Old 06-02-2016, 01:04 AM   #26
oem4me
Re: E-Brakes...How many of you have them?
I've narrowly avoided disaster three separate times in three different trucks after blowing two brake lines and losing a wheel cylinder. The E brake saved my butt on each one, and allowed me to carefully milk the truck home on my own twice.
Old 06-02-2016, 09:03 AM   #27
vince1
I can remember my dad rushing us off to catch a missed school bus at the bottom of a hill on a gravel road at its last stop before heading to town. Picture this, 46 Dodge, no brakes, rocks flying from the back wheels every time the emergency brake was applied.
vince1 is offline   Reply With Quote
Old 06-02-2016, 12:12 PM   #28
jayoldschool
Moderator
I lost a rear cylinder on the way home from work last year. Had no brakes for about 15 min of the drive. No E brake. It gets a dual master and the e brake reinstalled next week!
jayoldschool is offline   Reply With Quote
Old 06-02-2016, 08:39 PM   #29
La Zona Imagery
Now I am paranoid. i need to have my e-brake installed. How much should a shop charge for this?
1965 Chevy C-10 350 V8
2003 GMC Sierra Crew Cab 6.0L 4x4
La Zona Imagery is offline   Reply With Quote
Old 06-02-2016, 08:47 PM   #30
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Mine made a good foot rest.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 06-02-2016, 11:22 PM   #31
vince1
Cost could depend upon how many of the parts you have. All that stuff should be figured out and available first. There are also parts inside the drums attached to the rear shoes that could be missing.
Old 06-02-2016, 11:34 PM   #32
ironman3452
ironman3452's Avatar
so here is a picture of my e brake, it is on the floor.Name:  e brake on the floor 64 panel.jpg
ironman3452 is offline   Reply With Quote
Old 06-03-2016, 08:33 AM   #33
vince1
So its what's underneath from the end of the lever back to the wheels. If you are lucky it is all there and it just needs maintenance.
Old 06-06-2016, 12:20 PM   #34
Heater63
Heater63's Avatar
If anybody needs ebrake parts for a shortbed, I have almost everything, (even the crossmember) and brand new inline tube cables, posted in the for sale section.
I installed the trick electric eStopp using custom length cables so all the original pieces were not needed.
292 + TKO500
Heater63 is offline   Reply With Quote
Old 06-06-2016, 12:44 PM   #35
La Zona Imagery
PM sent
Old 06-08-2016, 04:38 PM   #36
TheLast929
My manual trans 69 E-brake needs adjustment, but works. My 63 is..... well, the handle is behind the seat. After reading all these scary posts I'm gonna have to get that thing working.
TheLast929 is offline   Reply With Quote
Old 06-09-2016, 09:25 PM   #37
ironman3452
mine has a rod that goes to the brake around the back of the transmission, then the drive shaft hooks to it.
Old 06-11-2016, 01:51 AM   #38
KilroyWasHere
I've got the lever under the dashboard in my 66 fleet side. Luckily I've got power brakes that work like a charm, and hopefully won't have to use it as a Jesus lever!
KilroyWasHere is offline   Reply With Quote
Old 06-11-2016, 12:11 PM   #39
jayoldschool
Moderator
Anyone able to help me with the cables needed for my 65 LWB? Dual master swap completed, need to get the E brake back online!
http://67-72chevytrucks.com/vboard/s...d.php?t=709374
Old 06-13-2016, 01:23 AM   #40
'63GENIII
'63GENIII's Avatar
I got mine through NAPA although when I picked it up (the front cable) it had an Inline Tube tag attached to it. Id call Inline direct. They seem to know what to make.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 06-13-2016, 01:26 AM   #41
Heater63
Heater63's Avatar
Originally Posted by La Zona Imagery View Post
PM sent
and replied
292 + TKO500
Old 06-13-2016, 01:32 AM   #42
Daze57
Daze57's Avatar
its there for a reason !!!!........make sure you have it hooked up ........use it !
Daze57 is offline   Reply With Quote
Old 09-20-2017, 07:11 PM   #43
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
A lot of parts I got from an older guy who totalled his truck because he had an automatic and no e-brake. When his brakes went out going down a hill, well, it didn't stop until he deliberately ran himself into a telephone pole. He was pretty banged up - not to mention his truck.
66 C20 Service Truck:
Old 09-20-2017, 07:58 PM   #44
jayoldschool
Moderator
I am loving having a functional e brake on my truck. Glad that I got all the pieces to put it back together. This, combined with a dual master (and everything else new), really takes away any worries when using the truck.
Old 09-20-2017, 08:36 PM   #45
65truckowner
65truckowner's Avatar
Make sure you fix it. My 79 bronco is a 4 speed and mine did not work until I stopped at work on day to shut the gate. When I turned around to lock the gate it rolled across the highway and into the ditch. I had to put it in 4x4 to get it out. The worst part was there was a bunch a guys across the road watching and laughing.
65truckowner is offline   Reply With Quote
Old 09-20-2017, 09:33 PM   #46
rvrfoot
I use mine, my truck was a long bed flat bed. I cut the frame and now i had to do all the things to shorten everything. So my e-brake cables are all new.
rvrfoot is offline   Reply With Quote
