Old 07-19-2015, 08:17 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
I'm looking for these OEM parts for a 71 Chevy
71 Chevy 1/2 ton, short/fleet, 2wd
OEM and straight metal only...rust not a concern.
1. 12-bolt differential cover. FOUND
2. 402 Valve covers using the push-on rubber oil cap. FOUND
3. Paint separator moldings (wraps around the cab under rear window). FOUND
4. Original coolant overflow tank and bracket. I believe these sat on the LH side of the radiator. Reference to a stock reproduction is appreciated. MISSING IN ACTION
Note: If anyone can educate why/if there are two different "original" brackets It would be appreciated. I've seen two "originals". When mounted, one bracket is square with the bottle. For the other, the bracket slopes downward against the bottle. I'm mostly certain the one that slopes down is original. I believe both types use the same bottle. I've never seen the mounting plate for the bracket that slopes downward, so can't say they're the same.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 07-20-2015, 09:32 PM   #2
71CHEVYSHORTBED402
Re: I'm looking for these OEM parts for a 71 Chevy
Cash, trade?..................BUMP!
Tony
Old 07-20-2015, 10:04 PM   #3
Blown06
Blown06's Avatar
This guy's got a diff cover, not sure if you've seen it.
http://67-72chevytrucks.com/vboard/s...d.php?t=676357
Me: Jarrod
My project: http://www.67-72chevytrucks.com/vboa...d.php?t=646563
Blown06 is offline   Reply With Quote
Old 07-20-2015, 10:55 PM   #4
71CHEVYSHORTBED402
I have thank you. It's nice, but not an improvement on what I've got.
Tony
Old 07-21-2015, 11:52 PM   #5
71CHEVYSHORTBED402
Turns out I still need all these parts.
Tony
Old 07-22-2015, 01:44 AM   #6
chewychevy67
What condition does the overflow tank need to be? I have one I believe ( just have to make sure I still have it) in used condition. It has the bottle and mounting bracket but is missing the cap. If interested I can dig it up and get photos this week sometime. Rod.
chewychevy67 is offline   Reply With Quote
Old 07-22-2015, 12:00 PM   #7
71CHEVYSHORTBED402
Well, I can refinish the bracket if the metal is straight and no rust. I believe I can locate a cap. As for the bottle, I'd be surprised if it's nice, but I imagine I can get a replacement. Let me know Rod..........Thanks
Incidentally, I'm still not 100% sure if the originals sit on the RH fender or mount to the LH side of the radiator. I believe it's the RH side of the radiator. I've looked this up, there appears to be some confusion.
Tony
Old 07-22-2015, 02:24 PM   #8
chewychevy67
here it is. bracket is solid and could just use a blasting and repaint. bottle is just a bit yellowed but holds fluid and is not cracked. 4th pic shows what the original cap looks like but I do not have one with it. the green cap on the bottle is not original but works. the last pic shows where it was mounted when I removed it from the truck it was on. if you want it I would do $75.00 shipped. Keep in mind it will cost me $30-$35 to ship this properly from Canada. would come thru Canada Post.
Old 07-22-2015, 04:10 PM   #9
71CHEVYSHORTBED402
That MAY not be what the correct part Chewy. Below is a link to an interesting thread. See posts 5, 10, 14, 20 and 21. Apparently these were dealer, not factory installed. So there's some doubt of consistency. I can't say for certain they all used the same part. At least one recovery tank was a GM part. I've seen one on a SPID. Dealer makes the SPID? Heck, I don't know.
Any chance your SPID shows an overflow tank?
I may still be interested. Can I trouble you for the widths of? 1. mounting strap width. In other words, the width of the vertical portion of the bracket. It's probably around 2-3". Also 2. the horizontal width of the entire bracket. I'd like to confirm this fits with the radiator and core before I ponder this further.
http://67-72chevytrucks.com/vboard/s...d.php?t=546610
Tony
Old 07-22-2015, 04:55 PM   #10
chewychevy67
does this help. I have no idea I am confused now. truck did not have a glove box lid when I got it and that was quite some time ago now. nothing with these trucks was documented clear it seems lol.
Old 07-22-2015, 04:57 PM   #11
chewychevy67
the width of the banding holding the bottle is 1" wide
Old 07-22-2015, 05:21 PM   #12
71CHEVYSHORTBED402
Yes, some things can be really confusing. I found that out recently in pursuit of a decent rear brake hose. Unless you know it's from an educated source, you cannot take any info. for granted. That and a loss in translation.........That's the "beauty" of the internet.
