Old 07-26-2015, 10:27 AM   #26
hardwaycooke
hardwaycooke's Avatar
Re: I'm looking for these OEM parts for a 71 Chevy
Originally Posted by 71CHEVYSHORTBED402 View Post
I'm interested in that differential cover. PM sent. Thanks
Here ya go...
71 LWB
Large Bore 6-71 Blown 383 Stroker
4.11 Motive/EOM Eaton Posi Ported/Polished Carrier
15x8/15x16.5 MT Radials
B&M Pro Shifter
Truck Name- Spike
hardwaycooke is offline   Reply With Quote
Old 07-26-2015, 01:00 PM   #27
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
Oh ya, I'm interested, PM sent.
Edit: Your mailbox is full. I wrote: Are those are OEM and straight? If so, I'll take them. If you take Paypal, I'm happy to pay the difference. They charge about 4 percent.
Let me know how you want to communicate this. Unfortunately, as stated, your private in-box is full.
Thanks!
Sorry, cleaned mail box. PM sent
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 07-26-2015, 01:29 PM   #28
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Not sure why, but I didn't get it. At any rate, I sent you a couple PMs. One includes my phone #.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 07-26-2015, 01:36 PM   #29
71CHEVYSHORTBED402
hardwaycooke, I sent you a PM. Thank you.
Tony
Old 07-26-2015, 09:48 PM   #30
bronze 72 super
bronze 72 super's Avatar
Say, did you ever find a set of Big Block valve covers? I have a set on my '71 Cheyenne Super that I'm going to be pulling off, and replacing with factory Chrome ones with drippers, which means I don't need the painted ones. If interested let me know in this thread. Thanks, Mike.
1971 Cheyenne Super C-20 402 4 speed
1970 El Camino L-48 350
1999 Chevy Z-71 Extended Cab 4x4
2000 Tahoe Z-71
2004 Monte Carlo S.S. Supercharged Dale Earnhardt Intimidator
1970 Chevelle, Malibu Sport Coupe
2007 Harley-Davidson FLHX Street Glide
bronze 72 super is offline   Reply With Quote
Old 07-27-2015, 12:10 AM   #31
71CHEVYSHORTBED402
Definitely interested. Another poster may provide picks for his set as well. Makes me wonder if the valve covers currently on the engine have the drippers. The heads are off a 396, couldn't tell you what year it is, but the valve covers came with.
Thank you.
Tony
Old 07-30-2015, 10:46 PM   #32
71CHEVYSHORTBED402
71 Chevy 1/2 ton, short/fleet, 2wd
OEM and straight metal only...rust not a concern.
1. 12-bolt differential cover. FOUND
2. 402 Valve covers using the push-on rubber oil cap. POSSIBLY FOUND
3. Paint separator moldings (wraps around the cab under rear window). FOUND
4. Original coolant overflow tank and bracket. I believe these sat on the LH side of the radiator. Reference to a stock reproduction is appreciated. MISSING IN ACTION
Note: If anyone can educate why/if there are two different "original" brackets It would be appreciated. I've seen two "originals". When mounted, one bracket is square with the bottle. For the other, the bracket slopes downward against the bottle. I'm mostly certain the one slopping downward is original. I believe both types use the same bottle. I've never seen the mounting plate for the bracket that slopes downward, so can't say they're the same.
Tony
Old 08-03-2015, 10:22 PM   #33
71CHEVYSHORTBED402
Say cheyenne10, your inbox is full. Note: You can save what you need to a another folder by:
1. Create the folder from "Edit folders" option located your "Private Messages" page. Make your changes and click "Save Folders".
2. Click the check boxes for the messages you want to save.
3. Locate the "Selected Messages" option and be sure it reads "Move to Folder". Then click "Go".
4. Select the folder you'd like to save them to and click "Move Items".
Still interested in those covers.............Thanks!
Tony
Old 08-21-2015, 10:15 PM   #34
71CHEVYSHORTBED402
2. 402 Valve covers using the push-on rubber oil cap. FOUND
Note: If anyone can educate why/if there are two different "original" brackets It would be appreciated. I've seen two "originals". When mounted, one bracket is square with the bottle. For the other, the bracket slopes downward against the bottle. I'm mostly certain the one that slopes down is original. I believe both types use the same bottle. I've never seen the mount portion of the bracket that slopes downward, so can't say they're the same.
Tony
