Old 10-17-2016, 09:09 AM   #26
juddss
Re: WTB Traclock or Powerlock carrier for Dana 60
Ok I messeged you the info.
juddss is offline   Reply With Quote
Old 10-18-2016, 03:09 PM   #27
gmc 2500 4x4
Looks like 23.00 shipping
gmc 2500 4x4 is offline   Reply With Quote
Old 10-19-2016, 08:15 AM   #28
juddss
Sounds good ill take it sir. Please message me your paypal info if that's how you would like to get paid.
Old 10-19-2016, 08:21 AM   #29
juddss
Originally Posted by w314speed View Post
The spiders probably aren't seized. I don't think the True-Trac is buildable, from what I understand. There is a lot of pressure on the side gears from the wave spring plates, so it would be hard to turn unless totally worn out. Once installed and used some to get the lube through the center working parts should be fine. I have two more for anyone that might be interested, after GMC 2500 4X4 sells his! I also have 3:54 ring and pinions. Thanks, Dan
Ill let you know on the 3:54 ring and pinion. I have to do some research and see if it will work for me because I tow as well. Any idea how the RPMS are on this with a th400 related to speed? I have a gear vendors overdrive I installed but it doesn't work. I have to send it in and get it rebuilt for $1100
So I was thinking of ditching it and installing these gears. I have a 454 big block now and may install my supercharged LS motor over the winter. The 4:11 gears in it now are 4k RPMS at 70 MPH
Old 10-19-2016, 04:16 PM   #30
juddss
Money sent thanks!!!
