performance boost without any internal engine work but without a doubt gets a ton of attention at the shows.. I wish I could say people stop to check out the truck it's self but it is always the engine people stop to check out.. On a long row of small block Chevy's my inline 6 stands out.. There is always a crowd under my hood and not because it is pretty because it is not.. It because it is not another 350 like every other hot rod at the show.
I wish the engine work was more affordable because when my 250 dies I will be in that row at the car show like everyone else.. With my brand new short block 350. Posted via Mobile Device |
05-19-2015, 07:34 PM | #14 |
Full agreement taking a straight 6 to car shows. Even though mine is old and grimy people are always standing around swapping stories. "Had one of those in my work truck and it ran forever." Or ... "You cannot kill those things." Chevy 250 used to be dime a dozen but few people rebuild them anymore. So a lot of parts houses have kits on the shelf collecting dust so they can be had pretty cheap. Shopped around about a year ago and found a few quality top to bottom sets complete with pistons, rings, gears, bearings, and gaskets for $190.
05-19-2015, 08:10 PM | #15 | |
05-19-2015, 08:51 PM | #16 |
You can change the cam, but you are still limited by the roughly 8.0:1 C.R.
It just keeps getting better doesn't it? I rebuilt my 292 and used a 194/204 cam which is like Langdons Stovebolt and others sell. A little smaller than the Crane H260 that '68 Orange used which I think is a 204/204 (not sure). Bigger than the original 292 cam, which is 188/188. I included 9:1 pistons, roller rockers, 1.94 intake valves, Clifford intake and Carter AVS, The HEI and long tube headers had been installed previously. I drove it around for a few days and was very happy with the time and money spent. It wasn't a 3/4 ton rocket, but it was good. That week, I pulled the 4.56 gears out and installed a 3.54 with posi. That put a big smile on my face. Even with the new engine, I was still in the slow lane with the engine screaming. I got there sooner, but I was still in the slow lane. With the new gears it runs in the fast lane with ease. I put in the AC in and it now runs in the fast lane with the windows up and an even bigger smile. I think if my truck had 3,73 gears, I would be looking for something with overdrive. If not a 5-spd, then an 4-spd automatic with overdrive. I have a feeling you are going to come back with some flowery stuff about how cool and original the column shift is, but it really isn't. It's going to have one of three (all tall) first gears and still have big steps between gears. I am mindful that my truck 4-spd isn't a whole lot better. I just can't wrap my head around having a more powerful engine and making that first shift, uh over and up into second. It would just leave me blank.
'67 GMC 2500, 292, 4spd, AC |
05-19-2015, 09:45 PM | #17 |
Richardj.. Sorry for the little hijack of the thread but I was looking at your set up and my set up is similar, maybe you could help me out.. I am doing a front disc conversion and wanted to do power brake upgrade as well, I was wondering where your vacuum line runs to from the brake booster, I have only been able to find info on stock set ups.. On stock set ups the vacuum line runs from the booster to the stock intake manifold.. Any info would be great!!! I hope I explained what I am looking for correctly
68 GMC 2500 stepside LWB 250CI |
05-19-2015, 10:11 PM | #18 |
RichardJ, "flowery stuff" that's lame bro! Must be a chill living under that bridge lol.
05-20-2015, 01:01 AM | #19 |
Scottcoda, there is a round, raised pad on the top of the runner where it turns for cylinders 5-6. It's there for just this purpose. I think I used a 1/4 NPT pipe tap and a 7/16" drill.
Myself, I'd pull the manifold rather than take chances on shavings going in the engine. I've read some of your posts, but I don't know how long you've had your engine running. If you don't pull the headers away from the head, there is a good chance you won't have to replace the gasket. I've read where you said you installed all studs for the manifolds, so the header shouldn't move at all.
05-20-2015, 02:08 PM | #20 |
I like the 6 as others have mentioned. In the sea of V8's the lil 6 stands out. I agree that the V8's are a dime a dozen. LS swaps are getting the same way. Both swaps are for good reasons such as milage and power. I have an LS camaro and a BBC truck already and hence way I'm trying to keep the lil 6. Yes the column shift isn't the best and I'd rather a floor shift setup.
So far, it looks like just bolt one adds nothing but the cool sound. Any power gains require a cam swap at minimum and maybe compression bumped up some. Thanks everyone so far for the advise. Anybody actually Dyno a before and after upgrade on the lil 6. What kind of numbers did you get?
05-20-2015, 04:31 PM | #21 | |
05-20-2015, 04:52 PM | #22 | |
05-20-2015, 05:21 PM | #23 |
That is impressive. I like that.
05-20-2015, 07:29 PM | #24 |
Old Duffer
I have a 292 and in the original configuration it was a big single barrel carb and single exhaust manifold/pipe. The problem with the 1 bbl is the engineers try to make that carb work from idle all the way up to highway RPM and as a result it works, it just isn't the optimum.
I put Langdon headers, Offy 4bbl intake, and an Edelbrock carb on the engine with no internal modifications. The results weren't dramatic, but they did improve the engines breathing and that alone has to improve performance/mileage. I have an HEI to install when the points go out, but so far they're doing very well. It's not tire smoking quick, but has plenty of drive-able torque for running around town. It runs cool, starts every time, and with the T5 trans behind it runs 65 MPH at 2800 RPM. For all-round dependability, and smooth operation, An I6 can't be beat. (Not to mention as some have above the "gotcha factor" when someone looks under the hood!)
'68 Short C20 Flatbed Dually w/ 292 4bbl, Langdon cast headers, and WC T5 trans. '81 G10 Shorty Van "Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers "Under promise, then over achieve." |
05-20-2015, 08:06 PM | #25 | |
That video was awesome. That's what I want but I bet the cost is up there.
