Old 10-05-2003, 10:45 PM   #1
jorgensensc
jorgensensc's Avatar
Rear Differential seal???
Quick Question:
My rear differential appears to be leaking at the front seal (not constant, but does cause a spray effect under the bed area). I went to the parts store to buy a simple seal, however the two seals he had did not seem to match the seal I have on my 12 bolt rear. Any suggestions? Any part numbers would be great. I have posted about a 'tink tink' noise I have that sounds like it comes from the driveshaft. Could the loose rear seal be causing this noise? Is it holding something in? I know nothing about the innards of rear ends. Thanks in advance for all of your help. I'm getting ready to put a gas tank under the bed and restain the wood floor and might as well do this while I'm at it.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 10-05-2003, 10:53 PM   #2
lukecp
Formerly yellow72custom
lukecp's Avatar
The seal really dosen't support anything, it just keeps the gear fluid in the diff. case.
When you go to change the seal, you must put the pinion nut on in EXACTLY the same position as you took it off. If you get the nut on in a different position, it will mess up your rear axle in a hurry. Mark the pinion nut relation to the driveshat yolk, and the driveshaft yolk to the rear axle.
It would also be a good idea to take off the cover and change your gear oil too, as well as inspect the innards to make sure they appear to be in good shape.
Good luck
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 10-05-2003, 11:00 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
^ He's right, the nut needs to be torqued exactly to where it was before. The pinion bearing preload is set with the nut. Count the number of threads sticking out past the nut bfore you loosen it, and like he said, mark the nut, pinion, and yoke to make sure you can torque it to exactly to where it was. This is muy importante! You screw this up, and you will be paying to rebuild the rear end.
Too loose- bearing play, goodbye bearings
Too tight- bearing wear, goodbye bearings.
New bearings= remove carrier and re set up the gear set.
Kevin-(man who has learned to respect pinion bearing$)
Old 10-05-2003, 11:10 PM   #4
jorgensensc
I changed the rear fluid about a week ago. I will admit that when I pulled the rear cover off it had maybe a handful of fluid in it. All of the gears appear o.k. with no cracks or broken teeth and there were no metal pieces in the remaining fluid. There is a gear type whining that I have been hearing lately (that's what made me check the fluid in the first place), but it didn't go away after I added fluid. Someone suggested the center support bearing and I checked mine. It appears to be loose, so I bought another today and will be replacing that tomorrow hopefully.
Old 10-07-2003, 01:13 AM   #5
jorgensensc
I hate to bring this up again, but the rear seal really started leaking bad today. I really need to figure this out, but I can't seem to find the right one. Please help
Old 10-07-2003, 01:32 AM   #6
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
You might try going to your local GM dealer for the seal, they usually get the right part. or if you don't need to drive the truck to get the new seal, pull the pinion flange off and take the seal with you ( as long as you're lucky enough not to damage the part number on the seal taking it out). as mentioned above, mark the pinion flange and nut and count threads to make sure it goes back in the same place.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 10-07-2003, 01:38 AM   #7
jorgensensc
I didn't see a part number on the seal. Is it written in magic ink? I really appreciate your help. I wrote a suggestion in your thread. It's funny, but I hadn't even entertained the notion of going to GM dealer. I guess I should K.I.S.S. sometimes!
Old 10-07-2003, 01:52 AM   #8
O'l Buck
O'l Buck's Avatar
The part number will be stamped in the metal part of the seal, usually hidden by 30+ years of rust and barely legible if at all.
Chad
Old 10-07-2003, 02:02 AM   #9
jorgensensc
I must be crazy. My seal looks like a metal cap on the end of the differential. All of the seals I see look nothing like it. Is it a metal cap and the seal is under it? I'm sooooo confused. I drive the truck daily, so putting it out of commission is not very good for me.
Old 10-07-2003, 02:30 AM   #10
O'l Buck
O'l Buck's Avatar
There is a protective dust cover on the pinion flange, concave in shape to keep rocks and dirt out of the seal area. If you take the flange out, you will be able to see the seal.
Chad
Old 10-07-2003, 02:47 PM   #11
jorgensensc
Thanks for all the help. I will drop the driveshaft and see what I can figure out. I'll let you know.
Old 10-07-2003, 07:38 PM   #12
jmanz69
Careful, they attack...
jmanz69's Avatar
You HAVE to take the pinion nut off (good luck) to get to the seal. You can't see it with the driveshaft still on the truck. It took me an hour and some time with the torch and impact wrench to get my pinion nut off. Just pop it out and pop in the new one. Like everyone says, mark the threads and the nut. Rear ends are $$ to have rebuilt, and since you need your truck everyday, I would take the extra time to be sure it's done right the first time.
jmanz69 is offline   Reply With Quote
Old 10-15-2003, 03:11 PM   #13
jorgensensc
O.K. Pulled the pinion nut off a few Min ago (during lunch), and I can't seem to get the pinion itself off the bolt??!!! WTF? How can I get it off? I have tapped and banged, to no avail. does anyone have any suggestions?? I need to try and get this completed today. Also, how do you get the driveshaft out of the center support bearing? Thanks!!!
Shawn
Old 10-15-2003, 03:21 PM   #14
COBALT
COBALT's Avatar
I'm pretty sure the seal mounts into the case like any other seal. Probably the end of the housing??? I've never removed/replaced mine. Are you having a hard time getting the pinion nut off, or you can't get the seal out?
