E-Brakes...How many of you have them?
Just wondering how much of a pain it is to replace all the parking brake pieces on my ride. I think I have used parking brakes during driver training and that was it. How many of you have replaced them or just done away with them altogether?
![]() Join Date: Jan 2011
Re: E-Brakes...How many of you have them?
I put new stuff on mine. Not to bad. In Virginia they are required and checked on state inspection.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
![]() Join Date: Sep 2011
Use mine stopped on hills, because of the 5 speed & not wanting to slip the clutch.
Never drive faster than your Guardian Angel can fly Larry |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Please don't think you'll never need them.
It isn't just about you.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
![]() Join Date: Nov 2015
My 64 only had the under dash lever with the short cable coming off of it. I used the Lokar universal kit. It was $120 but super easy to setup.
I use mine quite a bit. Being a manual I use it more than the one in either of the automatic cars. The new cables were pretty easy to replace. Definitely worth keeping. I drove the truck a little when the rear cables were frozen, but used wheel stops. That was much more of a pain.
Chris
1966 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=615165 1968 GTO http://67-72chevytrucks.com/vboard/s...=1#post7650182 |
![]() Join Date: Aug 2008
Mine works and I use it.
Mine is stock and I got it working great. It will lock up the rear wheels. In fact, I really enjoy using it to pitch the truck sideways now and then on loose dirt or gravel. Must be the redneck in me.
Active Member
![]() Join Date: Nov 2011
When I broke a brake hose, the E brake is the only thing that stopped me.
My daily driver Audi has an electronic one. I don't like it because it's either off or on and it doesn't respond as quick as a cable. |
![]() Join Date: May 2007
I use mine every day.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
![]() Join Date: Aug 2014
Mine doesnt work either, I wish it did. I like being able to use it on hills and steep places. Havent put forth the effort of replacing all the cables. Its missing nearly everything.
1965 C10 LS2/4l70, WHITE, 5/7 DROP LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283 1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E 1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE |
#13 |
Definitely get it working.
As for the single master cylinder, if a rear axle and drum came out I don't think the E brake would stop you. |
#14 |
Yeah, that would be a disaster.
#15 |
Mine is not hooked up.
Then my brakes, a dual setup disc in front drum in rear, went out. On a steep hill. Had multiple failure modes all tied back to sloppy work by the PO - proportioning valve was mounted in frame with one front line rubbing on frame. So that caused the fronts to go out completely. PO never drilled new location hole in pedal when upgrading to booster/dual MC, so rear brakes were not engaging all the way. And I was too lazy to setup e-brake. So those three things left me on a 25% grade going downhill with almost no brakes....in an automatic so I couldn't gear down. Remain Calm Don't Panic I managed to hold her on the road and coast to a stop with the 25% or so of rear braking that was available. I won't be back on the road without a full rebuild (never trust work done before you) and some e-brakes. |
#16 |
A truck i got parts off a few years back was totalled because he didn't have an e-brake with his automatic.
He got pretty busted up. But that's not the real issue. It's the innocent person in the wrong place at the wrong time. I know a lady who ran over a little one. Even though it wasn't her fault, it ate her up inside. So, our first priority over every little upgrade or some cool wheels or seat covers is make it safe as possible. Don't be stupid. Don't be unsafe.
#17 | |
It's like the fusible links that burn out and people replace them with a solid wire. A lot of rides have burned due to that shortcut. |
#18 |
#19 |
Well the first order of business I had was to upgrade the lines, hoses and brakes with a disc/drum system, power booster and dual master. So the odds of me losing brakes because of a hose is greatly diminished....but I will probably go and replace all the e-brake stuff too.
#20 | |
Coated the inside of the drum with Dot3, which makes a wonderful lubricant. Single-reservoir, so there were no hydraulic brakes at all. I came out out of the seat standing on the e-brake--which only had the driver's side shoe to contact, since the passenger side was lubed with brake fluid. The car didn't stop... even when I clutchlessly slammed the 3-speed manual down into 1st. Blew through the intersection on a 4-lane highway and miraculously didn't get creamed. Drove the car to the shop at work, and didn't put it back on the road until it had a dual reservoir in it.
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
#21 |
Most definitely hook the E brake up. My truck has the single pot MC at the moment and if it went out, especially at speed, I'd hate to think of the consequences. Don't just hook it up for yourself, hook it up for your family.
#22 | |
![]() ![]() Join Date: Oct 2011
Made me cringe just reading this
![]() ![]() ![]() Quote:
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" ![]() Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 |
#23 |
my '65 didn't come with any emergency brake whatsoever...I need to get them installed. I only have the single mc
1965 Chevy C-10 350 V8 2003 GMC Sierra Crew Cab 6.0L 4x4 |
#24 |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
When i did my LSx swap, i had to replace the trans mount which had the e-brake pivot device mounted to it. I went ahead and replaced all the lines with stainless and converted to the 1966 c10 type e-brake setup. Not too bad but not cheap either. Do it right, do it once!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#25 |
![]() Join Date: Feb 2011
I won't leave home without IT!
