09-04-2016, 11:40 PM | #26 |
Re: Where do you have your fire extinguisher mounted?
Good for all of you guys! I've been in a car, riding down the interstate, when it burst into flames. Not fun, and it makes you appreciate having a fire extinguisher on hand (I didn't).
I build Race cars for a living, specifically drag cars. I only bring this up because when it comes to safety equipment of any kind, the questions I always ask myself when mounting things like fire extinguishers or activation handles, parachute handles, emergency shutdown switches, etc. are: 1. Will the driver be able to use this easily in an emergency situation? 2. If the driver is partially incapacitated, will they be able to find it and use it without being able to visually locate it? 3. If the car is in a wreck, what happens to this piece of equipment and its mount? Does it pose a hazard if the car goes into a roll? Now, I know this sounds like overkill, but consider that these extinguishers can weigh 7 or 8 pounds when fully charged.....in a bad, bad wreck, these things flying around in the cab can kill you in an instant. To echo what others have said: keep an extinguisher where you or others can get to it, and mount it as securely as possible without impeding its use. |
09-05-2016, 06:28 PM | #27 | |
White K20 |
09-05-2016, 10:53 PM | #28 | |
--------------------------------------------------------- I'm not crazy, I'm chosen, there's a difference. ---------------------------- '72 K10 SWB, 350, sm465/np205 ---- ---- |
09-05-2016, 11:16 PM | #29 | |
I taped one of those spring-loaded window shattering punches to the ceiling arm grab thingie in my daily driver. I put it up in such a way that it will come off easily. It's out of the way, won't move around anywhere, and I can get to it even in total darkness. I practice emergency escapes out of my car from time to time and losing those 20 pounds will help with that. Talking about cheap-o's, buy the best you can and go on. If that best has a plastic nozzle, well that's fine, those work too. |
09-06-2016, 04:27 PM | #30 | |
Unless you work with/for Kidde, then I retract any apology. |
09-06-2016, 05:49 PM | #31 |
Passenger side kick panel is where I mounted mine.
1970 C10 Short Stepper with 71/72 front clip. |
09-08-2016, 09:07 PM | #32 | |
I've sold over 1,000 since launching it and designed it to fit as many vehicles as possible. It's not so compatible with bench seats (it either clamps onto the seat rail or bolts to the seat mount points) ... but fits just about anything with buckets. If anyone is interested, I'll offer free domestic shipping ... just use the code "free shipping" at checkout at www.thebracketeer.com I'll attach some pics: |
09-11-2016, 11:06 PM | #33 |
Diy4x makes a beefy quick release mount in both bolt or weld on versions. http://diy4x.com/product.php?productid=17833. I run one in my K5, I should probably get one in the C20 too
09-12-2016, 10:16 AM | #34 | |
No it's the original 205 stick in the original position. Plus check out my knob. I had a blank engraved at things remembered at the mall. Came out great! Don't think I ever posted pics of it completed, took me a couple passes to get the paint filled in the engraving. Came out great though. Here I looked up my old thread on the knob. Never posted a pic with the paint completed. Anyhow you all may get a laugh out the engravers misspelling! http://67-72chevytrucks.com/vboard/s...d.php?t=662501
White K20 Last edited by jeffahart; 09-12-2016 at 10:22 AM. |
09-12-2016, 10:27 AM | #35 |
I removed my stock glove box and made an oversize one. That's now where I keep my extinguisher.
09-12-2016, 08:24 PM | #36 | |
Well that's great man. Your first post on this forum was because of one of my posts. It is a neat idea and I wish you much success with it. I may even buy one for my car. |
09-13-2016, 12:37 AM | #37 | |
09-13-2016, 09:12 AM | #38 |
I mount to the trans hump in my 4wds or passenger kick panel in my 2wd trucks. The '72 4wd already had one mounted to the kick panel, so that's fine
09-13-2016, 09:35 AM | #39 |
In my Blazer it's behind the driver's seat in the bedside corner, yea I don't have side panels. My 67 will have it on the kick panel, it appears to of had one at some point, the drill holes line up with my era correct extinguishers. I also have a moving blanket in back to aid in smothering a fire, but it's mostly used for picking up road treasures
