08-24-2015, 07:48 PM | #26 |
Re: my ls swap died...
Well it lives they traced it back to a bad computer ground which is weird cause i had the computer grounded but they added 2 more grounds and it fired right up had 58 psi fuel pressure.
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
08-24-2015, 07:49 PM | #27 |
He thinks my lean codes where caused by the ground issuse but im not sure
08-24-2015, 09:13 PM | #28 |
I glad everything worked out truckdude239
08-25-2015, 08:51 AM | #29 |
1965 Chevy C10, 2005 4.8L/4l60
great! I am glad it was something reasonable and simple. I hope everything continues to roll smoothly for you!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
08-25-2015, 08:52 AM | #30 |
It is runnin good but it now has a u0107 code ibhave to figure out
08-25-2015, 04:26 PM | #31 |
meowMEOWmeowMEOW
u0107 is tac module mismatch/disconnect. If you just had a grounding or electrical issue, then this one isn't a surprise. It sounds like your truck is having grounding issues in general. I'd make sure you have good grounds on the "big 3" then make sure there aren't any un-grounded circuits OR any positive circuits shorting to ground.
08-25-2015, 08:02 PM | #32 |
Yea aparrently when i did the swap i "forgot" to bolt the wires to the back of the cylinder head.... they where just hanging there bearly touching the block they told me the bolt them back and redid my ground wire runing to the ecm and it fired right up with normal fuel pressure i cleared the u0107 and going to see if it comes back but the thottle is working.
08-31-2015, 09:35 PM | #33 |
wait...the ecm is suppossed to be grounded???? More info please!! Im having horrible issues with my swap and cant figure out why...maybe Im not grounding everything properly??
74 Stepside"Steppin Wolf":78mm Turbo LQ4/4L80e,BTR stage 3 Truck cam,3.73 12 bolt with Detroit True-Trac Project Steppin Wolf Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=670303 My Youtube channel "Bad Luck Garage" https://www.youtube.com/channel/UCRP...XkeEPCu_HmRfuw |
08-31-2015, 09:59 PM | #34 |
Mine would start when i frist did the swap i ran a ground wire to one of the case screws on the ecm and it started right up
08-31-2015, 11:20 PM | #35 |
mine fires up easy and idles good but wont rev over 2500 and will only give me 20%tps with engine running. At this point Im going to try anything and grounding the ecm is free so why not?
09-01-2015, 12:43 AM | #36 |
meowMEOWmeowMEOW
The ECM is internally grounded under normal circumstances. IF the internal grounding is bad, or if random line interference is causing noise (way more rare), then externally grounding the case helps solve some problems. You do need to be careful if you do this however: It could theoretically allow the PCM to become the path of least resistance if a current spike occured (welding on the chassis, getting struck by lightning, accidentally creating a short from the alternator). That shouldn't scare you off, just keep the battery disconnected at all times any electrical systems are being worked on your car.
09-01-2015, 12:59 AM | #37 | |
If welding on the vehicle, ANYWHERE!!! Or, otherwise energising the vehicle... ... ... (IE: Juicing the Flux Capacitor behind the seat with a Mr Fusion or Lighting via the Belltower...) DISCONNECT THE Battery! CT, (Crazy Engineer) |
09-07-2015, 10:25 PM | #38 | |
