I picked up a rust free 67 c30, but no motor or trans. I am wanting to convert it over to a 4x4. Is it easier to convert the original frame? Or is it easier to put the body onto a 73-87 4x4 dually frame? Let me know what you think! Thanks in advance!!
All about them K’s
![]() Join Date: Jun 2014
Re: C30 4x4 conversion
http://67-72chevytrucks.com/vboard/s...=703160&page=6
This is the correct way to do it in my opinion. The 73-87 frames are different and it doesn't come out near as nice as this.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
Yeah that looks fairly straight forward! There are a few measurements I'm not sure how you would find.
Posted via Mobile Device |
Either way works well. Staying with existing frame is nice and clean, but you need to have a 4wd donor or gather a heck of a lot of stuff
Why do people call the 73-87 less clean? Is there that many mounts to move?
All about them K’s
Because the frame bends in different places and its hard to get the body bolted up without a body lift in my experience.
With the body lift does the frame stick out very far below the body? Does anybody happen to have a picture?
I read in one of the threads on this topic that you need to straighten the frame in a certain place. Where is that and is it major?
#9 | |
I could show you two trucks, one using 67-72 frame and one using newer frame and you couldn't tell, unless you crawled around underneath it.
Ok thanks for the advice!! I just wanted to make sure I saw the big picture before diving in!
All about them K’s
Your not referring to the e brake cable holes in the front of the 67-72 c-30 frame that need to be filled so you can bolt the spring mounts to the frame are you?
Yeah that must be what it was but that's nothing too major or structural. Thanks!
#13 |
![]() ![]() Join Date: Jan 2015
It's not that bad of a job here's pics of how I did mine
Posted via Mobile Device Posted via Mobile Device |
#14 |
Another
#15 |
Pic
#16 |
Welded new plate in
#17 |
Pic of finished
#18 |
Jeff,
did you use 1967-72 spring length or 1973 up ? I am working on building my 1 ton longhorn chassis and not sure what length to use.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
#19 |
Is that where the spring shackle then bolts?
#20 | |
#21 | |
Posted via Mobile Device Last edited by Jeff's bowtie's; 09-02-2016 at 09:45 PM. |
#22 |
How much different are the newer springs compared to the 67-72 springs in length?
#23 |
They are the same length they are for a 72 they are arched to give the 4 inch lift
#24 |
I plan to use mine as a ranch truck so I want to make sure that I will be able to handle a load still.
#25 | |
All about them K’s
Here's an example at the bottom of this page:http://www.sdtrucksprings.com/leaf-s...c/pickup-67-72
