12-13-2015, 05:24 PM | #1 |
Summit 6 lug vision wheels and tire size
Narrowed it down to the 17 x 8 vision 141 series gunmetal 6 lug wheel with a 4.5" backspace. My question is tire size... Looking at getting the widest tire I can that will fit all the way around so I can rotate my wheels and just for ease. It seems that a 255 is basically it for width for the front which means that's what I'll have to do for the back. Let me know if that is correct. Prob gonna do between a 50 and 60 series tire. Don't want any rubbing or any problems!
My truck is a '69 with 2 1/2" drop spindles stock height springs in front and 3" drop springs in the back with a '69 rear end. Baer 13" discs all around. Thanks, Ryan |
12-14-2015, 08:33 PM | #2 |
Re: Summit 6 lug vision wheels and tire size
Anyone know the widest tire that can fit under the front?...
02-28-2016, 07:44 PM | #3 |
I am in the same position as Ryan above and about to pull the trigger on these wheels. Let me know if you have purchased these wheels, or wheels with the similar size and what size tires are you guys running? I don't want to have any rubbing issues and would like to run the same size tire all the way around. Thanks!
02-28-2016, 08:15 PM | #4 |
I'm in the same truck (boat, lol) as Ryan too.
MyToys: Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles. Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop. Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ. Member of the Louisiana Classic Truck Club, LCTC Member of the Louisiana C10 Club Member of the Baton Rouge Drifters Car Club |
02-29-2016, 01:53 PM | #5 |
One of us should just pony up the cash and buy them!! Let's see.... Who is closer?? I'm still working on my frame... Haha where on your projects are you guys!?
02-29-2016, 09:38 PM | #6 |
I'm saving now but will be purchasing in about 6 months.
03-11-2016, 10:30 AM | #7 |
I broke down and pulled the trigger a few nights ago and ordered the wheels above. I will hopefully get tires and mount/balance within the next 2 weeks. I will keep you guys posted and send pics.
03-11-2016, 10:54 PM | #8 |
Sweet. Thanks. Let us know about the fit and any photos you can provide will be much appreciated.
03-12-2016, 09:56 AM | #9 |
Nice!! I'm excited to see them! Gunmetal or chrome?? Is your truck drive able right now?
04-05-2016, 08:24 PM | #10 |
Sorry for the late post. I went with the gunmetal. The truck is drivable now, but still working out a lot of bugs with it. Only issue I had with the wheels is since I still have 6 lug axle in rear the hub was just slightly larger then the center bore on wheel. Since the wheels are lug centric I could have either bored out the wheels slightly (just a few millimeters) or use a spacer. I decided for the time being to swap out my wheel studs for ones that are 1/2 inch longer and used a 1/2 inch spacer.
04-05-2016, 09:23 PM | #11 |
Looks good. What size tire did you go with? Any rubbing? Good to know about the rear center not fitting up. Does it have enough to allow the rim to be machined?
04-05-2016, 09:35 PM | #12 |
Thanks. I went with 255-60-17. No rubbing at all. I think the wheels could be machined without issues, it appears to have plenty where opening up the center slightly should not be an issue.
04-07-2016, 07:26 PM | #13 |
Nice! looks pretty cool! Take a few close ups when ever you get a chance!
04-26-2016, 07:46 PM | #14 |
We just installed these wheels on our 67. They did have to be turned by a wheel shop to fit correctly. But man they sure look nice. Went with a 265/60/17 tire.
We Bought another truck? |
04-26-2016, 08:00 PM | #15 |
265's!? And no rubbing?? That has got to be about the max on these for the front. I'm assuming you did the same all around... What kind of drop do you have? They look pretty nice btw
04-26-2016, 08:54 PM | #16 |
I just got some Vision wheels & tire delivered today
I went with 17/8 in front and 17/9 in rear. 255/50 front & 275/50 rear. Just a chassis with no body yet, so it doesn't really help you visualize it, but I made sure I stayed around a 27" tall tire
______________________ www.northeastrodrun.com |
04-27-2016, 01:05 PM | #17 |
Did have a little rub issue in the front had to adjust the inner liners. Got a 2"/4" drop kit from Early Classics. Nice kit worth the money have used it on a few trucks.
04-27-2016, 05:53 PM | #18 |
Thanks !! Keep the info and pictures coming !! Darkgrace what had to be turned for them to fit?
04-27-2016, 07:19 PM | #19 |
I converted mine to 5 lug, but they are the Summit Legend wheel. I did 17x8 in the front with the 4.5" backspace and 235 55 17 and on the rear 17x9 with 5" backspace and 275 55 17.
Stepsides have very little space in the rear for tire so backspacking and axle width are super important. I have a '72 5 lug axle in my truck. Personally, I think the smaller 235 front is a better look but wheel/tire is all just opinion...
04-27-2016, 07:57 PM | #20 |
Do you know what the bore size is that is required to fit a 6 lug truck? I've been looking for some rims also, seems to be limited options if you want 17, 18 or 20 inch wheels on the factory 6 lug setup.
67 C10 SWB Chevy |
04-27-2016, 08:25 PM | #21 |
It's the same as a solid axle 1/2 ton 4x4. You can look up on Summits site the wheels on my truck as well as the ones the OP mentioned and see what they are.
11-15-2018, 12:23 AM | #22 |
I did 275-55-17 tires on all fours.
11-15-2018, 09:56 AM | #23 |
@keel056, that is the exact size I am thinking to get on all four corners. I have a '70 fleet side that I am going to do a 2/4 drop. Still trying to work out exact disc brake/wheel/offset combination.
Any issues with rubbing in the front?
1970 C10 CST, PS, PB, AC, patina, original, work in progress |
11-15-2018, 11:17 AM | #24 |
No rubbing so far
11-15-2018, 11:29 AM | #25 |