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 10-15-2003, 03:28 PM   #15
jorgensensc
I got the nut off easy. I can't get the part that te driveshaft connects to off of the bolt the nut screwed on to. Does this make sense? The seal is under the flange that I am trying to remove.
Old 10-15-2003, 03:39 PM   #16
Tx Firefighter
You have to tap it off with a hammer. Some times, not too gently either.
Old 10-15-2003, 03:42 PM   #17
jorgensensc
Wow, I guess I will bang a little harder. My Chilton says there is some kind of removal tool? Any Idea what they are talkin about and if it is necessary? Thanks again for the quick replies!!!
Old 10-15-2003, 04:30 PM   #18
jorgensensc
O.K., I beat the crudd out of it and I can't get it to budge!!! Is this really how it comes off?????
Old 10-15-2003, 04:46 PM   #19
Ed ke6bnl
The secret tool is shown in the latest chp mag on redoing a 12 bolt. you need a plate about 1/2 in thick, drill two or four holes for the plate to bolt to the flange and a center hole threaded for a larger bolt to push against the pinion to force the flange off.
I have gotten them off with hits with a rubber mallet but yours is like the one described in the magazine. Ed ke6bnl
Ed ke6bnl
Agua Dulce
70 S.E. Los Angeles
70 Chevy short bed
1948 F3 ford pu
1949 F1 stock V8 flathead 3 on floor
1950 F1 pu street rod
1948 F6 Ford Dually/350sbc no bed stock trans&rear
1972 El Camino 4" chop
1953 Chevy 3100 2b daily driver
1970 SB 4X4 400ci 6in lift
Ed ke6bnl is offline   Reply With Quote
Old 10-15-2003, 04:50 PM   #20
jorgensensc
Looks like it's tool fabricating time!!!!
Old 10-16-2003, 01:03 AM   #21
jorgensensc
Yeahhhh!! I got the pinion off!! What I did (in case anyone ever has this problem) is used the straps that hold the u-joint to the pinion and strapped in a hammer so that it protruded from the top a bit, but went through both straps. Then I tapped (insert beat the crud out of) the hammer on the side with a rubber mallet. This worked the pinion off. Slowly at first then it quickly came off. The seals I bougt from kragen auto parts didn't fit (go figure). When I tried to give tem the numbers that were atamped on the side of the seals they said they couldn't cross reference them(Kragen Sux). Autozone did it without a problem. I will be buying my parts from them from now on!!!!!
Old 10-16-2003, 02:10 AM   #22
SLS
Finish the'71..or bust!
SLS's Avatar
Sounds like you have it under control now. GREAT!
I'm sorry I did not see this thread earlier as I just replaced my pinion seal and cover gasket on my Corp. 12- bolt.
The pinion seal I used is a:
NATIONAL (Federal-Mogul) 8460N
Do like the other guys said....marking the pinion nut relation to the driveshaft yolk, and the driveshaft yolk to the rear axle....and counting the threads for good measure.
But if you get overly concerned about the torque on the pinion nut:
Get an INCH-LB 'beam style' torque wrench, jack the rear wheels off the ground, remove the brake drums (to relieve all resistance on the axles), and check to see that it takes 15 to 20 INCH-LBS to cause the pinion to turn. Remember...what to look for here is 'resistance'.
My manual says that 15 inch-lbs is spec (if new bearings and crush sleeve are installed), but if you are not replacing bearings and crush sleeve that 20 is recommended to reset pre-load and compensate for worn bearings and sleeve.
I filled my differential with Royal Purple...and so far it all is working like a charm. No clunking, whining, or anything else wierd.
Plus...no big oily spot on the driveway!
I hope I've explained this right....
SLS is offline   Reply With Quote
Old 10-16-2003, 07:40 AM   #23
Tx Firefighter
That is the correct way to determine bearing preload, the torque wrench way. But, that way is only intended for use when the carrier isn't installed yet. When the carrier bearings and axle bearings are added into the picture, they give the wrong reading.
That said, it's probably pretty close doing it that way. When I worked at the Chevy dealer, GM taught us to use the mark the yoke method.
Kevin
Old 10-16-2003, 10:47 AM   #24
Hugger
Hugger's Avatar
If you still have the whinning sound, check the carrier bearing, as well. I was real close to taking mine to the rear end shop, when I decided to take a chance and check the bearing. When I got it out, it would not turn by hand at all. Installed new u-joints, and carrier bearing, and most of the whinning went away. Probably still need rear end work, but it is not near as bad as before.
By the way...I now have the tink sound comming from the driveshaft, when I stop completely or take of from a stop. Sounds like the front shaft, because I tapped on the shafts and the tone is exactly like the front.
Go figure.
72 LWB - Hugger Orange
350/350 3.73
Next; 335hp GM Crate
Hugger is offline   Reply With Quote
Old 10-16-2003, 11:10 PM   #25
jorgensensc
Update:
I got the rear differential seal in today, and the tranny seal. I am trying to replace the carrier bearing also, but I'm having a hard time getting the u-joint out to take the old one off. Any suggestions would be great!!!. There is a bolt under the u-joint, do I need to remove that to take the two drive shafts apart?? Can I reuse the u-joint that holds the 2 shafts together, or do I need to buy anoter one? Thanks for everyones help! I know it takes time to respond, so thanks!!!
