Old 10-19-2015, 06:37 PM   #26
clinebarger
Re: 4L80E behind a 5.3
Originally Posted by Heavymetl View Post
As for power robbing, in theory, sure. Over on ls1tech there's multiple threads of track results after switching from 4l60e to 4l80e and there's no change. Several went faster due to the more favorable ratios. Bottom line....if a 4L80E fits, in my mind there's no reason NOT to run one.
I never stated anything about E.T's or Dyno numbers, I was talking about what they rob on take-off and Part Throttle in general, IT IS Noticeable, I have swapped 4L60E's for 4L80E's several times, Of course as BoostedC10 stated a good Stall Converter that gets the engine into the meat of the Torque Band helps a lot, Then More Power & Displacement/Boost makes my point moot.
The OP is going for a Cammed 5.3, A 4L60E will feel Better/Faster at Part Throttle where MOST driving is done. Especially if the cam is too big (Easy to over-cam a 4.8L/5.3L)
If I slapped a Allison 1000 in your truck....You would notice it
clinebarger is offline   Reply With Quote
Old 10-19-2015, 07:10 PM   #27
68c10owner
68c10owner's Avatar
I only asked because I dont currently have a transmission for this build. I`m getting a 5.3 core long block from a friend for free. I`m not planning to reuse my 1985 700R4 as its currently on it`s way out anyway.
The cam I`m planning to run is 218/226@.050 .595/.580 113LSA from Tick Performance. He recommended a 2800-3000 stall with 3.73 rear gears. Like i said, I dont care which one I use but I happened to find a 4L80E core for $150. 4L60E cores are going for much more than that in my area.
Anthony
68c10owner is offline   Reply With Quote
Old 10-21-2015, 03:00 AM   #28
Cobalt964ruf
Cobalt964ruf's Avatar
hey now... I like Allison 1000's lol
1971 K30 burb carbed LS6 th400 np205 d70f 14bff 4whl discs lifted 35 bfg's
1994 k3500 rcsb trophy truck ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's
1998 K3500 rclb ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's
1999 k3500 crewcab dually 4x4 496ci 4l85e bw4401 9.25ifs 14bff g80 6" lift 37 bfg's
Cobalt964ruf is offline   Reply With Quote
Old 10-21-2015, 03:03 AM   #29
Cobalt964ruf
and I only run 80's. yes I have built monster 65 and 70's. but in the end a mild 80 will take it all day long. most times for less money. I don't care about parasitic loss I drive a 1ton truck. I care about reliability and cost.
Old 10-21-2015, 07:29 PM   #30
clinebarger
That is cheap for a 4L80E, At least you will have room to grow (Blower/Turbo/more CID), With that cam, & the 2.48:1 first gear....A 3600 stall would be good to get you rolling.
Me too, I have one behind my Duramax
Old 10-26-2015, 11:31 PM   #31
CROWN
I did a 4l80 with a 5.3 in a 83 c1 and for what I was trying to do it was the Dumbest thing I've ever done. I was being cheap I had a extra 80e laying around and hindsight I would of found a cheap 60e and put it in. The tune has to be for a 4l80 or it will not work. Trust me! Google segment swap and Ull see what I'm talking about.
CROWN is offline   Reply With Quote
Old 10-27-2015, 01:13 AM   #32
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
But why is it the dumbest thing you ever did? It sounds like you had a 4l80e for cheap, which itself is a win. Why would you spend money, to acquire a trans thats weaker? All you need to do is have the tune and wiring setup for a 4l80e, which doesn't cost any more from the start.
Now if you already had a computer and wiring setup for a 4l60e and just tried to toss a 80e in there on a wing and a prayer....well...thats not the transmissions fault.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-27-2015, 01:20 PM   #33
CROWN
We'll the 5.3 I had was bone stock. I shouldn't have wasted the 4l80 on that motor I ordered a PCM and WIRING HARNESS SPEC'd to the vehicle and engine/trans I was using. The problem that I was having was it wouldn't shift into overdrive. No matter what I tried it wouldn't do it. I even had ANOTHER good 4l80 laying around that I knew for a fact worked put in. Did the same thing. After going back and forth with psi and current performance I narrowed it down to the tuning. And just to clarify it wasn't anyone's fault why it would work. That's why im saying I should of just used a 4l60 for a bone stock motor.
Old 10-27-2015, 06:24 PM   #34
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Have any of you guys used the TCI controller for the 4L80E yet? I was at a local trans shop today asking if they had any 4L80E cores and they said they just installed a 80e in a 69 Camaro and used the TCI controller and it worked out awesome. They said they can't keep 80e's in stock because they have a problem breaking cases at a certain power level? Have you guys heard this before?
