01-27-2016, 02:43 PM | #1 |
350 engine oil capacity
I think the dipstick is incorrect on my 350 engine. Changing oil and filter I noticed it only takes 4 quarts to be at full mark on dipstick.
To correct need the following clarified. Owners manual and GM service manual both indicate 6 quarts needed when filter included. I also noticed that several members say only 5 quarts needed when filter included. Which is correct? Your thoughts appreciated and thanks for your time.
General Contrucktor |
01-27-2016, 05:12 PM | #2 |
Re: 350 engine oil capacity
With the factory oil pan it will hold 4 qts plus 1 for the filter.
01-28-2016, 08:48 AM | #3 |
4 -5 qts
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
01-28-2016, 09:11 AM | #4 |
5 quarts is what I will go with.
Hard to believe the 1970 service manual which says 6 quarts needed was never corrected.
01-28-2016, 10:07 AM | #5 |
It sounds like something isn't right with your dipstick. If you put 5 qts in will it be over full? Is yours a big truck (C50-60) that takes a 2 qt filter?
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
01-28-2016, 12:56 PM | #6 |
*** That's interesting ***
I agree with everyone else. Unless you have something odd, every SBC powered vehicle I've owned, car or truck (including my C30) with a standard pan takes 4 in the pan and 1 in filter. Those 5qt bottles have always been ideal. I just fill up the filter, and dump the rest in the engine and plow on.
Can't assume that for LS-based engines though. The L77 (LS) in my 2011 Caprice PPV takes 8.1 qts. Go figure.
Tom Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... |
01-28-2016, 01:35 PM | #7 | ||
"I ain't nobody, dork."
I had a 1994 Chevy K1500 that with a factory installed oil cooler and a TBI 350, took almost 6 quarts.
It took forever for the oil to drain from the cooler lines unless I did a "hot" oil change. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
01-28-2016, 02:41 PM | #8 |
Registered Truck Offender
Yeah oil cooler on a 96 I had was the same way,, PITA
The stock Chevy SBC pan is a 4 qt pan (except SOME HD trucks 3ton and above which was a STUPID application for a SBC, but that's another story) So PAN will most likely take 4 quarts,,, Thing is you can get a 1/2 quart oil filter, or a 3/4 quart, or a 1 qt, or the big 2 quart filter. (and I think Delco makes a 1.5 qt.)
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
01-28-2016, 03:21 PM | #9 |
driving is in my blood
Never understood why our v8's take 5qts while a 2.8L v6 in a german car gets 8-9qts.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
01-28-2016, 03:49 PM | #10 |
Just to be safe I just changed oil one more time using 5 quarts.
Checked dipstick and same results. Oil level is about 1" above "full" mark. For now will engrave correct level mark on dipstick. Thanks again for your feedback.
01-28-2016, 03:50 PM | #11 |
When you say 5 qts, did you put 4 in the pan and 1 in the filter?
01-28-2016, 05:25 PM | #12 | ||
Or... start the engine, let the oil circulate and then shut off. Then check it after it all drains back into the pan.
Checking the oil after a change and not starting the engine will always show it to be too high on the dipstick. Gary
01-28-2016, 07:54 PM | #13 |
the boat guy
10,000 mile oil change interval. If you work the oil half as hard it will last twice as long. And who cares as long as it last past the warranty... #amiright?
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
01-28-2016, 10:26 PM | #14 |
My Cruze (1.4L - that's 83 cubes) yields 4.25 qts. per change.
I'm with everyone else - the vast majority of small blocks will require around 5 qts. for a change including filter.
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
01-29-2016, 12:11 AM | #15 |
Haha i did several like 3 or 4 newer kias today at work with a 1.6l 4 cylinder they all took 3.5qts
01-29-2016, 09:47 AM | #16 |
Yes
01-29-2016, 09:51 AM | #17 |
Ran engine for 5 minutes after change. Let drain for 1/2 hour before I checked.
01-29-2016, 10:01 AM | #18 |
Its a c-20. Nothing special noted on SPID so I'm pretty sure it is original standard oil pan.
01-29-2016, 10:13 AM | #19 |
Decided to look for longer dipstick tube that attaches to block.
(Not sure how to proceed without mind in gutter. LOL) Mine sticks out 6". 7" long would allow dipstick to read correctly. Need to find longer one if available and cut as needed. Any ideas on were to find?
01-29-2016, 12:10 PM | #20 |
Is the dipstick on driver or passenger side? You didn't say if your engine is original or not...or I missed it...older engines have it on driver's side...newer is on passenger side.
01-29-2016, 08:29 PM | #21 |
On drivers side. According to cylinder head casting number it is most likely original engine.
01-30-2016, 09:15 AM | #22 |
You can't just pull the dipstick tube out. I'm pretty sure that has to be knocked out from the bottom. Aftermarket ones just slide in an inch or so. I was wondering if yours has been changed at some point.
01-30-2016, 10:40 AM | #23 |
The dipstick has the correct mark locations according to spec sheets shared on this site. Therefore I suspect the tube may be a fault.
01-31-2016, 11:22 AM | #24 |
Active Member
On my old 69 with 350 I had to replace the dipstick and tube. Machine shop removed the old one and I lost it somewhere. I bought a dipstick kit from local auto parts, put 5 quarts of oil in the engine, ran it as serge did, let is sit for a while and checked dipstick. I made a full scribe mark with small file and forgot about it.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
02-01-2016, 09:16 AM | #25 | |
Thanks for the info.
