Old 08-11-2015, 03:29 PM   #1
truckdude239
truckdude239's Avatar
my ls swap died...
so i swaped in a 4.8 4l60e into my 71 its been runnign for a while now and ive been battleing p0171 and p0174 system lean codes, i cleaned the massf low and checked for vacumn leaks but did not find any. drove it codes came back sometimes it would not idle so i replaced the mass flow with an ac delo reman, on my way home ti started bucking and jerking and then stalled out and wouldn;t start back i think i lost the fuel pump in the tank an ac delo ep381 with corvet filter
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 08-11-2015, 05:10 PM   #2
nsulacountry
Re: my ls swap died...
Did you check fuel pressure when you were getting lean codes?
A failing/weak pump or other restrictions can cause fuel pressure to go low. I believe 58 psi is the minimum to keep everything happy.
CT
nsulacountry is offline   Reply With Quote
Old 08-11-2015, 05:30 PM   #3
truckdude239
I did not but i pretty sure now it was fuel related
David fuller
2012 Subura outback
1999 honda accord
Old 08-11-2015, 07:36 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Those are whole-bank codes, so ya its most likely that something in between the tank and rail died. Luckily, the culprits are only the pump, reg, or filter...and all are pretty simple fixes.
Do the easy stuff first like checking that the filters aren't clogged (or too small), and that nothing is kinked/damaged. Then, I'd take a look at the feed hose on the in-tank pump from the pump motor to the sender. Its only 3" long, and has been known to split...especially if the wrong hose got used by mistake.
As long as it wasn't also seeing a ton of heat, its most likely that your lean condition didn't damage anything...hopefully the ECM killed protected you from that. If you scan it now, how many codes do you get?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-11-2015, 09:04 PM   #5
truckdude239
Its not ready only codes as p0650 mil control circuit but that cause i dont have the engine light wired. It died like 4 miles after mass flow replacement
David fuller
2012 Subura outback
1999 honda accord
Old 08-12-2015, 01:11 AM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Unlplug the maf to force-fail. The ECM will idle you off of speed density and you should be able to see if there is an immediate change.
Old 08-12-2015, 01:40 AM   #7
truckdude239
It will not sTart with maf unpluged or pluged in. There is no fuel at the saddler vavle
David fuller
2012 Subura outback
1999 honda accord
Old 08-12-2015, 07:00 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Current at the pump (pump even turn on? you should hear it prime, dpending on how much gas is in tank muffling it).
Old 08-12-2015, 08:01 PM   #9
truckdude239
Couod not hear pump prime when it died but i havent had a chnace to check for power at pump or relays
David fuller
2012 Subura outback
1999 honda accord
Old 08-17-2015, 12:56 AM   #10
dec010974
dec010974's Avatar
im interested to see the answer to this one.
dec010974 is offline   Reply With Quote
Old 08-17-2015, 01:00 AM   #11
truckdude239
Me to it is sitting at a friends shop it died as i 2as passing his shop. But i havent had anytime to work on it with my work schedule he said he would look at it when he could if i couldn't, but be has paying customers and they have to come first plus i told him i wasnt in a hurry
David fuller
2012 Subura outback
1999 honda accord
Old 08-17-2015, 10:42 AM   #12
dec010974
dec010974's Avatar
I am sure the problem will be resolved, easily. i haven't seen many LSxs die unless the engine falls apart internally, like piston rings, cylinder heads, or a bad crankshaft. they usually run forever. most of us pass them on to the next owner, when we decide to sell them.
Old 08-17-2015, 07:47 PM   #13
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
We just rebuild em if they pop. Not much can really "grenade" on these unless your making 600+whp on stock internals. Con rod bolts, lifters, rocker bearings are the only things that ever really self destruct (unless the oil pump went, which isn't your problem on this one).
Old 08-18-2015, 02:54 PM   #14
Justin@EntropyRad
Justin@EntropyRad's Avatar
which brand filter/reg unit? some are known to poop out early
* Call me NOT the website number*
Justin Novick
(773) 303-8251
Sales/Support
Entropy Radiator / Engineered Cooling Products
"The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com
Justin@EntropyRad is offline   Reply With Quote
Old 08-18-2015, 05:52 PM   #15
truckdude239
Wix 33733 or soemthing like that its the vett filter i used an ac delo fuel pump ep381
David fuller
2012 Subura outback
1999 honda accord
Old 08-19-2015, 03:30 PM   #16
TopFuel1966
TopFuel1966's Avatar
Mine presented with those same symptoms one day. I pulled the vacuum hose off of the fuel pressure regulator and gas ran out of it. Replaced the regulator and she ran like a fine watch once again.
