05-26-2015, 01:59 PM | #1 |
Where do you have your fire extinguisher mounted?
I want to carry an extinguisher but where do I mount it? I was thinking the trans hump as I have a column shifter and it would be easier to reach there than over on the right side by the door.....
What do you guys do? |
05-26-2015, 02:23 PM | #2 |
Re: Where do you have your fire extinguisher mounted?
I have mine in the kitchen. Guess I better get it into the truck. I'm thinking just under the seat within reach while in driver seat or door open. Hope we all never need one.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
05-26-2015, 02:31 PM | #3 |
Mine is mounted between the driver side window and the back window. Just behind my head. Is located there, for that is where my dad mounted it in
1970. Could never move it.
1970 Custom Camper/20 1959 Morris Minor 1000 1953 Dodge B-4-KA 1953 Fruehauf 30' Lowboy 1928 Cat 30 1939 TORO Bullet Tractor |
05-26-2015, 02:47 PM | #4 |
Mine is mounted under the seat on the driver's side with a small bungee cord holding it to the seat bracket.
Hook'em |
05-26-2015, 03:46 PM | #5 |
It's important to remember that anything not secured tight becomes a projectile in an accident, and the accident doesn't need to be serious to sustain additional injuries from objects in the cab. I've seen many mounts that would not hold a fire extinguisher in even a 25mph accident.
05-26-2015, 04:31 PM | #6 |
Old Duffer
On the hump between the shift lever and the seat. My thought being it's easy to reach and use if I come on an accident, and it's just below my right arm if I am the accident.
Mounted on the kick panel won't do much good if the door is jammed, and hard to reach if you're stuck in the driver's seat. Under the seat could be hard to reach in some circumstances. Not trying to be too gruesome, but thinking through several scenario's I'd like to think I could protect myself as well as someone else. Seems like there was an earlier thread on this as well......
'68 Short C20 Flatbed Dually w/ 292 4bbl, Langdon cast headers, and WC T5 trans. '81 G10 Shorty Van "Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers "Under promise, then over achieve." |
09-04-2016, 01:01 PM | #7 |
I went gung-ho on the heater box mount but I'm starting to have second thoughts about it now...
I'll probably never use my heater but something about "heater box" and "do not keep in high temperatures" in the same sentence sounds kinda funny to me, in a not so funny way. I'm also wondering about the weight of the fire extinguisher on the box, if that will end up wearing on the box mount and make things sloppy. Has anybody had any issues with mounting on the heater box? Here's mine:
-Jim 71 Chevrolet C20 94 GMC Yukon 4x4 |
09-04-2016, 01:23 PM | #8 |
Wow I like that! I don't think you'd have any problems with the heater box. If the box was that hot, it would melt your truck. Perhaps you could fashion up some insulator material (foam?) to go between the canister and the heater box.
09-04-2016, 01:33 PM | #9 |
I always thought the area where the jack goes, beside the tank, would be a good spot. No one has a mount there I can copy? Don't make me innovate, people, I just want to copy!
I actually assumed that's where most would have it!
09-04-2016, 01:51 PM | #10 |
It might fit well there, but would not be easy to get to. Seconds count.
I came across a flipped over car that was on fire about 3 months ago. However, I was late to the party: traffic was extremely backed up, 5 police officers were on scene, but apparently not a single one had an extinguisher. The fire truck was just arriving also. Now had I been 5 or 10 minutes earlier, I might could have had some impact as I carry two extinguishers in the back of my daily driver. |
09-04-2016, 02:14 PM | #11 |
I saw a bad "semi not paying attention, crashes into stopped traffic" conflagration on the news last week. One vehicle burst into flames immediately, but something like 5 different people had extinguishers on the scene and they got it out.
09-04-2016, 02:33 PM | #12 |
Very rare that so many people were both prepared and aggressive. Two things overcome adversity: being prepared and being aggressive.
09-04-2016, 02:55 PM | #13 |
Well that -was- five our of maybe 100 involved. It was a big incident, and on a major freeway.
09-04-2016, 03:16 PM | #14 |
so...not to hijack, but what type extinguisher do y'all carry?
