Old 09-03-2016, 10:25 PM   #26
Bueno 68C-10
Bueno 68C-10's Avatar
are the 73-87 springs any different because I'm planning on using a k30 as a doner truck?
Bueno 68C-10 is offline   Reply With Quote
Old 09-04-2016, 09:06 AM   #27
Re: C30 4x4 conversion
springs are longer. If you are swapping the whole frame, no biggie. If you use the later springs on the earlier frame it will yield a little bit of lift due to relocating rear shackle mount. The frame continues to drop behind original location, so mounting point will be lower on the frame
Old 09-04-2016, 10:05 AM   #28
Bueno 68C-10
Ah I see. Yeah probably I'll just order k20 springs then!
Old 09-22-2016, 12:24 AM   #29
Bueno 68C-10
Would it work to use a 3/4 ton front axle?
Old 09-22-2016, 09:13 AM   #30
Deer_hunter_088
Deer_hunter_088's Avatar
can we see pictures of the truck please
1967 GMC C25 305 V6
1969 K20 CST
1994 k1500, Oldredz71(ext shorty 4x4 6 in lift)
1998 S10ZR2
2001 Silverado 2500hd 8.1L
2003 Silverado 2500hd Crew cab
Deer_hunter_088 is offline   Reply With Quote
Old 09-22-2016, 09:41 AM   #31
Bueno 68C-10
Sure but I don't know how this pertains to the question I just asked.
Old 09-22-2016, 09:45 AM   #32
Deer_hunter_088
because we love pics here, and is it leaf front end? if it is just get a front axel assembley thingy and put it on the front, get a t case, mount it, run your driveshaft, and plumb the brakes and vents and bang you are done, if its ifs, well either new frame or do alot of fab work.
1967 GMC C25 305 V6
1969 K20 CST
1998 S10ZR2
Old 09-22-2016, 10:52 AM   #33
57taskforce
All about them K’s
57taskforce's Avatar
Yep you should be able to use a gm 3/4 Dana 44. Either the 44 or the Dana 60 will bolt up just the same. any 71-72 or square body front axle will bolt up and be most ideal with disk brakes, once it's converted to front leaves. However you will likely need front dually adapters to run your current wheels.
Tyler
57taskforce is offline   Reply With Quote
Old 09-22-2016, 02:44 PM   #34
Bueno 68C-10
Will adding the dually wheel adapters be hard on the wheel bearings? Will it still be Okay to use the truck and load it heavy?
Old 09-22-2016, 05:05 PM   #35
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
On a D44 I don't know if you'll be able to get anything other than an aftermarket adapter. Make sure you use a big hub D44 that has the larger bearings other wise the small hub may not like the added weight etc.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 09-22-2016, 05:08 PM   #36
Bueno 68C-10
A Dana 60 would probably be better suited for the job correct?
Old 09-22-2016, 06:10 PM   #37
57taskforce
All about them K’s
Absolutely it will.
Tyler
Old 09-22-2016, 06:18 PM   #38
Dieselwrencher
Originally Posted by 57taskforce View Post
Absolutely it will.
Exactly. I forgot to mention how the D44 ball joints may wear out every year too. Not to mention the little u joint if you plan to use the 4wd.
Ryan
Old 09-22-2016, 06:22 PM   #39
57taskforce
All about them K’s
Yes sir your correct on that. Those king pins on the 60 are tough as nails compared to the ball joints. Ujoints are another big plus on the 60.
Tyler
