Old 06-29-2015, 05:53 PM   #26
R.S.S.
R.S.S.'s Avatar
Re: Need help with 67 Chevy van
VCVC.org is a good site as well. Plenty of good writeups on mII disc brake swaps.
R.S.S. is offline   Reply With Quote
Old 06-29-2015, 09:43 PM   #27
tarafied1
tarafied1's Avatar
thanks guys, I am registered on vintage vans, have not yet been approved for VCVC yet.
we are actually trying to figure out what the rear axle is as well. It's a 10 bolt but 5 on 4.75 bolt pattern. It has 11" drums. Well one anyway. Trying to find parts for it. Ordered a G10 drum thinking it was from the half ton but it was too small.
B body Chevy's had 11" brakes on a 10 bolt so I ordered a Caprice drum, it comes in tomorrow. We will see...
married to TARA, that makes me the TARA-fied1
tarafied1 is offline   Reply With Quote
Old 06-29-2015, 11:13 PM   #28
bretcopsey
Maybe not all, but two different Caprice's I had were 5x5 bolt pattern-hopefully the one you ordered works. If not, I have used Oreilly's website in the past to get drum/disc specs when trying to find something not original to my application. Once you enter year/make/model then select the part, you can click a "product details" tab to get specifications info such as this:
UPC: 829352436875
Rear
OE Replacement
11 Inch Brakes
3 Inch Deep
Outside Diameter (In): 12.93 Inch
Overall Height (In): 3.41 Inch
Bolt Pattern: 5 On 5 Inch
Additional Details
Maximum Diameter (In): 11.090 Inch
Maximum Diameter (mm): 281.69mm
Nominal Diameter (In): 11 Inch
Nominal Diameter (mm): 279.4mm
Number Of Bolt Holes: 5
Bolt Circle Diameter (In): 5 Inch
Outside Diameter (mm): 328.42mm
Overall Height (mm): 86.69mm
Pilot Hole (In): 3.06 Inch
Pilot Hole (mm): 77.85mm
Surface Depth (In): 2.52 Inch
ABS Sensor Ring Included: No
Good luck, and cool van!
My 51 project
http://www.cardomain.com/ride/2285825
My 68 Camaro project
http://www.cardomain.com/ride/2277404/1
bretcopsey is offline   Reply With Quote
Old 06-29-2015, 11:39 PM   #29
michael bustamante
michael bustamante's Avatar
Maybe an s10 rear end? Leaf spring right?
1967custom
michael bustamante is offline   Reply With Quote
Old 06-30-2015, 12:51 AM   #30
tarafied1
tarafied1's Avatar
that's kind of how I came up with the Caprice drum, the one I found was a 5x4.75. It had one drum on it so I measured everything best I could.
Old 06-30-2015, 12:52 AM   #31
tarafied1
tarafied1's Avatar
yes, it's a leaf spring rear. Did S10's have 11" drums?
the drum I do have looks "60's" with no fins...
Old 06-30-2015, 07:45 AM   #32
Katrina/10
Katrina/10's Avatar
I dig the van! Nice work so far.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 06-30-2015, 02:35 PM   #33
tarafied1
tarafied1's Avatar
thanks
and the Caprice drum worked!
Old 06-30-2015, 02:37 PM   #34
tarafied1
tarafied1's Avatar
day dreaming of a Gasser...
Old 06-30-2015, 04:34 PM   #35
Katrina/10
Katrina/10's Avatar
thanks
Cool, glad you found one that would fit. Is there a 5 lug drum you can swap on the front so the wheels will match?
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 06-30-2015, 11:49 PM   #36
tarafied1
tarafied1's Avatar
I'm looking into that. It is a "heavy half" so the spindle is different than the G10 which had 5 lug. Trying to find out what will fit.
Old 07-01-2015, 07:07 AM   #37
Katrina/10
Katrina/10's Avatar
I was told you could change an old solid axle truck (say 1950) from six lug to five lug by installing 1950 car hubs and drums. Yours looks a lot like my 51 truck so that may be possible, but I have never done it.
A G10 van axle would be correct lug pattern and bolt right in, if you could find one.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 07-01-2015, 07:32 AM   #38
chiefcfd
chiefcfd's Avatar
Cool van! Just FYI I have a new van aluminum radiator in the shop that I ordered wrong and couldn't send back. I could make you a deal and I am just down the road.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 07-01-2015, 09:36 AM   #39
Bagd72Chevy
C10 Collector
Bagd72Chevy's Avatar
FYI- Caprice's were 5x4.75 until 1989, the 1990 and up was 5x5. I know the 49-57 chevy car hubs will fit on the 6 lug truck solid axles, maybe they would fit on the van???
///Ryan
1972 Chevy C-10-Bagged, Blown LT1, 700r4, Suicide Doors
1967 GMC- SC & Cam'd 4.8, built 4l80, 3200 stall, posi, 4.10
1967 Chevy LWB- 454 and patina
1971 Blazer - Rusty
1968 Crewcab project
Bagd72Chevy is offline   Reply With Quote
Old 07-01-2015, 11:12 AM   #40
tarafied1
tarafied1's Avatar
thanks I may be sending you a PM once we get this thing where we an drive it!
and thanks guys on the lead about the car hub. I am going to check that out!!!
Old 07-19-2015, 08:40 PM   #41
tarafied1
tarafied1's Avatar
well after much research, the G20 is a bit of a rare van. The disc brake conversions for the G10 will not work, the G20 front drum is not available new and the straight axle & parts from other Chevy trucks are different.
We were thinking we were just screwed.
We were able to determine that a mid 70's K10 rear drum will work. The shoes are the same and they are both 6 lug. We were also missing some hardware so we used some Mustang parts...
Mustang adjuster:
Old 07-26-2015, 07:58 PM   #42
tarafied1
tarafied1's Avatar
it lives
https://fbcdn-video-i-a.akamaihd.net...2c9dcd01d8f8b1
Old 07-26-2015, 09:04 PM   #43
flashed
Its nice to see it move under its own power ,still tagging along.
flashed is offline   Reply With Quote