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 10-27-2015, 07:53 PM   #35
Heavymetl
Breaking cases? Nope. I attended Drag Week this year and the number of folks running stupid fast (8's, 9's) using an 80E was staggering. I'm not doubting your shops claims, but case breakage with a 4L80E seems uncommon.
1970 C10
Turbo LM7 5.3/LS6 cam
PT7675/4L80E/Holley Dominator EFI/E85
Moser 9" 3.25/4 wheel discs
11.16@121.07
Heavymetl is offline   Reply With Quote
Old 10-27-2015, 08:00 PM   #36
clinebarger
I have no experience with the TCI controller.
4L80E cases are not prone to break, I have several out there with 700-1000 horsepower being put through them with no issues. They have the thickest most robust case of all Hydramatics.
Bellhousings breaking is usually from the trans being in a bind (Prying it over to get aligned with a mount, Bad U-joint, Out of balance drive shaft...ETC.
Big power cars with violent wheel hop or Tire shake can do that....Not really the fault of the Case though.
The Lugs around the Intermediate Clutches can crack/break, Builder error....Do not block the 1-2 Accumulator!
I guessing they are talking about the Bellhousing? If the Case wall (Arrow) is busting.....That is run away Line Pressure issues (400+ PSI)
Old 10-28-2015, 04:28 PM   #37
Dieselwrencher
They said the cases are cracking along the casting seam on the top of the case. I got on to this subject with them because I asked if they had any 4L80e cores to sell. He told me they can't get enough to use to build and sell, let a lone to resell. That's all I really got from him and why I asked here.
Ryan
Old 10-28-2015, 07:37 PM   #38
clinebarger
I have a hard time keeping cores also, Just not for his reason.
I would hit some wreaking yards.
LSx/Duramax cores run $250-$300
SBC/BBC/6.5L cores run $150-$200
This is regional, So they may vary where you are?
Old 10-29-2015, 04:03 PM   #39
Dieselwrencher
I've only found 2 late ones around here for $500ea. I don't really want to spend that much on one since it's going to be rebuilt later.
Ryan
Old 11-06-2015, 02:16 PM   #40
LowLifeS10
LowLifeS10's Avatar
Okay, I just bought me an 4L80e for my LM7 5.3. Is this the flexplate and spacer I need to make it work?
FP
http://www.jegs.com/i/JEGS-Performan...ductId=2442580
Spacer
http://www.jegs.com/i/JEGS-Performan...01010/10002/-1
GMC C15 -68 project: http://67-72chevytrucks.com/vboard/s...d.php?t=526059
Front/back Porterbuilt dropmember, Accuair, LS1/4L60e
Chevrolet C20 -72 C20 to K10/20 conversion, LS power.
LowLifeS10 is offline   Reply With Quote
Old 11-06-2015, 07:59 PM   #41
aknovaman
I just search craigslist for diesel transmission. Picked up a 80e for $75 last year. You can get a stock converter for a fair price as the diesel converter I usually have a very low stall speed compared to a gas converter.
Current project 1959 Willys = GEZR TRUK
Geezer is a Latin compound word made up of two roots.
Gee meaning Urine Stain and Zer meaning your pants are open!
FMCDH GBU and GBA
http://www.youtube.com/user/aknovaman/videos
aknovaman is offline   Reply With Quote
Old 11-07-2015, 12:53 PM   #42
slotard
http://sfbay.craigslist.org/sby/pts/5304560682.html Did they really do 4.8/4L80E in the Tahoe XL? I'd like to do a swap on my C20 and keep it capable as a 3/4 ton truck, I figure the 4.8 should probably make enough power for me (and if it doesn't I'll throw a turbo on).
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 11-07-2015, 08:56 PM   #43
clinebarger
I think he means Yukon XL....Same as a 2500 Suburban, the 8.1L & 6.0L were the ONLY engines available in GMT-800 2500 Suburban/Yukon XL.
The 4.8/4L80E combination was only available in Savanna/Express 2500 & 3500 Vans.
Old 11-07-2015, 11:14 PM   #44
slotard
So if it's out of a Yukon XL it's a 6.0? 2003 means LQ4 I believe, if that's what it was. What's the easy way for me to tell displacement?
1973 C20, 350/350
Old 11-08-2015, 03:13 AM   #45
slotard
Ok, he says it was in a van. Any reason I can't use it?
1973 C20, 350/350
Old 11-08-2015, 08:20 PM   #46
clinebarger
No.
