Old 04-04-2016, 10:03 PM   #26
aod92
aod92's Avatar
Re: before and after pics of my 67 swb
Beautiful truck man!
aod92 is offline   Reply With Quote
Old 04-04-2016, 10:13 PM   #27
Tropical Snowstorm
Lurky lurky
Tropical Snowstorm's Avatar
Looks great! Perfect worry free cruiser, enjoy the summer in it!
Tropical Snowstorm is offline   Reply With Quote
Old 04-04-2016, 11:00 PM   #28
powell72
powell72's Avatar
Originally Posted by CST10 View Post
How bout some detail photos of the carb linkage? Fixing to try something the same as yours. Are you running the stock exhaust manifold also?
This is the only pic I have right now, I'll grab more when I can. It's a mix of custom, stock, and aftermarket parts. It's a really tricky setup to get right and took a lot of time to troubleshoot and get it dialed. The hard part is the throttle rod runs front to back and the 6cyl linkages on the Monojets sit left to right. The stand that the modified factory bell crank sits on is a custom piece my buddy cut for me on a 2 axis machine out of aluminum. We measured very carefully because it's held in place by the intake/exhaust studs, and actually take the place of two of the clamshells that hold them together to the head. The height of the piece is important also since the carb linkages rise upward. It has an aluminum sleeve we made to work with the factory bellcrank and pin. We bent the bell crank towards the carbs. The linkage that connects to it is an Offy piece that came with the intake, along with the piece that ties the carbs together...both of which we also modified. Confused yet?? I know I was for a while!
I'm running the factory exhaust manifold for now. I had it Cerakoted, which is a coating like powdercoat commonly used on guns. It has a much thinner mil thickness than powdercoat and can handle higher temps. It still looks great after 2 plus years.
Hope this helps, it was a total pain in the butt, but it gets a ton of looks and comments at shows.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 04-09-2016, 07:54 PM   #29
xaircav
xaircav's Avatar
Once again that kid of mine hits one out of the park.
xaircav is offline   Reply With Quote
Old 04-10-2016, 09:11 AM   #30
mywifestruck
I already said this in a different thread but that is a beautiful truck! Almost exactly what I want to do with my 68.
http://67-72chevytrucks.com/vboard/s...d.php?t=684137
Thanks for sharing
mywifestruck is offline   Reply With Quote
Old 04-10-2016, 11:12 PM   #31
powell72
powell72's Avatar
Thanks for sharing
Thanks for the kind words! Good looking 68 you got there!
Chris
Old 04-11-2016, 12:36 AM   #32
Dave K.
Dave K.'s Avatar
A beaut! Nice job.
Dave K. is offline   Reply With Quote
