12-17-2015, 01:39 PM | #26 | |
Re: ANOTHER 6 lug disc brake question
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
12-17-2015, 01:51 PM | #27 | |
I am going to "pretend" I have a 71/72 and get everything from that truck and be good to go. Did 71/72 have a brake booster? Or would it be ok to use a hydroboost with those parts since I want power steering and brakes
"Cancer Crusher" build start date 11/29/15 |
12-17-2015, 01:53 PM | #28 |
Thank you to everyone trying to help me understand this.. I don't know enough about these trucks yet, even though I have a lot of mechanical knowledge.
Everything I have read on this topic involved using bits and pieces from numerous years and models, and that is what I wanted to avoid. If a 71/72 is a direct swap, why not just tell everyone who asks about the swap to go buy 71/72 parts, and its done?
12-17-2015, 08:33 PM | #29 |
Kyle I'm gonna try to simplify. IF you order the spindles that lolife has sent you the link to,You can keep the parts on your truck now if they are in operable shape.[meaning if somebody had gone through the truck recently you keep what is there]. Take off the drum and spindle that is there and set it out of the shop. Put the conversion spindle on put on the 6 lug rotor[ also you have that link. Now if your following so far you still have 70 model upper and lower control arms and the ball joints for the 70, along with all the steering stuff your truck came with.
So using these parts you only need to buy Spindles, rotors,calipers, hoses and pads. So when in the parts store you order calipers and pads for a 71-72 truck. When ordering front end replacement parts[tie rods or the like IF NEEDED] order the 70 model ones[that is the year of your truck, right?] I hope I helped if not I'm sorry and surely hope i have not added to the confusion |
12-18-2015, 12:08 AM | #30 | |
12-29-2015, 02:32 PM | #31 |
Kyle, I too am a low budget guy and did my build accordingly and stuck with the 6 lug pattern.
Junk yard items.... 3/4 LCA's 67-87 I think. Spindles/Rotors/Calipers from a 92 C2500 (Heavy Half) New Stuff...... Shaft kit/bushings for LCA's Upper/Lower Ball Joints for the 92 parts Brake lines (the 92 stuff will connect to the existing main brake lines) Brake pads This isn't exactly everything, I modified my own tie rod ends from a rack I had laying around. I also purchased a disc/drum master cylinder but haven't put it on yet due to the fact that love how the brakes feel(not running power brakes). Everything bolts and works great. The key to this setup is finding good parts from the bone yard to start with. I was lucky to find a truck with pretty decent rotors. The stuff I bought new was from rock auto so they weren't too pricey. The other benefits are that this setup gives you around an inch drop in the front and slightly widens the track width. Another is that I can purchase any of the parts at the local parts store. One thing I didn't know about until I put it together is that the LCA shaft kit is already has the caster correction so your front wheel is more centered in the wheel well. Hope this helps, if you have any questions feel free to ask.... Scott
1969 C10 SWB, 68 Front Clip, Tired azz 350 w/built 700R4, 3.73 Peg Leg........... |
12-29-2015, 03:04 PM | #32 | |
67-72 parts collector,…
It was documented in another thread on here. The issue was TOO MUCH positive camber. How did your alignment come out after you did this mod? The other negative,... would be what you said,... a wider track width. These trucks already suffer from having the front track width wider than the rear,... in stock form. I would hate to make it wider yet. http://67-72chevytrucks.com/vboard/s...d.php?t=620262
12-29-2015, 03:10 PM | #33 |
Other 88-98 threads:
http://67-72chevytrucks.com/vboard/s...d.php?t=353393 http://67-72chevytrucks.com/vboard/p...&pp=40&page=11 QUOTE: You must have missed the part where that conversion is no longer recommended due to alignment issues. The originators of that conversion don't recall any alignment issues, but everyone that has tried it in the past couple of years have.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 12-29-2015 at 03:24 PM. |
12-29-2015, 03:27 PM | #34 |
I haven't done an actual alignment yet but I'm pretty good with string and tape measure from my racing days....... Right now I have a little more negative camber than I'd like but there appears to be plenty of adjustment there. As far as the track width goes, I used a 70 rear end which is actually a bit wider than the 69. Overall I like it, I have 295/50/15's on the back and they look about perfect. On the front I have 225/60/15's, they are ok but I am going to go with a little wider tire in the future. The wheels fill the wheel wells nicely. I also use 8" wheels, 7" wheels could be used on the front if needed......
12-29-2015, 03:35 PM | #35 |
Here's what it looks like....
12-29-2015, 05:46 PM | #36 |
I guess I should add that the 92 spindles are stock and not drop. The drop is from cutting 2 1/2 coils out of the springs. The only possible issue that I can came across on my setup is that at some point I need to clearance the front of the spring pocket since the LCA is moved forward. Its not causing any issues but the springs do rub the edge of the pocket.
Scott
12-29-2015, 07:53 PM | #37 | |
You have so much spring cut out, that the normal C10 suspension would have alot of NEGATIVE camber. I'm glad it worked for you. But I would never recommend the 88-98 light duty 2500 6-lug components on any 60-87 c10. Just my opinion,...
12-29-2015, 08:10 PM | #38 |
Kyle,
Lowlife and hugger nailed it, good info there. Buy the spindles in the drop of your choice (if you are going to lower it). When you buy them, tell them what year your truck is. They will sell you the ones that will allow you to use your factory tie rod ends, ball joints, control arms, etc. if you want to stay 6 lug, you best bet is to find aftermarket rotors because the 71-72 trucks were 5 lug. I believe the calipers and pads from the 71-72 will fit the spindles. Check out MP Brakes.com for tech advice, those guys really know brakes. BTW.. I will be listing some almost new 6 lug rotors on the parts board real soon. Good luck! |
12-29-2015, 08:30 PM | #39 | |
Thank you for your opinion.... I have read a lot of your posts and value your experience and info...... Scott
