Old 02-08-2016, 01:25 AM   #1
Mrturner1
No tranny mount on my TH400? 70' c10
I'm in the middle of an engine rebuild and currently have the engine out but transmission is still in, sitting on a block of wood and still has the driveline hooked up. When I pulled the motor I was very surprised to see that there is no transmission mount. It's bolted to the motor, and then hooked up to the driveline. I always wondered why it felt weird when I would jump on the gas at higher RPM's, and I think this is the issue. Truck is a 1970 C10, with a th400 and 350 SBC.
Should there be a trans mount?
And could this be an issue IF the truck was previously a manual transmission?
Mrturner1 is offline   Reply With Quote
Old 02-08-2016, 08:59 AM   #2
Grumpy old man
Grumpy old man's Avatar
Re: No tranny mount on my TH400? 70' c10
Yes, Your truck was manual at one time evidenced by the cut out cross member . Yes you need a automatic trans cross member to keep it from "winding up" behind your new rebuilt engine . Check with member DLtruck he has been listing a lot of cross members in the classified section lately . Do a vin check on your truck and it will give you some interesting facts .
Grumpy old man is offline   Reply With Quote
Old 02-08-2016, 01:29 PM   #3
kehstr
kehstr's Avatar
I'm surprised you are still alive!! When you pulled the motor where the motor mounts trashed? And yes you DEFINITELY need a crossmember
kehstr is offline   Reply With Quote
Old 02-08-2016, 03:16 PM   #4
Mrturner1
Thanks Grumpy! Jeez one more thing to buy lol
Old 02-08-2016, 03:16 PM   #5
Mrturner1
Surprised I'm still alive? Is it that dangerous?
Old 02-08-2016, 03:17 PM   #6
Mrturner1
Hoping that once I put a trans mount I'll get more power to the ground and a firmer shift too. Seems like a flopping tranny would rob you of some performance
Old 02-08-2016, 04:05 PM   #7
Grumpy old man
So... Now that your going to have all the power from the new rebuild and after you install a new trans cross member . Whats the plan for the rear differential ? Because 100' burnouts with a one drive wheel wonder can be done with a 6 cyl with a 3 ott . Are you thinking POSI yet ? Yes ,I know what your thinking "does it ever end "? The answer is NOPE always one more thing to tweak to get it just right .
P.S. climb under your truck with a 4 inch grinder and grind the rivits off whats left of the old cut cross member (SAFETY GLASSES) You'll need the room to install the new cross member .
Old 02-08-2016, 04:25 PM   #8
truckdude239
truckdude239's Avatar
show us pictures so we know what exactly you have
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 02-08-2016, 05:46 PM   #9
kehstr
kehstr's Avatar
Well a t400 transmission is not exactly light, so all of that weight on the driveline, is not good, it could brake and then there's just something flipping around that can hit anything in it's path destroying pretty much anything it comes into contact with. Then not to mention the extra weight it has on the motor mounts that really are not made to have that sort of load on it.
Old 02-08-2016, 07:06 PM   #10
Mrturner1
The pics are in another thread. We've got it figured out, now just need to get a crossmember bolted up
Old 02-08-2016, 07:31 PM   #11
Mrturner1
100' burnouts with one tire would be such a shame after all this time and work haha The differential is next on the list after stall converter and external trans cooler. I definitely want to put a posi in it, but I'm not sure about gear ratio yet. I am going to have plenty of power, so I don't have to go extreme like 4:10's or anything. But I would really like to be able to cruise on the freeway now and then without winding it up to 3000 rpm ya know?
Old 02-08-2016, 07:53 PM   #12
firedemon
if you can weld you can build one for about 10 bucks in scrap I got the measurements for one I built I would be glad to post for you . its based on one of those $120 dollar aftermarket ones
firedemon is offline   Reply With Quote
Old 02-08-2016, 08:03 PM   #13
Possmguts
Possmguts's Avatar
wow... I mean.. WOW... how was it even still under there?? I mean... WOW!!
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
Old 02-08-2016, 08:11 PM   #14
Grumpy old man
This is when he finds the 12 inch long crack thats already in the trans bellhousing , And the worn out universals along with the slightly tweaked drive shaft ....
Old 02-08-2016, 08:24 PM   #15
Possmguts
Possmguts's Avatar
I dont want to crack on no one, but how in the world does something like that get by someone? That was a death trap waiting to happen if that thing was driven on the freeway like that. Im glad he got it figured out now and all, but Im willing to bet just what you said... busted bellhousing and worn everything from there back...
