#26 | |
Moderator
![]() Join Date: Oct 2008
Re: Best place to buy a parallel flow condernsor?
It'll need to be custom. Just a shroud between the condenser and the rad support that the condenser mounts sit against would do it.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
#27 | |
#28 | |
![]() Join Date: Feb 2014
86 Chevrolet K10 350/SM465 Frankie SOLD 1995 GMC Yukon GT SOLD 1996 GMC Yukon GT 2010 Suburban 1500 4x4 5.3l/6L80e. Sold 2016 Silverado 2500HD Crew Cab 4x4 6.0l/6L80e |
#29 |
Thanks for the info. Ive looked into Tubes n Hoses in the past. They make a bad ass machine that will make damn near anything you need when it comes to tubing and fittings for all sorts of aplications. I wish I could afford it. I could make my own custom ac lines without having to weld or braze. Their headquarters is just outside of Dallas. I need to give a call to see if there are any local dealers If not, I'm originally from florida and I travel back often.
#30 |
I'd suggest using an AC Delco compressor for R134 conversions....not a no-name parts store one. Also airflow is critical to getting good cooling-My preferred method is to use the 4000+ CFM Motorcraft dual speed electric fans mounted inside the stock pickup shrouds. This way, maximum surface flow and one of the most stout factory style fans too! Keeping the head pressure down on the high side related directly to airflow-especially at idle-low speed.
Also, make sure to change out the low pressure switch on your drier to an R134 switch-same goes for the high pressure switch on the compressor. R134 works at a little higher pressure so the R12 switch will prematurely kick the compressor off-making the system "appear" as though it isn't working as well as with R12. |
#31 |
Hard to see the fan but it's in there! lol
#32 |
Still plenty of room...it's a very stealthy install....
#33 |
AC compressor trigger off the climate control thru a HD relay to take the load of the system...
#34 |
Factory idle solenoid also trigger when compressor is engaged...
#35 |
Only evidence of an electric fan are the aluminum rivets on the top of the stock truck shroud....
