#26 |
Re: No tranny mount on my TH400? 70' c10
From what I gather reading and looking at Google images, the transmission should have a mount at the crossmember and the tail shaft. Does it matter when I'm getting parts that I have a TH400 instead of TH350
#27 |
That is the correct mount, and i am not sure, but i believe it does not matter if you have a t350 or t400. I do recommend, however, that you buy a polyurethane mount, like one from energy-suspension, they last longer, and in my opinion are much better.
#28 |
So was the engine leaning back against the firewall? This is wild!
69 GMC shortbed Carbed LM4 - Manual VB TH350 - Gear Vendors OD |
#29 |
#30 |
Is the trans mount broken or just missing the bolts?
When you were getting on it before you tore it down, did it vibrate or make a thumping noise like the trans was hitting the body underneath? Were there vibrations on acceleration or deceleration? For me, as far as the trans mount, I would not go to a urethane mount unless you go with the same urethane type motor mounts. The engine and trans needs to be able to move with each other. If you have a urethane trans mount (stiff) and rubber motor mounts (not as stiff) you take a chance on cracking the trans tail shaft housing.
Terry Soon to be retired and moving to Bristol, TN. |
#31 | |
#32 | |
There was a bad vibration any time I went over 55-60. And no thumping except for when I would manually shift and hold a gear at high RPM's and then floor it (like racing from a roll) and on major deceleration. |