See that 3rd picture you offered above? Do a 180 with the tape measure for the width. I'm guessing it's around 2.5".
I suspect yours is the GM part they referred to per that link, post 14 and 21. You might plug these numbers into Ebay, these may be what you've got: EDITED: Bracket: 15996772 Bottle: 15687277
Tony
Old 07-22-2015, 05:39 PM   #13
chewychevy67
oh I got it now. it is 2" wide
Old 07-22-2015, 05:49 PM   #14
chewychevy67
on bottle 15687277 the fill neck is centered and on mine it is not and mine is much smaller. couldn't find a photo of the bracket.
Old 07-22-2015, 05:53 PM   #15
71CHEVYSHORTBED402
Thanks a bunch Chewy.
Definately a different bottle. You couldn't locate the bracket because I gave the wrong part (sorry). Here it is 15996772: http://www.ebay.com/itm/GM-15996772-...7f83fd&vxp=mtr
Damn my eyes............(too late)
Edit: Your bracket would mount to my vertical core support brace, above the horn. However, if centered on the width of said brace, it would hug the radiator. In other words, may not be quite right for this application.
Tony
Old 07-22-2015, 06:08 PM   #16
chewychevy67
I have to disagree with post 21 in that thread as far as similarities between first owners set up and 994230. I happen to have both right here in front of me and they are identical right to the screws that mounted them. there may possibly be different part #'s for the factory and dealer mounted parts but what first owner has there is a dealer truck unit.
Old 07-22-2015, 06:55 PM   #17
chewychevy67
it is tight to the radiator no doubt. I wondered about that as well. I never ran this truck but wondered if the heat would melt it. anyway ttt for you
Old 07-22-2015, 07:01 PM   #18
71CHEVYSHORTBED402
Ha, check that out.......... Is it just me or do some of these brackets seem to hang differently? The bracket on yours above (post 8) and post 14 in other thread appear to be square with the bottle (i.e., bracket is level), while the brackets in post 10 and 20 per the other thread are at an angle (i.e., bracket slopes downward).
Tony
Old 07-22-2015, 11:31 PM   #19
hardwaycooke
hardwaycooke's Avatar
I have the diff cover and over flow tank and bracket.
71 LWB
Large Bore 6-71 Blown 383 Stroker
4.11 Motive/EOM Eaton Posi Ported/Polished Carrier
15x8/15x16.5 MT Radials
B&M Pro Shifter
Truck Name- Spike
hardwaycooke is offline   Reply With Quote
Old 07-22-2015, 11:33 PM   #20
hardwaycooke
oops...I have washer tank..not overflow. sorry. thought 71 didnt come with overflow...
71 LWB
B&M Pro Shifter
Truck Name- Spike
Old 07-23-2015, 12:44 AM   #21
leddzepp
Moderator
leddzepp's Avatar
From what I have read here, they were only called out on the SPID if the truck was ordered by the government...which would mean to me that they were installed by the dealer otherwise. I have found them on 72's, 73's (73 is common if you search threads here), and vans. I run them on my 72 and my 68 in the position to the left as shown in the "factory" pic. It is a tight fit, but clears just as well, and serves a great purpose. Here is a setup I pulled from a 72 that I am saving for any future needs. It also has a warning sticker attached. I would like to think the sticker has been there since day one, since the truck was very clean and well cared for, making it very rare (LOL )...but it is over 40 years old and highly unlikely.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 07-23-2015, 04:01 PM   #22
71CHEVYSHORTBED402
Good information Zep....... Don't know where else you'd find a sticker like that. It looks original anyway.
By chance do you know why these "stock" brackets appear to hang differently? Between this thread and the one per the link below, some brackets are square with the bottle while the bracket slopes downward in others.
look at post http://67-72chevytrucks.com/vboard/s...d.php?t=546610
Tony
Old 07-23-2015, 10:55 PM   #23
71CHEVYSHORTBED402
Originally Posted by hardwaycooke View Post
I have the diff cover.
I'm interested in that differential cover. PM sent. Thanks
Tony
Old 07-25-2015, 05:12 PM   #24
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
I have the Paint separator moldings. I had them professionally straightened and polished they are ready to go! If you are interested I will take 60.00 plus shipping.
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 07-25-2015, 05:16 PM   #25
71CHEVYSHORTBED402
Oh ya, I'm interested, PM sent.
Edit: Your mailbox is full. I wrote: Are those are OEM and straight? If so, I'll take them. If you take Paypal, I'm happy to pay the difference. They charge about 4 percent.
Let me know how you want to communicate this. Unfortunately, as stated, your private in-box is full.
Thanks!
Tony