TopFuel1966 is offline   Reply With Quote
Old 08-19-2015, 03:31 PM   #17
truckdude239
Mine does not have a regualtor in the rail it is a retrunless system
David fuller
2012 Subura outback
1999 honda accord
Old 08-19-2015, 04:48 PM   #18
siggyfreud
siggyfreud's Avatar
Sounds like you're using the Corvette filter/regulator combo that fixes pressure at 58psi. You just need to verify that you are getting power to your fuel pump, and that it's pushing fuel. If it is, you likely need to replace your filter/regulator. At that point you can do a pressure test and see what it is.
If you're not getting power to the fuel pump its an electrical issue.
If you are getting power but no fuel, likely the fuel pump went bad (assuming ground is good).
siggyfreud is offline   Reply With Quote
Old 08-19-2015, 06:40 PM   #19
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I'm still thinking that feed hose from the pump to the sender is popped. Soooooo common on in-tanks.
Old 08-19-2015, 09:59 PM   #20
dec010974
dec010974's Avatar
truckdude239, take some personal time off from the job and work on your truck. if you need an excuse, tell your supervisor that a close member of your family is really, really sick. he/she is having some real complications with his/her mobility. this person really needs your assistance, and you want to be there, for them, during their time of need. truckdude239, don't go too much into the details. call your supervisor from your cell phone, and speak slow and sadly during the call. if you are a bad liar, rehearse this a couple of times, before you actually make the call. if you need to, look at a few episodes of "The walking dead". Imagine rick grimes just wrecked your truck, killing zombies. "yeah", that should do it. sad, sad, sad. a c10 destroyed for a movie prop. that would really make me sad.
Old 08-19-2015, 10:13 PM   #21
truckdude239
Yea that wont work
David fuller
2012 Subura outback
1999 honda accord
Old 08-20-2015, 08:19 AM   #22
dec010974
dec010974's Avatar
truckdude239, to most of us on the forum, our trucks are members of our families. My previous post was intended for laughter. It hurts me when my truck isn't running properly. If work is a priority, by all means, be there everyday that the doors are open. Every once in a while, I use personal leave from the job to work on my trucks. Its my therapy. Dr. C. says so (I see a therapist). I took a week off from work, to complete an engine swap on Choppy. It was a very memorable week. I loved every minute. the wife and kids were away, at school and work. It was just me and choppy. Choppy is the son, friend, and brother I never had. He is always there to lift my spirits, console me when I'm alone, and teaches me life's lessons. Vroom, Vroom. Damn I love my truck. I feel a burnout coming, when I get off from work.
Old 08-20-2015, 06:04 PM   #23
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Originally Posted by truckdude239 View Post
Yea that wont work
Everything Dec is saying is coming from a good place, but I understand it won't work for your situation TruckDude.
Whether it be a "living" family, pets, a truck, stuffed plastic maniquins with realistic private parts or something like art...we all have that thing that matters most to us. I think what Dec is really saying tho, is that unless you bear down and make time, the problem won't be solving itself any time soon.
Most of the idea's we've thrown out could be knocked off the list in a few evenings, so don't convince yourself you don't (or can't) make time to fix it. Don't get discouraged, and just do down the list. We'll be here whenever you get around to it.
Old 08-20-2015, 10:11 PM   #24
dec010974
dec010974's Avatar
"stuffed plastic maniquins with realistic private parts" really BR3W CITY. lol. I love this place. that was very funny. Truckdude239, we all are awaiting your triumph. good luck and keep us posted.
Old 08-21-2015, 08:36 AM   #25
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I am in a similar pickle as Truckdude, I cant take time off for my truck hobby, would love to but cant. I work on my truck about once a month when I have a Saturday off of everything. I get a bunch done ( or this is what I tell myself) but just never enough time to do everything needed.
Most of my vacation time is spent ON vacation ( two weeks a year sometimes) and the rest of my time is spent helping my elderly parents and/or my kids. Oh and then there is work.....I gotta do that, right?
Br3w, your a funny guy! that was classic!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
