#26 |
Moderator
![]() Join Date: Oct 2008
Re: Wire question
A meter should sit at 14.5V with the engine running. 15+ is too high and 13.x is too low.
Amperage output is by demand up to the capacity of your unit... 10SI=63A, 12SI=78A-94A, CS130=105A. If the battery is low or has a dead or partially shorted cell it'll cause the alternator to push more current and heat stuff up. If you have poor connections to the battery from the alternator you'll get the same results.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
#27 | |
Re: Wire question
#28 |
Moderator
Re: Wire question
Be sure the ground cable to the alternator bracket is making good contact and the bracket is making good contact with the alternator itself as well.
Star washers are your friend. The easy way to test this is reading volts from the BAT terminal to the alternator case and comparing to the volts across the battery terminals. They should be the same. If they aren't you have a bad contact at the J-Block or the starter or the ground ^^^ is not making good contact. You can do a voltage drop test across all of these connections. Easy Voltage drop tests to check your cables...http://aimpartsonline.com/reduce%20warranties Is the 14ga red sense wire on the plug intact from the alternator through its' fusible link to the starter? Can you read more than @.1 DC volts from the BAT terminal to the sense wire? This means there's a voltage drop across these wires. There shouldn't be. The J block is fed from the starter through a fusible link. The sense wire is attached at the same place on the starter through a different fusible link. Internal failure. Bad regulator, bad diode, improper alt fan, bad bearing, defective heat sink??
And please let us know if and how your repairs were successful. Last edited by hatzie; 12-09-2015 at 10:08 PM. |
#29 |
Re: Wire question
Also, we noticed that the dome light won't go out when the truck is off and doors are shut. It just dims down when I shut the door
#30 |
Re: Wire question
#31 |
Moderator
Re: Wire question
The jamb switch has failed or the switched wire has rubbed through and is grounding out. The dome/courtesy lamps use a switched ground on the doorjamb and the headlamp switch.
The voltage drop tests across the cables are bloody easy and quick to do. They don't require $1000 in tools to execute either.
#32 | |
Re: Wire question
So I got the grounds improved and the alternator still seems to be heating up. It is putting out 14.4/14.5v but continues to heat up in the matter of a couple minutes. The wire off the alternator that runs to the fusible link is getting hot as well but the second wire within the fusible link doesn't. |
#33 |
Moderator
Re: Wire question
What's the voltage drop across the charge wire?
#34 |
Re: Wire question
#35 |
Moderator
Re: Wire question
It's measuring the difference from one end of the wire to the other. It's measuring the effect of resistance in the circuit.
Set the meter on DC volts and a range above 15v. Touch a digital meter probe to each end of a wire. If there's a voltage drop from one end to the other you'll see a low voltage reading on the meter. 0.1VDC is acceptable the more volts you get the less acceptable it is. Corroded terminals, poorly crimped terminals, loose terminals from age, corrosion inside the wire jacket, paint insulating grounds, ... will cause a voltage drop. It's really simple. Here are some hookups from the linked article on how to perform this diagnostic procedure. Testing the charge wire... Note you can test from the alternator BAT stud to the battery a shown then move the battery probe to the J-Block. ![]() This is testing the voltage drop between the battery and the alternator case. Your ground wire connection to the ALT ![]() This is the voltage drop across the sense wire. ![]() Test every cable run in the charge circuit. There are only 5
It may turn out that all your cables are pristine... If that's the case then you may have a failing alternator.
#36 | |
Re: Wire question
Tried that top picture and if we did it correctly (kinda hard to mess it up) it's reading at .8v. When we run the truck, the alternator seems to be losing .5v by the time it gets from the alternator to the fusible link |
#37 |
Moderator
Re: Wire question
That's way too high. You have dirty connections or corroded wires or a damaged wire. No section of the wire should show a drop of more than .1V to .2v
You measured the voltage drop across #s 1, 2 &, 3 on my list. Test each section to see where the drop actually is. It's not likely all three. What do you get from the red wire on the Packard 56 two wire alternator plug to the Battery positive post? This is #s 1 & 4 on the list. What does the alternator case to battery negative post give you? This is #5 on the list. Deoxit is still stocked by Radio Shack. You can hit the ring terminals with it after scrubbing with some emery cloth. When you get the connections cleaned up and passing current the way they are supposed to... I usually spray all the battery cable connections in the engine bay of my cars with Wurth HHS-2000. You can use Fluid Film or CRC Battery Terminal Protectant. You just need to keep the weather out.
And please let us know if and how your repairs were successful. Last edited by hatzie; 12-10-2015 at 07:13 PM. |
#38 | |
Re: Wire question
Alt. Red wire to the BAttery posi=.03 and so does the alt. Case to battery negi. #3 on the list=.25 and #5=.02. Have to rig something to get to starter, headers are in the way |
#39 |
Moderator
Re: Wire question
That narrows it down a lot.
The alt plug sense wire better than excellent to the battery positive so the big wire to the starter is just fine. The ground is better than excellent. #3 is high but it shouldn't make the alt get screaming hot. Check the crimp on the new ring terminal to the J-block. Solder it if necessary. This leaves the J-Block to Starter wire in the charge circuit and the alternator itself. It could be both.
#40 | |
Re: Wire question
#41 | |
Re: Wire question
Dad and I replaced the battery, alt, and starter wires and saudered the connections and the alt still was heating up the fusible link. So my dad took it to an electric shop for them to really test it out and turns out the alt is bad. So got another one on the way. |
