Old 10-16-2003, 11:37 PM   #26
lukecp
Formerly yellow72custom
lukecp's Avatar
Yes, there is a bolt underneat the u-joint. Be sure to put the two halves back togetehr in the same position that they came out in, and put the yolk that unbolts back togheter in the same position that it came aprat in.
Good U-joints are only $10....i would replace it while it is out, no matter how good it looks
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 10-16-2003, 11:48 PM   #27
jorgensensc
jorgensensc's Avatar
Thanks!! I will probably replace it. The alignment thing causes a concern. My chilton says the driveshafts aren't supposed to line up perfectly, it says there is a 4 spline, towards the driverside twist with the 2nd saft. Mine appears to be lined up straight the whole way right now. Should I make the change, or leave it like it is? I don't have any shakes or shimmies or vibrations right now. What do you think? Maybe someone could post pictures of "Good" Stock type driveshafts. Thanks
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 10-17-2003, 12:36 AM   #28
lukecp
lukecp's Avatar
Leave it exactly the way it is. If you get the allignment off 1 tooth, it will vibrate. Just mark everything, put it back together and you should be fine. The shafts are balanced as a assembly, so if you rotate 1 part of the assembly without roating the rest, it will throw it out of wack (i learned that from exeperience )
Good luck
Old 10-17-2003, 12:47 AM   #29
jorgensensc
Kewl, thanks for the heads up!!!! I will definately leave it alone now. Now I just have to get te u-joint off, put new one in, and reassemble.
