11-10-2016, 11:42 AM | #26 |
I'm just glad to be here!
Re: 65 bagged farm truck
Looking good. I like how you did the front inner fenders.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
11-12-2016, 04:03 PM | #27 |
I'm diggin this build
63 Shop Truck Build...Sorta http://67-72chevytrucks.com/vboard/s...d.php?t=722311 |
11-14-2016, 09:31 PM | #28 |
wow that thing is sick !!!
11-15-2016, 12:00 PM | #29 |
I am digging your build. Gonna subscribe so I can follow along. I have a 63 GMC that is next in line for a build somewhat like yours as soon as I finish my current project.
Looking good.
"Life is too short to drive a boring vehicle". Later, Wayne |
11-15-2016, 11:22 PM | #30 |
Got a bit more done this weekend. I have got to get my but in gear to get this thing done. My goal is to have it ready for a local car show Easter weekend
I set up the front fenders so you could drive the truck 1' off the ground(mostly for safety). I was able to get about 90% of the full turning radius without making contact with the inner fender. Thanks to Accuair I will be able to program that height into my presets.(this picture is with the frame 1'off the ground) Inner fender sand blasted and ready for body work Starting to get the motor ready to put in |
11-15-2016, 11:52 PM | #31 |
Looks great! Your going to love Accuair. Worth every dollar even with our terrible exchange rate
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
11-16-2016, 01:01 AM | #32 |
I did a quite a bit of research on air management and talked directly with accuair at SEMA last year. With the ride height sensors, programable heights and ride monitoring it only made sence. I have put a lot of time into trying to get the geometry rite on this truck and this system is the best way to know everything is in its place consistently . Luckily I bought this system about a year ago when the dollar was slightly higher. I also got it from KMS tools which is a Canadian company so the shipping and brokerage was a bit better.
11-21-2016, 12:29 AM | #33 |
Got a lot done this weekend.finished getting the motor buttoned up and got it set in place. Also changed the pinion seal and got the diff back in. Definitely a lot more room in the garage now. Dad also did a lot of work on the inner fenders and they are now in primer.
motor in place truck at ride height truck aired out |
11-21-2016, 11:49 PM | #34 |
Cool ride, what size front tires you running.
11-21-2016, 11:53 PM | #35 |
11-23-2016, 11:40 AM | #36 |
Ba Ba Bap Bap Bad, BAD TO THE BONE. (music playing in my head when I look at this truck layed out)
11-29-2016, 12:42 AM | #37 |
Today marks the one year anniversary of pulling the truck into the garage.
before after |
12-05-2016, 12:54 AM | #38 |
Made some progress this weekend Started building the board for the air management. Dad also finished painting the front inner fenders
front inner fenders painted underside of the air management board. relay, fuses and wiring mounted underneath try and clean it up a bit on top. I am very happy how it turned out. |
01-05-2017, 01:08 AM | #39 |
Been a while since i have posted anything but that does not mean i have not been busy. It took a few weeks for my final big order of parts to come in and i did not have a hole lot to do. I decided to start looking at the wood for the bed and cut and drill the support straps.Finally the parts came in and got the new shifter installed and started dressing the motor as well as a few other things.
. air management painted up test fitting new rad laying out bed strips Last edited by B28; 01-05-2017 at 01:20 AM. |
01-05-2017, 01:24 AM | #40 |
Also got a new personalized plate for Christmas. Lowrock is a play on my moms maiden name and is also the name of the truck
01-05-2017, 07:40 PM | #41 |
Truck looks awesome. Are you reusing the original A-arms or did you get new ones with dropped spindles? Original rear end as well? Great inspiration for my build. Thanks for all the great pics. Should be on sweet ride when you are done with it.
01-05-2017, 08:13 PM | #42 |
The front crossmember is from a 74 truck as is all of the steering linkage and power steering box. I had to make a couple of modifications for clearance on the a arms. The rear end is original to the truck. It is 1 1/8 inch narrower then trucks with disk brakes up front( I think 70 was the year it changed from drum to disk). I also got conversion axles for 5x5 bolt pattern.
01-05-2017, 08:22 PM | #43 |
Who Me?
Great build!! Im hitched up for this ride!
Steve 1997 Tahoe LT 4D 2WD (DD) 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
01-05-2017, 09:59 PM | #44 |
Awesome work! I love seeing someone build their own notches and suspension components too. Gives motivation to those of us who don't want to drop huge $ on prebuilt setups (although I do admit, they sure would be nice to have).
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
01-05-2017, 11:48 PM | #45 |
Thanks for the reply. I am now thinking that I will use the 86 1/2 ton frame I have for my build. I have a 64 that I want to lay frame with. Can you please describe what modifications you made to your front suspension. It looks like you cut down the cross member. Did you do anything to A arms etc. Use dropped spindles. Thanks for the advice. 👍
02-07-2017, 07:21 PM | #46 |
Truck is coming along slowly. Have been pretty busy and also took a random trip to vegas. Still lots of small task that take a lot of time before she is moving.
hood hinges painted to match body color got a local sign company to paint on Chevrolet onto the valve covers. I am very happy how the engine bay is turning out Interior is starting to come along. got the gauges, shifter and some sound deadener installed. |
02-07-2017, 08:01 PM | #47 |
Who Me?
Looking good!! Great progress!
02-07-2017, 10:53 PM | #48 |
I dig the white engine block. Very cool truck.
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
02-07-2017, 11:52 PM | #49 |
Really like your truck.
Am thinking of buying a Plasma. What kind did you buy and any advice?
02-08-2017, 12:04 AM | #50 | |
Posted via Mobile Device |
