Old 11-15-2018, 01:20 PM   #26
SC1969c10
Your all a bunch of enablers!! Ha i browse wheels from time to time and was thinking of pulling the trigger. I also have drop spindles up front and 3” drop springs in the rear.
My favorite wheels ive found are
US Mags u125 or 126 chrome or gunmetal
https://www.jegs.com/p/MHT/US-Mags-Boulevard-U126-Chrome-Finish-Wheels/6836244/10002/-1
Coys C629 in either chrome or gun metal
https://www.coyswheel.com/coys-c-629-gunmetal
Us wheel rat rod max size in 6 lug is 17 but my favorie smoothie option
Or a set of smoothies from detroit steel or coys has a lighter weight aluminum smoothie.
Those are my favorite 6 lug options. Pricey, but if your already forking out the money, a few more bucks really isnt that huge given its a one and done. IMO
Jegs just had 50 off 500, im waiting to see if anyone has any black friday deals. Kills me because 5 lug options are endless and you can get wheel and tire packages 14-1700 all day.
SC1969c10 is offline   Reply With Quote
Old 11-15-2018, 02:39 PM   #27
kcmarkd
kcmarkd's Avatar
Re: Summit 6 lug vision wheels and tire size
May plan is to try and stick with an "enhanced stock" approach with this truck, upgrading to newer more capable tech (disc brakes, larger wheels, electronics) while retaining as much stock look as I can. So, I have been leaning towards Jegs 17" rally style wheels for 6 lug:
https://www.jegs.com/i/JEGS/555/681241/10002/-1
I can put wider tires on, but still have some "meat" in the sidewall, and don't have to bite the whole bullet and do disc brake conversion AND new wheels and tires. When I do disc brake conversion, I'll simply do the 6-lug variant.
So, I am trying to figure out backspacing, offset, fitment, etc. And to make it more challenging, it appears the PO had the stock 15" wheels banded to make them wider. So, cannot based any measurements or visualizer tools on the dimensions of a stock 15" wheel. About to take one of them off and have the local tire shop measure it and tell me the exact specs.
1970 C10 CST, PS, PB, AC, patina, original, work in progress
kcmarkd is offline   Reply With Quote
Old 11-15-2018, 07:44 PM   #28
dennislbrooks
dennislbrooks's Avatar
I run 17x8 6 lug summit legend gunmetal wheels on my 67 4wd. The hole in mine was 3.25". I know on mine as my front hubs are 3.5". I do run an 88 GM 10 bolt front axle from a full size blazer - same as a Dana 44. . 3.25" should be ok for a 2wd - but not a 6 lug solid axle.
Just info.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
Old 11-17-2018, 09:40 AM   #29
Mike C
Mike C's Avatar
The hub pilot is the same for the 2x4 and the 4x4 trucks. I ran my Jimmy 4x4 stock 6 lug rims on my 69 short step before I converted it to 5 lug. And they had the same hub diameter.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-03-2020, 11:51 PM   #30
KevJim72
Originally Posted by keel056 View Post
No rubbing so far
What are you running for suspension? Any drop?
KevJim72 is offline   Reply With Quote
Old 03-05-2020, 12:05 PM   #31
Custom 68
Custom 68's Avatar
its good to see a few options for the 6 lug. I stayed on my 6 lug for years. I do sometimes wish I had swapped over maybe someday as I know the wheel options are much greater.
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 03-06-2020, 02:58 PM   #32
SwitchbladeII
When I built my 36 Chevy street rod I wanted the biggest tire that I could fit in the rear. I ended up building a fixture out of wood and cardboard. You can buy a fancy one but for a one shot deal it was not worth it to me. I got the specs on different tires, section width, tread width and diameter. I then set my high tech tool and rotated in the wheel well. I cut the card board to match the profiles and secured the wood arm to the drum to set diameter. A few things to mind in mind is to check inside due to fact that body lean in a corner will bring tire closer than in a static position also weight in the bed, hitting bump, pothole or while steering wheel is max left or right. With all that said there is more clearance on truck than in most cars.
SwitchbladeII is offline   Reply With Quote
