Old 10-03-2016, 10:47 PM   #26
clinebarger
Re: Rubberbandit's 4L80E Build Thread.
The Intermediate "Brake" Band, Direct Drum that the Intermediate Sparg & Race are attached too goes in next.
Then the Forward Drum.
Nothin' but "Lacing Clutches"
I reused the old (In new shape) Intermediate Brake Band!
Band & Direct Drum installed...
Forward Drum...
clinebarger is offline   Reply With Quote
Old 10-03-2016, 11:03 PM   #27
clinebarger
4th Clutch Housing, Nothing special here. I only use AC-Delco/GM bolts on this housing, Aftermarket bolts vary too much in quality. Trans-Go being the worst!
Old 10-04-2016, 12:03 AM   #28
Captainfab
60-66 Nut
Subscribing
Old 10-04-2016, 08:01 PM   #29
clinebarger
Overrun Hub, O/D Carrier, Output Shaft, & Pump Installed, Front Endplay measured .013".
Old 10-04-2016, 08:13 PM   #30
clinebarger
1-2 Accumulator, Lo/Reverse Servo & Servo Cover installed.
Intermediate Brake Band Servo.
8 Sonnax imidized plastic Checkballs, They don't tear up the Separator Plate like the stock chromed steel Checkballs.
Old 10-04-2016, 08:40 PM   #31
clinebarger
Valve Body & Mods.....
Ream & fit a Oversized Trans Go AFL Valve, Restores the Actuator Feed Limit hydraulic integrity, Wider "Land" to prevent future wear.
Sonnax TCC Regulator Valve, Has a Teflon Seal to prevent leakage, Lighter Spring for firmer TCC Apply.
New "Thimble" Filters.
New 1-2, 2-3, EPC, & TCC PWM Solenoids.
New Trans-Go Separator Plate, .120" 2nd feed, .101 3rd feed, & .101 4th feed.
3rd & 4th Accumulator left Active.
Valve Body torqued too 98 Inch Pounds.
Trans Go AFL Valve top, Stock Valve bottom...
Sonnax TCC Regulator Valve...
Separator Plate...
Valve Body & Accumulator Housing ready for install...
Old 10-04-2016, 08:51 PM   #32
clinebarger
Valve Body, Harness & Filter Installed..
Old 10-04-2016, 09:15 PM   #33
clinebarger
All done, Painted with Cast Iron engine paint per Chads request.... NO paint on the mounting surface (for grounding reasons), And NO paint around the Pump, If the Pump ever has to come out......The paint flakes off & goes everywhere.
Old 10-04-2016, 09:55 PM   #34
Dustytrix
Very nice work, I take it that you did not just order a rebuild kit but ordered from different places ? I have a 96 4l80e that was pulled working fine or so I was told. I am tempted to go thru it since its still sitting on the floor.
Dustytrix is offline   Reply With Quote
Old 10-04-2016, 11:05 PM   #35
faribran
Cline, very nice work. Rlt
faribran is offline   Reply With Quote
Old 10-05-2016, 12:40 PM   #36
tinydb84
tinydb84's Avatar
So cool! Thanks for sharing. How much do you typically charge for a rebuild like this?
David
Instagram: myfabguy
Old 10-05-2016, 08:25 PM   #37
clinebarger
I get Clutches, Steels, Seal Kit & the Sonnax parts from Whatever It Takes (WIT), Very similar too Transtar.
Ac-Delco/GM parts are bought from my local Chevy Dealer.
The Intermediate Snap Ring was bought directly from CK Performance.
The TH400 Pistons, Early 4L80E O/D assembly, & TH400 Silencer ring come from my personal Stock.
You can buy a machined TH400 Direct Piston from CK Performance for $80, To get your monies worth......Their Billet Piston Kit is only $20 more.
http://www.ckperformance.com/View/4L...TCH-PISTON-KIT
The Steel Forward Piston is OK to use as it is not a "Shifting" Clutch, I use the TH400 version because my OCD
Please PM me, I am not allowed to advertise on this site as I am not a Vendor.
Old 10-05-2016, 09:22 PM   #38
NorCalAnthony
+1 I wish you were close enough to do the rebuild on my 4l80e. I really like how you mix and match all the different parts to get the best end product instead of just ordering generic rebuild kits like I'm sure most transmission shops would do.
NorCalAnthony is offline   Reply With Quote
Old 10-06-2016, 02:03 PM   #39
indymachinist
Thanks for posting this. I apprecite the effort it takes to document something nicely like that.
-Curt
My 1968 Chevy shortbed stepside build
indymachinist is offline   Reply With Quote
Old 10-08-2016, 02:14 PM   #40
solidaxel
solidaxel's Avatar
Thanks for the detailed input.
What type of "cast iron " paint do you use !
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 10-09-2016, 10:26 PM   #41
clinebarger
Dupli-Color DE1651.
Old 10-10-2016, 12:01 AM   #42
solidaxel
solidaxel's Avatar
Thanks again !
LS 3 4L70E
Old 10-10-2016, 11:23 AM   #43
lyrikz
PITbut
lyrikz's Avatar
Originally Posted by clinebarger View Post
Thought I would share some stuff on Rubberbandit's (Chad) 4L80E build, Most people never get to see what actually goes into building their transmission. This is going behind a stock LS3 but will handle A LOT more when I'm done!
It's a 2003 4L80E out of a Express Van, REALLY nice core! It could have been put in just like it is & easily handle a LS3.....That's how good of shape it was in!
Got the Case cleaned up, Ran it through the Hot Water Vat twice, A little Iron staining on the lower half of the Case, I can paint this if you want Chad.....But I would leave it be, Your call??
Awesome info. I have a 4l60e out of a astro van 4wd. That thing worth rebuilding?
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 10-10-2016, 08:40 PM   #44
clinebarger
It all depends.....What engine is it going behind? Will you need to convert it too 2wd?
Old 10-11-2016, 10:25 AM   #45
lyrikz
PITbut
lyrikz's Avatar
v6 was in front of it. No, it would be used with a 4wd.
and sold.
Old 10-11-2016, 11:15 AM   #46
lyrikz
PITbut
lyrikz's Avatar
Oh, i mis read what you wrote. It had a v6 behind it, i would probably be putting a turboed 4.8 liter behind this. 5-600hp.
and sold.
Old 10-11-2016, 02:05 PM   #47
Low Elco
Beautiful documentation on the thread. Thanks for all you do to clear up the mystery of transmissions for us. If I may, since it seems to have turned that way, What is involved in changing a 4wd 4l60 over to a 2wd and what should it cost? Lots of 5.3/4l60 trucks, but a LOT of them are 4x. Like the one I just got. If I were in DFW, I'd be at your door, but I'm not, sadly. A thread on that would be great, but any advice would be welcome. Thanks, and again, great job.
Low Elco is offline   Reply With Quote
Old 10-11-2016, 07:29 PM   #48
clinebarger
It will cost too much to get a 4L60E to handle 500-600 horsepower, I can build one too hold 500hp N/A reliably & 400hp Boosted.
To get more in-depth.....Start a thread, Let's not derail Chads build thread too much.
Sure, I can do a thread.....
