Old 02-06-2016, 11:32 AM   #26
68gmsee
Active Member
68gmsee's Avatar
Re: 350 engine oil capacity
In case you haven't already done it..
When I bought the kit I used a small box end wrench that just fit over the tube and slid it down to the ridge. I then tapped on the wrench so as not to bugger up the tube.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 02-06-2016, 03:42 PM   #27
serge
serge's Avatar
Great idea.
General Contrucktor
serge is offline   Reply With Quote
Old Today, 04:28 PM   #28
Mav
Mav's Avatar
Used to put 5 qts. w/filter change in my 70 K10 pickup and 69 Judge RA3 both original engines, then years ago found specs and both say 6 qts. w/filter, so went with specs. Dipsticks both showed overfull but both engines had been removed and am not positive dipstick tubes are at correct height. Running into same deal with daily driver now (2024 Kia Seltos sx 1.6 turbo) Specs say 5 qts. w/filter, dipstick shows overfull. So have same question, are all 3 manufacturers putting out incorrect capacity specs or??
Mav is offline   Reply With Quote