Make sure you check everything.. and I mean EVERYTHING. Put a wrench on every bolt and might as well change those motor mounts too. When I got mine I went over it with a wrench and found that the motor was not even bloted down at the mounts, along with many other bolts that were hand tight at best...
Old 02-08-2016, 08:42 PM   #16
Mrturner1
Well, I'm not feeling too smart about not catching the absence of a mount BUT, I am feeling lucky that nothing went wrong )
When I bought the truck about a year and a half ago, I got it from a dude who got it from an old timer who also had a 10 second swb C10. I went to look at the truck and after the PO started it and I heard a big lumpy cam I was sold. I have been wrenchin for years but still didn't look over the truck very well at all. I loved it as soon as I turned the corner on his block to be honest. Only drove it once in a while, and recently when I tore down the engine J found some really nice 492 heads, a big Lunati cam, and a nice .040 over bottom end ) SCORE.
Also in my defense, there is a peice of metal that resembles a crossmember, however, the tranny isn't bolted to it. When I lowered the jack under the tranny after pulling the engine, the front of the trans came down 7 inches before touching the crossmember type peice that's there. Only good it would do is not let the trans fall all the way to the ground, if even that.
Old 02-08-2016, 08:46 PM   #17
Mrturner1
I sure hope not. I mean the trans IS bolted to the motor when everything's together, so it's not gonna just flop. I can see where the danger lies, but the motor mounts looked fine (I'll double check now that we've discovered this) and from what I saw the trans looked good. I'm gonna pull it when I get home though. I was thinking, and bolting a nasty greasy transmission to my purdy engine seems like a half assed thing to do. Now that I've slowed down and really dug in, it makes sense to be as thorough as possible
Old 02-08-2016, 10:14 PM   #18
cleszkie
cleszkie's Avatar
Perhaps a scatter shield should be added to the list of improvements
cleszkie is offline   Reply With Quote
Old 02-08-2016, 10:17 PM   #19
tcrist
That could be the reason for the "no power at take off" issue that you were having. Everything that was supposed to allow you to hook up was moving around instead.
Guess it really does not matter at this point but, hate to think that you are going through the engine for no reason now.
Well, at least now you will know what you have. Time to start checking everything, and I mean everything. Now you don't know what else could have been Mickey Mouse'd.
Terry
Soon to be retired and moving to Bristol, TN.
tcrist is offline   Reply With Quote
Old 02-08-2016, 11:05 PM   #20
Possmguts
Possmguts's Avatar
Well Thats not quite as bad as what I was understanding then... I could not understand how there was no cross member... if it was at least sitting on a cross member thats a LITTLE bit better I guess...
And I did the same thing when I bought mine after only hearing it run over the phone lol.. and then found out how bad it was once I had it shipped 800 miles home... hence the full frame off Im doing...
Old 02-09-2016, 12:28 AM   #21
Mrturner1
I think that can be attributed to the big cam with no stall, and the stock gear ratio. But I think you're right, that definitely robbed some power. This engine build has been so fun I wouldn't take it back anyway
Old 02-09-2016, 12:32 AM   #22
Mrturner1
It sat pretty high over the one that's there, but certainly isn't mounted to anything lol would've acted like a driveline loop I think
The phone story makes me feel much better at least I'm not the only one. But hey, I wouldn't give my truck up for anything. And a frame off sounds like my next project
Old 02-14-2016, 11:42 PM   #23
Mrturner1
Do any of you guys have pictures of your crossmember and transmission mounts? I'm a little confused about mine. There IS a crossmember, but the transmission isn't bolted to it and doesn't even come close to touching the trans
Old 02-15-2016, 02:41 AM   #24
Gmc.guy
Gmc.guy's Avatar
I don't see a pic. But the one you have that seems cut. That's a manual trans Trimmed to fit auto That bolts to bell housing and trans hangs off the back. Look near the tailshaft. Should be 2 bolts there near the back on bottom. The crossmember bolts there and on the lip of frame on each side. You should have a couple sets of holes there. I don't have any pics but pretty common setup and you should be able to find one
-Cody
Gmc.guy is offline   Reply With Quote
Old 02-15-2016, 02:45 AM   #25
Gmc.guy
Gmc.guy's Avatar
I'm surprised you didn't have clacky noise with fan tapping shroud or cracked distributor cap.
-Cody