09-04-2016, 03:17 PM | #15 |
I got the tall mega shifter so I'm thinking on the front of the shifter housing plenty of room right next to my hand all the time
09-04-2016, 03:24 PM | #16 |
White K20 |
09-04-2016, 03:54 PM | #17 | ||||
Btw your mount is one of the best styles of mount available for that size of fire extinguisher. Unfortunately Amerex is the only one I know of with a dual strap mount like that. Quote:
So you want an ABC, BC or Purple K (has BC rating) that holds at least 2.5lbs of chemical, I'd recommend a 5lb though. There's plenty of room under or behind the seat for a 5lb but it's a little harder to get a good vehicle bracket for one. Amerex is the only one I know of with a dual strap vehicle bracket for 5lb extinguishers. Avoid CO2 fire extinguishers, they're great for under the hood when inside the shop but outside the wind renders them basically useless. Also avoid any liquid/foam fire extinguishers, they're gimmicks and often aren't UL listed/rated and if they advertise they are they're lying. The only liquid/foam extinguishers that are decent are the 2.5 gallon ones with the stainless steel shell Fire Fighters use, not something you want to carry around. Quote:
09-04-2016, 06:17 PM | #18 | |
Never buy a new car.... LOTS OF PLASTIC
White K20 |
09-04-2016, 06:43 PM | #19 | |
What I do know is what I've seen over the last 17 years working in the fire extinguisher service industry. I see them mangled and broken all the time in delivery trucks at accounts where we unfortunately have to service those because they refuse to buy better quality and we don't want to lose the account. So we take a chance. Because we become liable for a fire extinguisher when servicing them we refuse to service those plastic Kidde whenever possible. And as I said I've seen plenty of them come out of the box dead, leak down in a year, etc. At one point there was a recall for a Kidde plastic valve model where the threads on the valve would break and the valve would shoot out of the head. Still feeling smart with your "Never buy a new car, lots of plastic" comment? Another plastic valve model has a clip holding the gauge in, it's not threaded, just push the gauge in and insert the paper clip thin clip and hope it holds back 195psi pushing on it. Sometimes they don't hold and the gauges shoot out. We are careful where the gauge is pointing (like you would be with a gun) especially while filling. Btw the model in your truck has the gauge held in by a paper clip, it's only 100psi though, haven't seen one of those shoot it's gauge yet. Let me state this unequivocably. From what I've seen Kidde with plastic valve assemblies are the least reliable fire extinguishers on the market and I will continue to try and persuade others to not use and rely on them in an emergency. If you've had better luck with the strap and those plastic valve Kidde extinguishers more power to you, I sincerely hope it works when you need it. Last edited by Overdriven; 09-04-2016 at 07:05 PM. Reason: Spelling and a few more examples of crappy Kidde quality |
09-04-2016, 07:17 PM | #20 |
ITTR, Here's mine. My truck is a rust bucket, work truck, so I just screwed it into the kick panel.
Overdriven, I'm interested in anything you have to say about my fire extinguisher. Even if it's negative. Better to know now than later.
CHEVY/GMC VIN DECODERS |
09-04-2016, 07:27 PM | #21 |
I mounted mine on the hump using Velcro on the back side of the extinguisher mount. Been there for over 10 years now.
1968 SWB. GMPP 350/350 Turbo Trans, Edelbrock Performer & Carb. Hedman Hedders, Hooker Aerochambers Mufflers. Tuff Stuff Alternators. Remember, no matter where you go, There you are. Gary |
09-04-2016, 08:02 PM | #22 |
This may have some value.
http://www.thebracketeer.com/ I have been told that the metal nozzle-units are the ones to buy. I carry a 5 lbs CO2 unit in addition to my 2.5 dry chemical unit for gas station fires. Just in case I get a fume ignition at the pump....no need for a bunch of powder down into my tank. I'm sure just about anyone with some fabrication skills could work up a suitable floor mount. I guess I'll go for on the hump unless I can attach it to the front of the seat. Thanks for the info Overdriven! |
09-04-2016, 08:15 PM | #23 |
I have them in all of my vehicles, in my 67 its located on the floorboard at the edge of the seat on the driver side.
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies 2004 2500HD utility bed aka Brutus |
09-04-2016, 10:17 PM | #24 | ||
Every 12 years dry chem fire ext get what's called a hydro test. Fancy name for the cylinder gets filled with water and over pressurized to test its integrity. For little 2.5lb fre ext like those most have in trucks it's usually not worth it to do this unless it's one of those chrome jobs as the cost nears that of new. Something to be aware of if you decide to bring yours to a shop. There's always a date somewhere on the cylinder. These days many are stamped into the bottom but some are on the label somewhere. When 6yr maint or hydro is performed a sticker with the date of that is affixed to the cylinder. One last thing, kind of important. If you use a fire ext at all it should be recharged. Dry chemical fire ext don't reseal after shooting any amount, the powder mucks up the oring seal and the pressure will leak out in a day or 2. CO2 will reseal but there's a finite amount of agent in all fire ext, you want all you can get when you need it. Last edited by Overdriven; 09-04-2016 at 10:27 PM. |
09-04-2016, 10:50 PM | #25 | |
As far as the kind/brand of fire ext to buy. Its the valve assembly that matters, the nozzle can be any material. Kidde and First Alert are the only ones I know of making plastic valves and they are everywhere because they're cheap. I had a guy come into the shop with a 60ft ocean going sailboat who bought his plastic Kidde at a marine store and it's all they had. I'm sorry they had 2 sizes of them and this guy bought 2 of the smallest ones that are less than 2lbs for his God only knows how much it cost 60ft sailboat he takes out on the ocean. Anyway. Some stores will carry the metal valve models by Kidde and First Alert though. As I said before avoid Kidde if you can but if you can't get the metal valve ones. First Alert's metal valve fire ext are reliable though, not the most fun for us to recharge but they're reliable and many big box hardware stores carry them. Other good brands are Badger, PyroChem, Ansul, Sentry, Amerex, all of them only make good commercial grade fire ext. Last edited by Overdriven; 09-04-2016 at 11:04 PM. |
