12-16-2016, 08:27 PM | #26 | ||
Re: Cab fuel filler to rear tank
12-17-2016, 08:03 PM | #27 |
I don't like it, too nice, too perfect, too OEM, lol. It looks awesome!
12-17-2016, 08:21 PM | #28 | |
12-30-2016, 05:28 PM | #29 |
Before and After
I really like this idea, I like the classic look of the filler tube on the cab, but agree it is a swell idea to remove the fuel from the cab. Do you forsee any filling delay with the long horizontal run you have to the tank?
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
12-30-2016, 06:57 PM | #30 |
Thanks it has worked out great, I've already put a couple of tanks in it and it runs about 3/4 on the fill nozzle. No big deal to me as I'm in no hurry these days and it's only a summer truck so all good.
12-30-2016, 08:40 PM | #31 |
That looks great! Really good idea.
09-01-2020, 01:31 PM | #32 | |
Mr. Cheyenne
I really want more room inside the cab (I'm a stereo guy) and a slightly bigger tank is a plus too. I also want to keep the original fill location - well because I want it to look original. I have a feeling I'd be mulling this over for a long time for my 72 LWB Truck.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
09-01-2020, 01:52 PM | #33 |
Old member
Nice job sir! If we all thought the same this place would be very boring!
09-01-2020, 09:09 PM | #34 | |
Do it, Do it right, Do it right the first time |
04-29-2021, 11:42 PM | #35 |
What type of material did you use for the tubing from the cab to the rear of the truck? I was wondering if EMT conduit would work or if the zinc coating would cause a problem with the fuel.
"Green Monster" (Red Sox fan) 1970 GMC survivor, 350/200 4R, 3.42 rear gears, 2.5/4 drop, ECE disc brake conversion, powder coated suspension |
04-30-2021, 02:02 AM | #36 |
Location: 3,018 feet above the SoCal/Mojave Desert region.
I'm installing a blazer tank side fill under the bed. But plan on filling through the bed wheel well. But was thinking of keeping the original fill neck on the cab for the original look.
05-01-2021, 01:45 AM | #37 |
I used tubing from my daughters old bunk beds and some exhaust tubing the has galv on it. No problems with zinc. I add zinc to the oil and gas with my original 283 any ways. It's been 5 years without issues
05-01-2021, 06:09 AM | #38 |
Well thought out and executed, good for you
71 C10 72 K20 72 K10 Super Kirk |
